Question about Yamaha RX-V671 7 Channel AV Receiver - Black
Marantz sr7300 protect - Yamaha RX-V671 7 Channel AV Receiver - Black
Why marantz receiver 2328b sterophinc shut down?
Protective circuits have shut down unit to protect other wiring. Probably a power supply or out put amp issue.
Mar 09, 2015 | Marantz Audio Players & Recorders
How do i get my Marantz AVSR3053 out of protection mode?
Protection mode usually means there is a problem in the amplifier circuitry. You will need to have the unit checked by an authorized tech if the unit is under warranty.
Feb 19, 2015 | Marantz Audio Players & Recorders
How to reset marantz sr4001 from protect mode?
Protect mode comes into play when there is a problem with the speakers or amplifier First check all the speakers for opens or shorts If they are fine you don't reset it you repair the receiver.
Aug 07, 2014 | Marantz Audio Players & Recorders
Marantz sr8000
Check protection circuit, check transistor going to protection relay
Dec 22, 2013 | Marantz Audio Players & Recorders
Protect error on marantz sr4200
Check all your speaker wires carefully. Chances are good that a braid has crossed from + to - and causes the unit to protect itself. This is a very common problem! everyone's done it at some point. Check connections at both the receiver side and the speaker side. If you still have a problem, post a comment and I can help you troubleshoot further. Hope this helps.
Sep 27, 2009 | Marantz SR7500
One speaker channel is crackly.
There is Definately a Short in the Amp if tapping Fixes it. Could try opening the amp and Inspecting the Back side of the Terminals. You can use a Voltometer and check the Wiring inside. Turn off Power Before doing this!
Jan 01, 2009 | Marantz Audio Players & Recorders
Marantz sr 500 going to "protect" mode when on.
Change the audio amplifiers IC´s because are on short circuit
Oct 02, 2008 | Marantz SR-7200 Receiver
Receiver will not turn on
It is probably shorted out. the fact that you hear a relay click is bad news for you. Take it in and tell them that you cannot get power from the switch through to the main board.
Jul 26, 2007 | Marantz SR-7300 6.1 Channels Receiver
Yamaha RX-V671 7 Channel AV Receiver - Black Logo
59 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
