Question about Boss ME 70 Electric Guitar Effects Pedal Processor
My boss ME 70 wont turn on
Hey, i've plugged my me 70 into the wall, i've plugged my guitar into the guitar input and i've plugged my amp into the MONO output. and when i try to turn everything on, nothing happens. the amp turns on but theres no lights or sound from the me 70.
    Scholar:
  • 52 Answers
Sounds like a bad AC adapter. Companies use the brick style adapters that plug in the wall to keep noise out of the circuitry, and isolate the power by using the adapter. Chances are you have a bad one. Read the adapters' label and try to find the best match. Make sure to check the amperage rating -A- and if it is AC or DC, and the voltage. You need to have the closest rating to all of that not to damage the pedal.
If the adapter isn't the problem,the only other thought is there may be an internal fuse blown on the unit. Refer to your manual, or consult a repair service.
Posted on May 30, 2014
My Boss ME-70 han only two dots when i power on ,pedals dont lit when i press it down, is there a solution with this?
PDF]BOSS ME-70 Training Guide - Roland
cdn.roland.com/assets/media/pdf/ME-70_Training_Guide.pdf
AC adaptor. • $418.50 List, $299 MAP ... Connect the ME-70 to power using a BOSSPSA-120S AC Adaptor. 4. Plug a guitar into the ... For illustration only ). 4. Press the ...1. Turn the MODULATION TYPE knob to select a Modulation effect. Do not ... 2. Pressboth pedals down again or press EXIT to return to Manual Mode.Missing: han ‎dots
ME-25 Guitar Multiple Effects Review ' Boss ' Guitar Effects ...
https://www.ultimate-guitar.com/.../boss/me-25_...
Ultimate Guitar Archive
Rating: 8.6/10 - ‎135 votes
Sep 16, 2015 - Overall the effects are very very full sounding and don't sound too digital by any means. ... With 2 selector pedals, up and down, its a pain in the ? ... Editing the patch is as simple as press 2 buttons at the same time and turning ... If this was stolen I would probably get the ME-70 just because it pretty much ...
Tom Scholz's Guitar Sound - Van Halen Links.com
Jan 06, 2016 | Roland Boss ME-70 Guitar Multiple Effects...
Boss ME-70 distortion changing mid play why.
Is distortion changes like we turn the OD/DS selector (changes to Boost-Natural-OD1-Blues etc)?
If so, the OD/DS potentiometer need to replace.24346541-2ss5ycyvkoajtv035dpuezke-4-0.jpg
If the changes are like increasing/decreasing GAIN/BASS/MID/TREBLE/LEVEL and also TYPE of pre-amp, then one of PREAMP potentiometer is bad.24346541-2ss5ycyvkoajtv035dpuezke-4-1.jpg
May 06, 2014 | Boss ME-70 Guitar Multiple Effects Pedal
How do I factory reset a BOSS ME-70 effects pedal
press pedals 3 & 4 at the same time to swtich to Manual Mode. Hold down EDIT/EXIT and press the MOD pedal. Press WRITE twice.
Sep 04, 2011 | Boss ME-70 Guitar Multiple Effects Pedal
I actually use boss ml 2.. it works just fine for the past few month. but all of a sudden now. its just wont work. i even change the batteries. what happen was. while i was playing. it suddenly shuts off...
The first thing I would do would try a 9V AC Adapter to rule out a battery issue completely. But if you have changed the battery already, this shouldn't be the issue. Does the red light come on at all? The next thing I would check involves removing the back cover of the pedal and making sure the input/output jacks are okay. Do you see any hanging wires, loose solder, or smell a burnt smell? If you have only had this pedal for a few months, you may be able to send it back to BOSS for replacement under your warranty.
Mar 04, 2011 | Boss Mt 2 Metal Zone Effects Pedal
How do plug your guitar into the boss rv3 which jacks
Plug your guitar into the input and a cord from one or both outputs to the inputs of whatever you are using. Meant to be run in stereo for best sound. Two guitar amps?
Sep 24, 2010 | BOSS AUDIO SYSTEMS Boss Rv 5 Digital...
I have a Fender G-DEC Guitar amp and it has an output for recording, can I connect it to the BOSS MICRO guitar input? The Fender amp has many rhythm functions which I am very familar with, besides it has...
you can use the line in/mic stereo input, but you will have to turn the input level way down to around 1 or 2.
i assume that the record outputd a re rca outs. you can get a rca stereo to 1/8 inch stereo adapter, like the ones they use to connect protable cd palyers to recievers, and then get a 1/8 inch stereo to 1/4 inch stereo adapter form radio shack to complete the connection.
Aug 15, 2010 | Boss Micro BR Digital Recorder
My MT-2 wont distort my guitar.
A few things to try....
Usually the adapter will over ride the battery when used.
1) Make sure your 1/4" cables are working properly without the pedal "in-line".
2) Take out battery, and use just the adapter only. Make sure it is the correct and proper adapter that works with Boss. Usually the PSA-120. If you are not using a Boss Adapter, make sure yours is a direct replacement with same specifications. 9V/200mA. And "tip negative". DO NOT use Radio Shack stuff, nothing against them, but there adapters just don't mix well with Boss products and the like.
2) Try just the battery, no AC adapter. Remember to unplug the input when not in use. Saves battery.
Basic rule of thumb...when using correct AC adapters for all your pedals all the time, and all sounds good, then take out the batteries.
If you still experience problems, it would be an internal IC chip most likely. From there post another question maybe.
Apr 01, 2010 | Boss Mt 2 Metal Zone Effects Pedal
How to set up with amp and distortion pedal
With everything switched off. I will surmise that you are using the onboard battery with the foot pedal and not a power supply.
1. Plug lead from guitar/instrument into INPUT side of pedal
2. Plug lead from OUTPUT side of pedal into amplifier INPUT.
3. Turn amplifier volume to about 10 o'clock - to stop blowing your ears out.
4. Turn volume up on guitar to acceptable level.
5. press foot switch on pedal and adjust pedal controls to suit your type of distortion.
6. Play like Hendrix.
Good Luck
ps Just as an after thought rechargeable 9volt batteries are the way to go. I've been using them for years as I always get caught up in the power cable.
If you're going to add another pedal like a Phaser, Compressor, Flanger or what just use small connect leads between each pedal but always, always put the compressor pedal last in the line.
Sep 12, 2009 | BOSS AUDIO SYSTEMS Boss Ns2 Noise...
The proper way of setting up a foot board to my amp and guitar
Run a jack from your guitar to Input R Mono on the pedal.
Run a jack from Output R Mono on the pedal to the input of your amplifier.
There is a switch for guitar or Bass. Put the swich on guitar
You do not need a preamp to use this pedal.
Hope this helps,
Maxx.
Aug 27, 2008 | Boss Music
Boss ME 70 Electric Guitar Effects Pedal Processor Logo
1,124 people viewed this question
Top Boss Audio Players & Recorders Experts
J.D. Browning
J.D. Browning
Ron Jeremy
Sam Piasecki
Sam Piasecki
Level 1 Expert
Are you a Boss Audio Player and Recorder Expert? Answer questions, earn points and help others
