Question about BenQ Rl2450ht 24 Class Widescreen Led Backlit Gaming Monitor 1920 x 10
Ps3 rl2450ht out of range - BenQ Rl2450ht 24 Class Widescreen Led Backlit Gaming Monitor 1920 x 10
My headset keep disconnecting and saying not in range when I'm beside my ps3
You may have too many devices connected to either the headset or the PS3. Try removing the associations from both then re-pairing only the headset you wish with the PS3.
Jun 01, 2014 | Radio Communications
My ps3 system won't stay online. I have to always
Yes you may need to pick up a new wifi range extender because it sounds like it's almost burned out.
May 15, 2012 | Sony Video Game Consoles & Games
My ps3 wont work on my sony tv it comes up with out of range
better u download repair guide
click here to download ps3 repair guide
Dec 16, 2010 | Sony Playstation 3 (PS3) Console
Ps3 frequency out of range
This model will only support 1080i. What you need to do is go into the display settings on your PS3 and set the max resolution that your TV will support to "1080i" That should get you going!
May 19, 2010 | Sony VPL-HS51A / VPL-HS60 Multimedia...
"out of range" when connecting ps3 -> benq t221w
It display out off range because the PS3 is feeding the monitor with higher resolution that the monitor cannot suppoert, try setting the PS3 to the lowest resolution first and go up from there.
http://s807.photobucket.com/home/budm/allalbums
May 18, 2010 | BenQ T221W Monitor
What connections are needed to hookup the ps3 to the internet?
You can either hook up your PS3 through hard wire using an ethernet cable plugged into your PS3 and your modem or wireless since the PS3 has a built in wi - fi adapter for the wireless network in range.
May 12, 2010 | Sony Playstation 3 (PS3) Console
Out of range
Right i'm halfway to understanding what's going on.
It sounds like your ps3 is readjusting the resolution to something the new tv isn't compatible with.
Looking at the t.v (bravia v4000), it should be compatible with all resolutions upto 1080p.
What happens when you turn the ps3 on initially (plugged into the new tv) ? It doesn't go straight into the game, so what happens and what boxes in the display settings do you have the resolution set to?
You should only have 720p and 1080p ticked.
The 40v4000 supports 1080p so when the PS3 auto-detected the display settings it set the XMB to 1080p, the 32v4000 supports 720p but the PS3 still thinks its connected to the 40v4000 so it is trying to output 1080p which is out range of the 32v4000. Go to the display settings on the PS3 and auto-detect the display settings again
Feb 13, 2010 | Sony Playstation 3 (PS3) Console
Ps3 to gateway fdp1760 frequency out of range dvi to hdmi cable
what Frequency is the monitor set to run at ? u will get that mesg whan the monitor is receiving a signal that is greater than what it can handle say ur monitor can take 1024x768@60hz from ur PC and maybee ur PS3 is sending 720x720@100hz so ur monitor can handle the resolution but not the refresh rate that would be why u get that message
Mar 07, 2009 | Sony Playstation 3 (PS3) Console
Rande extender issues for ps3
Both your neighbor's router and your range extender must be set to use exactly the same SSID, encryption key and FIXED channel assigment.
Dec 09, 2008 | D-Link AirPlus G Wireless Range Extender...
Cant remember ps3 password or e-mail add
The only way to find out ps3 password is hacking into it with brute force attack.
The only simple way to get your password back is calling sony, you get the phone number in your PS3 documentation.
Sep 15, 2008 | Sony Playstation 3 (PS3) Console
BenQ Rl2450ht 24 Class Widescreen Led Backlit Gaming Monitor 1920 x 10 Logo
18 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
