Question about Polaroid Audio Players & Recorders
Polaroid pmp76bgl how to connect to computer
Setting on charger for a Polaroid tablet, 6V, 12V, Help
Not sure of the model number of your polaroid tablet you have. Generally the adapter should be an AC adapter for 220V or 110V depending on country. It is unlikely you will have to select 6v or 12v. If you are unsure charge the tablet through the USB cable connected to a computer. It might take a bit longer to charge and make sure the computer is connected to mains charger to avoid drain on computer (laptop, etc) battery.
If you have a 7" tablet then I am assuming it is a PMID705. See manual on this link.
http://www.southerntelecom.com/upload/polaroid/pmid705/PMID705_User_Manual_20121210.pdf
The manual says it is a 5v DC output connector for the adapter. Not sure why you are asking the question. If in doubt send email to polaroid support on the address at end of the attached manual.
Sep 19, 2014 | Polaroid 7-in. Internet Tablet - Other
I737 Polaroid camera
You don't need the Polaroid software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Apr 25, 2012 | Polaroid T730 Digital Camera
I have a polaroid i1036 and am trying to download to my pc. The camera recognizes the computer connection, but nothing is activated to download the pictures. I am running Windows XP. The polaroid disc...
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Dec 13, 2010 | Polaroid i1036 Digital Camera
Plug in polaroid t831 to pc and pc doesn't recognise that it is there
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
May 20, 2010 | Polaroid T831 Digital Camera
Hi, all of the sudden my polaroid i633 wont le...
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
May 20, 2010 | Polaroid i633 Digital Camera
Use as a computer monitor?
The Polaroid TLX01511C 16" Class (15.4" Diagonal) is capable of receiving audio and video signal in ATSC and NTSC systems. With the host computer, use as the display terminal and connect the 3.5mm (diameter) audio cord to your computer’s audio main board so you can listen to music from your host computer through the Polaroid TLX01511C.
Mar 02, 2010 | Polaroid TLX-01511C LCD TV
Lost installation CD
Do you really need the Polaroid software?
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
Jun 23, 2008 | Polaroid i532 Digital Camera
I need to download software for my camera to my laptop.
Go to www.polaroid.com
select your country
click support
enter your model number - i531
click the picture of the i531 camera
under get software, click i531 Driver
click download now
save to your machine & install
Jun 17, 2008 | Polaroid i531 Digital Camera
93 people viewed this question
Top Polaroid Audio Players & Recorders Experts
Owen Barnes
Are you a Polaroid Audio Player and Recorder Expert? Answer questions, earn points and help others
