Question about WoodMaster 5500 Super Duty Wood Furnace
Fan is not kicking on
The fan motor is not kicking on
Have an intertherm split system. Outside condenser compressor is starting, can hear freon flowing, but fan motor will not kick in. Gets hot then kicks breaker. Have replaced capacitor with factory part.
If that system is gas heat then you have 2 fan speeds Lo speed for heat and when ac is called for the motor speed shifts to hi with the use of a fan relay.
Some various fan relays in use today. themobilian_2285.jpgthemobilian_2286.jpg
May 02, 2011 | Heating & Cooling
Electrical fans wont kick on, car will run hot if they dont kick in..Tried changing fuses still wont come on..
The fans have a seperate temperature sensor either in the radiator or the block. Follow the fan wires to locate this sensor and unplug the sensor and with the key on touch the wires together. If the sending unit is bad the fans will come on. If the sending unit works the fan motor is bad.
Jan 19, 2010 | 1995 Chevrolet Impala
Air on heat pump not cool outside unit humming but not kicking on
This could be an inoperative condenser fan.System will kick off on high pressure without proper air flow.The hum indicates voltage is present. Providing the fan motor is not locked up and will spin,Check your run capacitor which helps boost the motor voltage initially and will get it turning.If the cap is good,you may be faced with motor replacement....good luck
Aug 19, 2009 | Carrier 38CKC042 Air Conditioner
Fan kicks on but
motor mount loose, fan grate loose, fan off balance, or the motor bearings could be wearing out. put your hand on the top of the motor grate. if by you putting your hand on it the buzzing stops, the hardware may need tightening. if it vibrates violently, the fan is off balance or the motor bearings are worn. if the blades are bent, you may be able to bend them back. if the bearings are shot, you need a new motor.
Aug 07, 2009 | Heating & Cooling
Kenmore a/c window unit fan not kicking on with compressor.
Likely a bad motor, when this occurs verify the board is sending voltage to the motor.
May 30, 2017 | Kenmore Heating & Cooling
Shuts down when fan kicks on
if it kicks out right away then it sounds like your fan motor is defective or possibly if the motor has a capacitor it could be defective,also does your receptacle have the ampacity to handle the unit?
May 14, 2009 | Reddy Heater-30-55,000 BTU Variable
WoodMaster 5500 Super Duty Wood Furnace Logo
Top WoodMaster Home Experts
john h
Tom Chichester
Are you a WoodMaster Home Expert? Answer questions, earn points and help others
