I'm trying to install sims 3 on my laptop? at the end of the installation i get this message: microsoft WSE 3.0 X509 certificate tool has stopped working Description: Stopped working Problem signat
I dont have much space on my drive C
By mistake, I have uninstalled Kodak Easy Share software from my laptop! Now, when I try to re-install the same from my installation disc it stops in the middle rendering error code: 12x58x0x! If poss
hello
please, try to restore your pc to any date before uninstallation date.
if you have windows 7 fellow these steps:
1- go to : start/All programs/Accessoires/System Tools/System Restore
2- click next
3- choose one dates before unistallation and click next
4- fellow the steps to the end
good luck
Dec 24, 2013 | Computers & Internet
I AM NOT ANY SOFTWARE INSTALL MY NOKIA N73. BECAUSE CERTIFICATION ERROR
format your n73.
Formating method.
1. Switch your n73
2. Now "press and hold" the three buttons(call, *,3)
3. Switch on your phone by holding the 3 switches.
Its working..
Sep 22, 2011 | Nokia N73 Cellular Phone
Certificate error on web site.
This is basically an Internet Explorer 7 Website’s Security Certificate problem! You have to self-sign the certificate on the client computer or add the URL manually to the trusted security zone. When you are trying to access a secure web page, you receive the warning message:
"There is a problem with this website's security certificate. The security certificate presented by this website was not issued by a trusted certificate authority."
Or
"Security certificate problems may indicate an attempt to fool you or intercept data you send to the server."
To fix this issue, you can follow either of the methods:
Method 1:
You have to install the Microsoft Windows Small Business Server 2003 (Windows SBS) self-signed certificate on the client computer. To do this, follow these steps:
  • In Windows Internet Explorer 7, click Continue to this website (not recommended).
A red Address Bar and a certificate warning appear.
  • Click Certificate Error button to open the information window.
  • Click View Certificates > click Install Certificate.
  • Click Yes, to install the certificate, when warning message appear.
Note: For Windows Vista users, right click on Internet Explorer icon. Select Run as Administrator.
Back to top
Method 2:
Add the URL to the Trusted Sites security zone:
  • Open Internet Explorer
  • Go to Menu bar > Tools > Internet Options.
  • Click Security > Trusted sites > Sites
  • Type the URL in the Add this website to the zone text box > uncheck Require server verification >Add > click OK
  • Click OK to exit.
Now you have added the URL successfully into the Trusted Sites security zone.
Jul 16, 2010 | Dell Computers & Internet
Abut certificate error i n73
Do the following:
  1. Open the Application manager by selecting Menu > Installations (or Applications orApps. or Ctrl.panel or Tools) > App.mgr.
  2. Select Options > Settings.
  3. Set Software installation to All and Online certificate (or certif.) check to Off.
  4. Retry the installation again.
Jun 09, 2010 | Nokia N73 Cellular Phone
Wont install on xp message saying it is not windows authorised?
Make sure that the version of the software you are trying to install is the Windows XP version and is obtained from a reliable (manufacturer) source: just ignore the message you are getting about 'software is not microsoft certified' or some other message of that nature and allow it to be installed: a lot of third party software are not submitted to Microsoft for certification as a cost saving measure or as to not have to rely on Microsoft certification timeline.
ps. As a preventative measure, pre-check this non-certified software with an antivirusantispyware scanner if you are not running a real-time scanner (eg. always on).
Dec 25, 2009 | LG Shine (CU720) Cell Phone
How to fix remote connection?
It depends on the problem you are having.
Most often remote connection problems are caused by firewalls
Are you trying to connect across the internet or are your two machines on the same LAN.
Are you only running windows firwall or do you have a third party firewall installed.
I suggest you run off the firewalls first and try to connect on the LAN and then add things back in one at a time until you solve the problem.
There may be more than one thing blocking you.
I hope this helps
Sep 10, 2009 | Microsoft Windows XP Professional
Visual studio instalation problem
just take a look to this site:
http://www.codeproject.com/
you will get your answer there easily.enjoy it!
Feb 23, 2009 | Microsoft Visual Studio® 2005 Professional...
Certificate error I cannot get into any email accounts
Please perform the following steps.
This error message appears because the security certificate was issued by the University itself and not by an authority acknowledged by Microsoft.
To solve this problem, for most webpages you just have to install the "CA Certificate" of Ghent University in your browser.
For certain websites, such as https://zephyr.ugent.be, you need to import its own certificate:
Click on "Certificate Error" next to the IE7 address bar and then "View certificates"
Click on "Install certificate..."
Click "Next"
You will be asked where the certificate has to be stored. You can use the default setting and click "Next".
Click "Finish"
Confirm by clicking "Yes"
On your next visit, you will not see the error message again. Hopefully it should work.. Thank you
Sep 13, 2008 | Computers & Internet
Themes wont install
try to download compatible themes for your mobile from zedge.net or ownskin.com your work is done directly
Apr 13, 2008 | Nokia 6120
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
