Question about Lexmark X5495 Printer
Carrier jam on X5495
My lexmark printer X5495 has a carrier jam message. I don't believe there is anything jamming it. When you press tick the carrier bangs each end of the printer and you still have the same message.
A plastic strip seems to have fallen out is is grey, the length of the printer and has small holes each end.
  • richardgutse May 18, 2009
    Please can you explian how to do this?
  • 30 Answers
Check paper sensor
Posted on May 17, 2009
  • victor obike Nwabuisi May 21, 2009
    check the plastic strip and try to locate were it fall off from and try fixing it back ai think that is the best solution
Carrier Jam message in window
http://images.lexmark.com/publications/pdfs/2007/3500/mhs/en/d0e10275.html
Jul 21, 2012 | Lexmark X4650 InkJet Printer
Printer keeps saying alignment, load paper and press tick will not print anything off ?
It could be the cartridges are not seated properly in carrier. Try to remove any paper from the paper feed tray. Remove the cartridges from the printer. Then unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert the cartridges. Try to print again.
Mar 08, 2011 | Lexmark X5495 Printer
Carrier jam
Raise the scanner unit and check the length of the cartridge carrier path for any foreign objects or anything blocking the free motion of the unit. Make sure that the cartridge carrier lids are closed. Then lower the scanner unit and press the button with the check mark. (page 173 of the manual)
Now try to print. If the error persists, there is either still something not in place, blocking the unit from moving freely or it needs service.
I hope this works.
(some of the printers have a guide strip behind the carrier that can come out of the carrier but I'm not sure this unit has that. If it is present, press it down and let it up in the guides (sometimes you have to move it forward and back as well).)
May 14, 2010 | Lexmark X5495 Printer
When i press copy the carriage shoots across and
The slamming of the carrier past the forward stop cause a reported carrier jam.
You should have the printer serviced by an authorized Lexmark Servicer.
Don
Nov 19, 2009 | Lexmark P4350 All-In-One InkJet Printer
Lexmark X5495,Error 1203, Says Clear Carrier Jam
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 3 Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the All-In-One (AIO) on.
Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark.
No: Continue to Step 4.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 5 Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 4 and 5. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
No: Continue to step 6.
6 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 7 Insert the black cartridge. Close the top cover, reinsert the power supply and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, skip to Defective Cartridge Test.
Apr 15, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Carrier jam
From what you are saying you are getting 'clear carrier jam' because of a misalignment. The jam error message is a generic message that applies to a multitude of things. The carrier while is in right, might not be sitting right. A piece of plastic that holds the carrier might be broken or the printhead might be messed up. Anything that causes it to not sit the way it wants will cause that error message.
Feb 10, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark 3500 carrier jam
Hi adirag! This is directly out of the user's manual! Clear Carrier Jam These are possible solutions. Try one or more of the following:
Remove any obstructions
  1. Raise the scanner unit.
  2. Remove any objects blocking the path of the print cartridge carrier.
  3. Make sure the cartridge carrier lids are closed.
  4. Close the scanner unit.
  5. Press button_select_0.jpg.
Remove print cartridges
  1. Make sure the printer is on.
  2. Raise the scanner unit.
  3. Remove both print cartridges.
  4. Make sure the cartridge carrier lids are closed.
  5. Close the scanner unit.
  6. Press button_power_0.jpg to turn the printer off.
  7. Disconnect the power cord from the wall outlet.
  8. Plug the power cord back into the wall outlet.
  9. Press button_power_0.jpg to turn the printer on.
  10. Reinstall the print cartridges. For more information, see Installing print cartridges
  11. Close the scanner unit.
  12. Plug the power cord into the wall outlet.
  13. Press button_power_0.jpg to turn the printer on.
  14. Reinstall the print cartridges. For more information, see Installing print cartridges
______________________________________________
Hope this helps and good luck!
-WB
Jun 14, 2008 | Lexmark Wheelwriter 3500 Typewriter
Error 1203 and carrier jam error
Error 1203 on a Lexmark is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad... I would suggest you to try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
If that doesn't work just call up their support number and check for replacement..
May 24, 2008 | Lexmark P915 InkJet Photo Printer
Lexmark X5495 Printer Logo
448 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
