Question about Xerox Office Equipment & Supplies
Xerox copier XC1045 - paper goes half way through machine and then stops. Everything else seems to be working correctly. Changed paper and cleaned entrance. Clunking sound occurred before this happened.
  • ctomasin May 21, 2009
    Half way through the carriage. Appears a gear is broken in the turn mechanism. Machine is analog.
  • ctomasin May 26, 2009
    It is the turn gear.
  • 30 Answers
Hi,where the paper stop?is your machine analoge or digtal?
Posted on May 21, 2009
  • Amanuel Tsige May 25, 2009
    hi,check fuser section especially web roll.if the web is damage replace by new one.cleared any misfeed sheet in fuser section.send me a result.
    thank you.
We have the xerox 560 printer and when using 11x17 tabloid paper the machine jams, pulls 2 sheets and seems to overheat. Any suggestions on what we could be doing wrong?
Not sure about his model but on most Xerox next to the feed wheel which need to be clean and good, there is a oneway clutch on the same shaft, either clean with alchol (rubbing) or replace. Again this maynot apply to this model. Also check settings for correct size of paper in paper set up menu.
Jul 23, 2014 | Office Equipment & Supplies
I have a Xerox Copier XC1045. Our copies are coming out with dark spot on the paper., I change the drum, but still have same problem, even big area has black spot
You may have a worn out heat roller in the fuser.
It is also likely you have a bad toner cartridge . If the spots are gritty then replace the toner cartridge and vacuum out the machine,
Aug 11, 2010 | Xerox 5665 Copier
Xerox XD100 paper jamming every time.
The fuser is the problem. Most likely the fuser will need to be rebuilt or replaced.
Google a business called The Parts Drop. they have either the parts or the unit.
You may just have to take the fuser out and remove a badly jammed piece of paper in that module.
Shut the machine off for a half an hour. Remove the back cover. You will then see on the left side a black plastic bracket with 3 plugs on it. Disconnect those 3 plugs. Then open the right side door and toward the top is the fuser. It has yellow caution HOT labels on it. There are 2 silver phillips screws holding it in. Remove the screws and then remove the fuser unit and see if there is a paper in there. There are 2 screws that you can remove and the fuser will kind of fold open to inspect for bent fingers or one out of place.
Mar 30, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox phaser 8400 will not feed paper on either tray.
I am going to assume something here. That the paper does get out of the tray just an inch or 2 correct?
If so, the registration clutch is bad, it is really common.
You can do one of two things. If you go onto the Xerox.com site you can find the parts list for the machine and get the part number.
If the machine is feeding the paper out of the trays just a couple of inches and stops, you can call 1-800-835-6100 and follow the prompts to order parts. Tell them you want a registration clutch for a Phaser 8400 and they will look it up and send it to you.
If so. Just E-mail me at rak458@aol.com and I will send you directions on how to change it. It really is an easy clutch to replace. Even if you never have changed one, I would doubt it would take a half an hour to change start to finish.
Dec 07, 2009 | Xerox Phaser 8400 Laser Printer
E2 error code on Xerox work centre xd series 120f copier
e2 is a paper jam problem. check that the paper guides in the cassette are positioned aginst the paper properly. Also remove the toner and drum cartridge. Clean all rubber rollers that you can get to with a damp cloth ( water). You are especially trying to clean the upper and lower registration rollers that "pinch" the paper. I hope that this helps.
Nov 05, 2009 | Xerox Office Equipment & Supplies
Copier too dark
Did you clean the lens and the mirror under the lens cover? If so, There is a VR behind the front cover of most small Xerox machines. One VR makes the image darker/lighter and one VR changes the lead edge registration.
Dec 11, 2008 | Office Equipment & Supplies
Xerox xc1045 copier machine
If it starts to make a copy and the light comes on then stops in the middle there is a problem w/the connection.
check the cable that turns on the light it may have a cut and is not making contact in a particular spot. If not then it may be the board that controls the lamp.
Oct 17, 2008 | Xerox 5665 Copier
Problem printing 1m long paper on 7760
If your driver setting is not set to the proper paper size it will not fuse the entire page.
What you seem to have is a simple setting problem either the machine of the print driver are not set to the correct length shutting the fuser off.
You could have a failed fuser, but if the first half is fine, you have a setting incorrect.
Dec 19, 2007 | Xerox Phaser 7700 Laser Printer
202 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
