Question about SYMA Toys industrial New Syma S107 Radio Remote Control Helicopter
Everything spins including the body - SYMA Toys industrial New Syma S107 Radio Remote Control Helicopter
    Problem Solver:
  • 21 Answers
Sounds like one of the motors is not working it has either burnt out or the drive cog is slipping or come off.
Kind regards, Julian.
rccontrolfreak.co.uk
Posted on Jan 31, 2014
Neither the upper or lower wash arms spin.
Circulation pump might be faulty. or spray arms are blocked. remove spray arms and clean them and try it again.
Mar 15, 2014 | KitchenAid 24 in. KUDP01DL Built-in...
Hi onley the spin is the problem i put a knife to keep the switch on then i push to make it turn then everything is ok it is not the switch everything eles is working
As the lid switch controls the spin operation (lift lid spin stops)for obvious safety reasons it also controls the out of balance arm at the right rear of the bowl. you can access this by reaching your hand under between the bowl & the body you should feel a plastic arm hanging down, gently wriggle back & forth then try your spin again normally. If that doesn't work you need a serviceman to replace probably the cutout switch, in those model machines it is a common problem after long use. I have found that out of every 50 or so there will be a faulty batch produced as most are made cheap in China now.
Mar 13, 2014 | Fisher and Paykel GWL11 Top Load Washer
Helicopter body keeps spinning
add small counter weights on copters plastic body just enough to allow motor to spin without dragging the body and spinning while in flight. check if motor's rotor shaft comes in contact with copter's body, make adjustments on it
Dec 12, 2013 | Toys
Everything works but the belt doesn't spin
please see the video and lube inmediately. God bless you
Dec 16, 2012 | RTO Image 15.0R Treadmill Walking Belt
Washing machine won't spin, will do everything else including drain
have you got any buttons on the m/c that say with hold spin or similar will it spin on any other program as some times with the same program running all the time the clock wares out so it wont go onto the spin program
Sep 28, 2012 | Washing Machines
I recently got a DH-1 AeroQuest Mini Helicopter. It was working fine until I crashed it against the wall. So now the top Propeller spins but the bottom propeller does not and the helicopter just spins...
I had the same problem. Bottom blade would not spin. There are 2 shafts that spin 2 gears. The outer shaft that spins the bottom blade has 2 set screws and my set screws got sheered off. I replaced both set screws and everything works now....
Sep 04, 2011 | Toys
My Thin Twin stackable washer & dryer Model # LTE5243DQ3 is having problems w/the washer spin cycle. I'm thinking I may just need a new timer because it goes through all the cycles except the spin...
Before wasting money on a timer that wont be returnable once it is removed from the packaging please respond to me and tell me does the washer do everything including draining, and the only thing it will do not do is spin
or will it wash but not drain and spin
their are 2 posibilities based on your response and neither is the timer
Thanks,
Gene
so ya know i have beena appliance repair technician for over 30 years
Jul 23, 2011 | Whirlpool LTE5243D Top Load Stacked...
Operates correctly on all wash,rinse,soak cycles but does no spin
Check the door switch, if it's faulty the spin cycle will not work, but everything else will.
Apr 02, 2009 | Asko W6021 Front Load Washer
Kenmore 70 won't spin, does everything else
  • there is a plastic part that releases the break when spinning. this part has broken.
  •  this whole kit in the picture sells for $35.00 and includes this piece.
  • the clutch needs to be replaced too so this kit is all you need.
  • item # 2670  repairclinic.com
  • it is a 20 minute job for an experienced person.
Jul 07, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore front loader won't spin
glad to be of assistance(hopefully) here if you need!!!!!!just remenber to include make and models with future preoblems on anything, because everything is made a little differently
Mar 14, 2008 | Washing Machines
SYMA Toys industrial New Syma S107 Radio Remote Control Helicopter Logo
Top SYMA Toys industrial Toys Experts
MeAndMyBrain
Level 1 Expert
Terry Hair
GI Consulting
Are you a SYMA Toys industrial Toy Expert? Answer questions, earn points and help others
