Question about Biostar Mb, Mb-8500tac-a Ver.5
Flash rom battery location mb-8500tac - Biostar Mb, Mb-8500tac-a Ver.5
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Biostar Master
  • 2,226 Answers
Your cmos battery is the size of a nickle
Posted on Jan 12, 2014
How to Flash stock rom on Alcatel one touch 7042
I think that you had better use Sp tool because it is simple and Huawei Mate S Stock Rom is MTK Device
1. you should charge your device up to 50%
2. enable USB debugging and developer.
3, remove battery and connect your phone to PC
4.Download Sp tool and Stock Rom
5, Open SP tool. Locate the catter file.
6. Click the Download icon then it will start Flashing
Download required files -
Install Stock Rom on Alcatel One Touch 7042a
Feb 05, 2017 | Alcatel Cell Phones
How to Flash Huawei Mate S new Stock Rom
You bricked the phone. That is one of the risks with flashing a phone. Phone is junk now. No way to fix it.
Aug 18, 2016 | Huawei Cell Phones
1005ha bios update usb
Upgrading BIOS is dangerous and can cause fatal damage to your PC. If you are aware of that and decide to take this risk, then continute. 1. Visit http://support.asus.com/download/download.aspx?SLanguage=en-us, search 1001HA and choose DOS as operating system. Download latest bios rom file.
2. Save and extract the downloaded file. You will get a rom file named like "1301.rom" 3. Format a usb pen drive to FAT-16 partition. In my case I used a 32 MB SD card which came with my old Kodak camera, and I used a SD card reader that PC can see it as a usb disk. Copy 1301.rom to its root folder and rename it to 1005HA.ROM. The reason for renaming it to 1005HA.ROM is that EZ Flash on this 1001HA netbook looks up rom with this name. If EZ flash failed saying trying to find a rom file with another name, just shutdown the netbook and rename your rom file to the required name and try again. 4. Plug in the usb pen drive and reboot the netbook. Make sure that during the ASUS splash screen, press ALT+F2. Then EZ Flash will run automatically and try to locate the usb drive and read from file 1005HA.ROM (in my case). 5. It takes around one minute for me to upgrade everything. DO NOT TURN OFF OR EVEN TOUCH YOUR NETBOOK DURING UPGRADE. Read the messages on the screen and when it says you can press the shutdown button, you can turn off your system. 6. Turn on your netbook again and enter BIOS to check if the BIOS version is up to date.
http://www.youtube.com/watch?v=61awfpVe49k&feature=player_detailpage
Jun 11, 2012 | ASUS Eee PC 1005HA Atom N270 TFT Notebook
Flash: compactFlash not present
Please check the below point and revert if any queries
  • Default/maximum:32 MB/128 MB compact flash,128 MB/384 MB synchronous dynamic RAM (SDRAM)
  • The Cisco 1841 Router has a single, external compact flash memory. This is the only flash memory for the system and should never be removed whenever ROM Monitor (ROMMON) is being updated with a new image or configurations or when the compact flash LED light "busy" is on.
Feb 02, 2011 | Cisco (1841) Router (cisco1841)
Flash: CompactFlash not present I am getting above error when i power on a cisco 1841 router
Sep 20, 2010 | Cisco (1841) Router (cisco1841)
I was traing to flash my bios on MB GA-7VA and fail !!!
> is there some way to put new BIOS?
Yes -- details are on Gigabyte's web-site.
> Is BIOS chip removable?
Yes -- but you'll need special hardware, a "ROM programmer" to load a new BIOS onto the chip.
Jan 20, 2010 | Intel Motherboard
Does the HP 1350 support 4gb MicroSDHC
Memory, std.
2 MB ROM, 16 MB RAM
Memory, max.
2 MB ROM, 16 MB RAM Memory, std.
2 MB ROM, 16 MB RAM
Memory, max.
2 MB ROM, 16 MB RAM Here are the specs:
http://h10010.www1.hp.com/wwpc/us/en/sm/WF06b/18972-238444-410635-12085-f57-306884-306889-306890.html
Nov 30, 2009 | HP PSC 1350 All-In-One Thermal Printer
Canoscan Setup Utility CD-ROM missing
How can i install my canonscan 20 without the cd rom
Sep 07, 2008 | Office Equipment & Supplies
Need specs on ax6b mb
CPU: Intel Pentium III / Intel Pentium II / Intel Celeron slot1
ASIC: Intel 440BX AGP set
Architecture: 3 xISA slots + 4 x PCI slots + 1 x AGP slos
Max. Memory: 1 GB SDRAM for DIMMx 4
DIMM Type: 8/16/32/64/128/256 MB
BIOS: AWARD plug-n-play flash ROM BIOS
On Board I/O:
2 serial ports (UART 16C550 supported)
1 parallel port (SPP/EPP/ECP supported).
2 floppy drive supported (1.2/1.44./2.88 MB)
2-channel IDE (PIO Mode 4 and ultra DMA/33 bus master supported)
2 USB ports supported (universal serial bus)
1 PS/2 Mouse Port
1 PS/2 Keyboard Port
On Board SCSI: Adaptec AHA-7880P ultra wide SCSI controller
SCSI Port: 68-pin wide SCSI and 50-pin FAST SCSI connector yes
Battery: 3V lithium battery
Green Function: Yes
Connector: IrDA, Wake On LAN, SB-LINK,Wake On Modem
Board Size: 244 mm x 305 mm, ATX form factor
Apr 13, 2008 | Computers & Internet
Rx3715 several problems
If you have only flashed the English ROM, not any other language ROMs, read the following paragraphs. If you have flashed other language ROMs but not the German one try flashing the German one instead, there is something about it that clears the ppc out better. If you have flashed the German one, do not read on, as it will be an insult to your intelligence.
Most problems can be fixed with a ROM correction. Unfortunately, this is unachievable by simple re-flashing the English ROM. Certain other versions of the ROM (usually German is used) contain different enough sets of code (possibly different firmware?) to force the ppc to truly reset, unlike what happens when simply flashing the US ROM or changing to ROMS that use similar enough coding. Try flashing the German ROM and THEN reverting to the English. This tends to solve most any major iPaq issue.
Refer to
http://www.fixya.com/support/t395941-display_operating_difficulties
For full instruction.
Jan 26, 2007 | HP iPAQ RX3715 Pocket PC
Biostar Mb, Mb-8500tac-a Ver.5 Logo
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
