The problem is electrolux washing machine when i start the machine it says 10 communication some time inter lock i did not change any cars 2 year ago also it happens but at that time i remove all the
How can i solve this problem
  • Mohamed Rashaad Dec 28, 2013
    The problem is electrolux washing machine Model NO:W4400H 45 kg machine ,when i start the machine it says on the display, 10 communication some time inter lock and some times Securer hopper. I did not change any cars, 2 year ago also it happens but at that time i reconnect all the all the jacks after it solve,but again it happen same thing.I noticed it is very slow functioning after 2 round these errors are coming. door lock sound also it takes 10 seconds i tried with new door locking device but same. how cane i solve this problem.
W4400h elecrolux spin is not working please tell what problem
Posted on Apr 28, 2014
  • 213 Answers
SOURCE: solving my lint problem in washing machine
the lint filter is a large plastic part that is conected to the bottom of the tub. you have to take the tub out to clean the lint filter. i would suggest, before you try taking the tub out, going to sears,they seel a product called washer magic. its a cleaning powder for your washer. just follow the instructions on the jug it comes it. it works pretty good
Posted on Nov 25, 2007
  • 4 Answers
SOURCE: Whirlpool AWM8121 ?door open? light flashing
I had the same problem about a year ago, I replaced the door switch but didn't fix it, I found the brushes in the motor has worn out - Replaced the brushes and fixed the problem.
Posted on Dec 13, 2008
SOURCE: intuitive washer code 43
Thx to fixya l sovled my code 43 by removing and cleaning my balance control switch. If anyone needs to know here step by step
1 Make sure the plug is out ( dont want curly hair do you )
2 Remove 2 screws from back of control panel and lift off
3 Remove 1 screw holding grey module panel
4 Under grey module on right hand side is the balance control switch with 1 white and 1 yellow set of wires
5 remove wires ( make note on where they plug back into )
6 2 small clips hold the switch in place, open them gently and pull switch out
Its that simple , clean the contacts with some wd40 or bicarb soda in hot water to get rid of any corrosion, make sure that the little button on the side springs out freely ( tiny drop of oil/wd40 ) clean or replace plugs on the white / yellow wires. install and do that washing!!! It worked for me but if the switch is too far gone no need for a service man just get a new one and go for it .
Good luck Pieman
Posted on Jul 01, 2009
SOURCE: Electrolux EWX 14440 W Washer will not start
This sounds like what I am having. Machine tumbles but does not rinse. Some postings say this is the door lock problem. Google "Fridigdaire washer will not Spin" and page down to read solutions.
Posted on Oct 26, 2009
SOURCE: I have a Zanussi ZWF12070W1 washing machine. It's
Hope I can help.When you press the start button is there a buzzing coming from down by the filter if so Check that there is not something stuck in the filter.You will have to be careful depending on how much water is left in the drum so put some towels down and undo filter slowly or get the machine near a door then release filter out onto a door step.when drained shine a torch up inside filter and see if the little plastic blade on pump can turn but do not try and force it,if you do find anything in there then try it again and check the pockets.If there is still a fault you will have to call out your Engineer.
Good Luck
Posted on May 05, 2010
Our Electrolux EWFLS70JRR0 washer has issues with door not unlocking and then occasionally stopping mid cycle. We have been limping along by unplugging and resetting lock but starting to see more random...
Thank you for your post, friend!
Based off the information you have provided your Electrolux washer is displaying multiple issues. This sounds like a faulty control panel. You may need to disassemble your washer and test each electrical component for a proper diagnosis. This is not a simple DIY job and I would recommend seeking assistance from a professional technician for proper repairs. This will help you avoid any future issues. Hopefully this is helpful. -Matt
Mar 29, 2015 | Electrolux Washing Machines
Door will not lock to start washing machine
Good Morning Michael, I understand that your washer door will not lock and it is inoperable. Let's try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately 2 minutes and turn on the washer. Select a normal cycle and verify if the washer will start. If the appliance will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. I would suggest contacting an experienced service technician to determine the precise cause.
Jul 19, 2013 | Electrolux EIFLW55HIW Front Load Washer...
My electrolux 880 front loader won't spin anymore
One of two things ... door lock or a speed board... I have been a tech for 10 years and I can say 9 times out of 10 its the speed board ... Its the board down by the base of the washer
Mar 24, 2011 | Electrolux Washing Machines
Oct 24, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
