Question about HP Computers & Internet
Remove bios password
When i turn laptop onit boots up then goes to a black screen with a blue banner asking for a password i have restarted it and tried getting into bios and can't it just goes back to password screen i bought it used and it came like this so i have no way of knowing password what can i do to unlock laptop
  • 3 Answers
There should be a factory procedure for this. Anybody that can help You need to know first the brand and exact model of your computer to search for the right procedure.
Posted on Dec 25, 2013
2 Suggested Answers
  • 84 Answers
SOURCE: laptop screen goes dark after booting .
your issue with your laptop is a faulty ccfl BackLight Inverter, the display uses the backlight to illuminate the lcd screen, the inverter is used to illuminate the cold cathode light in the back of ther lcd theirs countless places to laern about it on google.
They are cheap to replace google your model with inverter at the end..
They are not too hard to replace
Posted on Aug 20, 2009
When i turn my d257 acer aspire one on it goes to blue screen asking for a password, or it either goes to a screen that says no boot disk
No Boot disk found - usually indicates the HDD is not located.
so you need to validate the HDD is inserted properly, and locked into the HDD slot. securely,
Blue Screen asking for password, could mean several things,
basically you need with both errors, take to a good Repair Tech and have this looked into... PASSWORD can be either for BIOs or HDD,
or the system went into LOCKED MODE and password is needed to UNLOCK it.
Mar 03, 2015 | Acer Aspire One D257 Netbook
Black screen blue box saying
some one must have put in a boot password to your laptop,
follow this:
When booting up, enter your BIOS setup (usually by pressing the F2 key at the appropriate time).
Locate the BIOS Password section and turn the ON STARTUP password to off. There is no standard setup for BIOS, so I can't give you exact instructions.
If this does not work, try:
remove cell & start your pc you will here beep...beep...beep...
then turn off your pc & restore your cell.Start your pc and
password is removed.
there is a battery on motherboard,a button cell,you can try removing that and start computer, then put it back, bios settings will be lost.
you can also try removing any hardware like ram,if you have two,when system is off,turn on , it will prompt for changes , enter bios and try remove password.
Dec 15, 2013 | Gateway LT2001u Netbook
Toshiba laptop c660d-152 showing black screen asking for password
check whwther you have set password while booting if so enter bios pw
Dec 09, 2012 | Toshiba Satellite L455-S5009 laptop
Sony f series missing BOOTMGR
Bootmgr is missing - Vista, Windows 7
Go to this WEB site for instructions to fix this problem
http://pcsupport.about.com/od/findbyerrormessage/a/bootmgr-is-missing.htm
Jul 21, 2012 | Acer Aspire Computers & Internet
When I turn the laptop on I see the Toshiba screen for just a second and then it instantly goes to this lovely black screen that says password= How this got there I have know idea. Can anyone help?
Dear beanbean,
This "lovely black screen" is a BIOS password screen. This shows up because somebody has set a boot-up password in the BIOS Setup. If you're lucky, the BIOS Setup is still unprotected, and you can access it as follows:
When you turn it on, look for something that says "Press [button] to enter Setup" or "Press [button] to enter Setup Utilities." Press the corresponding button on your keyboard, and you should enter BIOS Setup.
Now two things can happen. Either you are permitted to access Setup, or you are prompted for the password.
If you can access Setup, navigate to the Security tab and clear all set passwords.If not... then you can either reset BIOS by unplugging the computer, taking off the back, and removing the CMOS Battery (unrecommended), or you can call Toshiba support and ask for the master password (Most manufacturers have a master password, which will allow you to access Setup and remove the boot-up password)
Hope this helps,Ericthecmh
Sep 13, 2011 | Toshiba Satellite A105 Notebook
My son was messing with my laptop and now when i turn it on, it is a blue screen and asks for a password. (bios password). He claims he didnt put this on the laptop. So, how can i get the password or...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
Also you might try
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
now for the password
http://majorgeeks.com/download.php?det=5710
UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password
you will have to burn it to a disk as an ISO then you will have to boot from the disc During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed your password you will have change first boot back to your hard drive) Hope this helps
Apr 16, 2011 | Computers & Internet
Black screen with blue box asking for password
that happened to my hp....some kid came to my house and stayed for the weekend...i don't know what the heck he did but i have a blue box as well and the password happens to be "password"....i don't know how i figured it out either...try it...it could work for yours as well!!! I would like to know how to get rid of it
Oct 28, 2009 | Dell Inspiron 1000 Notebook
Blank screen. Blue box that says enter password....no idea.
Well, someone if not you- have enabled BIOS password.. So, u better start asking around whoever it maybe.. :) Good luck..
Jul 21, 2009 | Toshiba Satellite A135-S2276 Notebook
Asking Password on booting laptop
this is problem regarding hard disk or ram error pls change the hardisk
Apr 02, 2009 | Computers & Internet
My laptop will not boot up. It goes to a black screen with a blue box in the middle and it asks for a password
now I think I have a solution
bypass a BIOS password. to try on of these standard manufacturer's backdoor passwords:
AWARD BIOS:
AWARD SW, AWARD_SW, Award SW, AWARD PW, _award, awkward, J64, j256, j262, j332, j322, 01322222, 589589, 589721, 595595, 598598, HLT, SER, SKY_FOX, aLLy, aLLY, Condo, CONCAT, TTPTHA, aPAf, HLT, KDD, ZBAAACA, ZAAADA, ZJAAADC, djonet, %øåñòü ïpîáåëîâ%, %äåâÿòü ïpîáåëîâ%
AMI BIOS:
AMI, A.M.I., AMI SW, AMI_SW, BIOS, PASSWORD, HEWITT RAND, Oder
Other passwords you may try (for AMI/AWARD or other BIOSes)
LKWPETER, lkwpeter, BIOSTAR, biostar, BIOSSTAR, biosstar, ALFAROME, Syxz, Wodj
hope it will help. If some of the codes work, let me know and I will tell you how to remove it.
CS :)
May 15, 2008 | Computers & Internet
Computers & Internet Logo
46 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
