Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
Long cycles seems like long cycles
  • Official Brand Answer
  • 4,342 Answers
Hello Shawn, thank you for your question!
If your dishwasher is taking too long to complete a cycle, first you need to make sure the water is 120F at the sink. If water is less than 120F it causes a delay in the performance and advancement of the timer until proper water temperature is reached. Run the sink to its hottest point, start a "pots and pans wash cycle". If that cycle runs over 4 hours, then I recommend reaching out to a service technician since more than likely the issue lies with the control board. If it runs under 4 hours it is possibly fine, it is only heat delays causing it to run so long.
Hope this helps!
Posted on Jan 03, 2014
The knob just spins round and doesn't catch. It received a bash and it now won't accept a wash cycle. Any thoughts?
It seems that the timer has failed and needs a replacement. If this seems to turn around without clicking and if there is no action when the program cycle is initiated, this seems a failure of the timer controller unit. This happens in cases when it is turned around in reverse order or violently.
Jan 14, 2013 | Zanussi Washing Machines
This is my Model # WTW57ESVW1 In the normal wash cycle, the timing seems off. When you first turn it you can hear the water but it also seems the agitator is already going and at the end of the cycle when...
Seems possible that the program controller is not working in order of the sequence that is required of the program.
So you must check the connection contacts, clean and try if this helps or else a new controller might be necessary as many of them develop bad contacts on usage..
Check cost , if possible swap and confirm before you buy one to fix.
Oct 11, 2010 | Washing Machines
Cycles randomly change electronic panel seems to
I am having the same issue. It randomly cycles back and forth between cycles and never shuts off on it self. Before I go replacing parts I hope to get some advice what I should try first. Please help.
Nov 14, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
My dishwasher is starting it's cycle, then running for a minute or 2, then it stops and drains itself, then starts the cycle over and repeats this. It won't continue it's cycle and it seems to be stuck in...
you seem to be stuck in a 'quick rinse' cycle. double check your buttons as well as your timer/dial to see if you are using the normal wash cycle. especially check the buttons. good luck
Nov 02, 2009 | Frigidaire Dishwashers
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
164 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
