Question about Stihl Garden
Service center philippines
Gasoline unable to go up in fuel bulb even pumping for aeverl times. The motor unable yo fire up?,
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 44 Answers
Hi, You probably have a cracked or damaged fuel pipe or possibly a blocked fuel filter on the end of your fuel pipe. Empty your fuel tank back into a clean bowl to see if the fuel is clean you can then se the pipe and filter. . The pipe disconnects from the carb and goes through a gromet on top of the tank. If you remove the gromet with the two pipes going into the fuel tank the pipe s and filter will come out. Normally the pipes get damaged where they go through the grommet. You can get new tubing on line ebay or other site lots in the states who will send to you I am sure. When replacing the grommet put some 2 stroke oil on it to help it go in easily and make sure the filter goes right down to the bottomm of the tank. hope this helps,
Best of luck
Steve
Posted on Jan 07, 2014
Whre i can rewind the coil of my wahl clipper in manila?
  • Order parts from Australia?
  • http://wahlspareparts.com.au/
  • or rewind in manilla
  • Coil rewinding • companies • Quezon City • Metro Manila ... www.tuugo.ph > Metro Manila ? Coil rewinding ? Quezon City ? Metro Manila ? Philippines ? Electromechtech Industrial Services, Inc. ? Breaker, Capacitor, Coil rewinding, degasify ...
  • Motor Rewinding, Philippines Motor Rewinding Suppliers ... www.alibaba.com/countrysearch/PH/motor-rewinding-supplier.html Philippines Motor Rewinding, Motor Rewinding from Philippines Supplier - Find Variety Motor Rewinding from motor engine parts ,electric motor ,motor oil pump, AC ...
  • Filipino Coils Manila Manufacturers ' Suppliers of ... https://panjiva.com/Filipino-Manufacturers-Of/coils+manila Filipino manufacturers and suppliers of coils manila from around the world. Panjiva uses over 30 international data sources to help you find qualified vendors of ...
  • ELECTRIC MOTOR REWINDING - DC ELECTROMASTER
  • www.dcelectromaster.com.ph/about us.htm DC Electromaster Service Center opened its door on rewinding electric motor since 1979. Only quality materials, unique winding system and techniques of coil insertion ...
  • Motor Rewinding in the Philippines - Philippine Business ...
  • www.philippinecompanies.com/search/motor-rewinding Motor Rewinding in the Philippines - Search Results from PhilippineCompanies.com
  • Feb 04, 2016 | Wahl Health & Beauty
    20 amp fuel pump fuse keeps blowing. I replaced pump, fuel filter, altenator, fuel pump relay. could it be the fuse box itself?
    People like to think they replaced the fuel pump and most really think they did. But I still ask, did you replace the in tank fuel pump?
    Lets be clear, did you drop your fuel tank and remove the old fuel pump and replace it and your sending unit?.
    Here's the thing, these units have electrical wires which once the coating wears off, leave the wires exposed (yes, immersed in gasoline) and they corrode and break and become a source of fire/explosion (see above where I mentioned bare wires immersed in gasoline, now imagine them igniting the fuel).
    The fuse is designed to blow as a WARNING that something (in that fuel pump system) is not right, or needs repaired and or replaced.
    Considering all that you have replaced thus far, this is what I would be investigating as a culprit and should not be taken lightly.
    Good Luck, and happy motoring
    Mar 10, 2015 | 2001 Ford Expedition
    ENGINE WANT IDLE?
    Stuck needle and seat in carb or hole in fuel pump diaphra
    Oct 16, 2014 | Boating
    7.3 diesel cranking over more than my v-10 is that normal
    Yes, it IS normal for a powerstroke diesel to require more revolutions of the motor to fire than for any gasoline engine. Combustion in gasoline engines is stimulated by spark plugs and many gasoline engines will start with little turning of the motor past the position where the ignition timing creates the spark and combustion occurs. Combustion forces the engine to continue rotating and combustion in that and other cylinders becomes a perpetual event. A Powerstroke Diesel engine requires more revolutions and speed of revolutions to create the heat necessary to cause the diesel/air mixture to combust. ALSO, the diesel is injected into the combustion chamber, at high pressure, by the injectors. The injectors are electronically controlled and the Fuel Control Module (computer) (also known as the Injector Control Module or ICM) tells each injector exactly when to open and inject diesel into the combustion chamber, as well as for how many milliseconds it stays open (how much fuel will be delivered). Summary, a powerstroke diesel will only begin the perpetual combustion process when the motor is turning fast enough and the pistons are compressing the volume of the cylinder into the tight space of the combustion chamber rapidly enough to create enough heat for the fuel to ignite and begin creating power to turn the motor without the aid of the starter. IN ADDITION, a Powerstroke will NOT start at all with weak batteries. Not only does the motor need to revolve rapidly in order to start, the injectors require a MINIMUM voltage of MORE THAN 12 volts in order to activate (open). The exact amount of voltage required can be different, depending on the Fuel Control Module (FCM) or "Injector Control Module" (ICM) type that is installed. (Note; terminology for the FCM / ICM tend to depend on who you are talking to, what resource you are reading, etc. They are the same thing.) If batteries are weak, the starter uses enough amps to drag the voltage down and, even though the starter turns the motor fast enough that any gasoline motor would fire right up, the ICM will never send the signal to the injectors for them to activate so, the cylinders never get any fuel and the motor never fires. I hope that helps. Yes, a 7.3L diesel will normally need to turn with the starter for longer than your gasoline fueled V10.
    Jun 19, 2014 | 2000 Ford F350 Super Duty Super Cab
    91 isuzu pick up sat for 2 years and now wont start
    I\'d try 2 things. One, some, or many, motors and fuel pumps, even electric ones, need to be "primed".
    You might try to figure out how to suck the fuel from the tank up to the motor somehow.
    I do not necessarily mean using your mouth.
    You could also take a rag and an air hose, and GENTLY blow air into the gas tank to "prime" the system.
    Another thing is, is there some part of the engine where gasoline could have congealed or turned to gummy deposits preventing the gas flow?
    This is why they suggest mowers and generators be run until they run out of gas before storage, to prevent gummy deposits caused by evaporated gas.
    Be blessed.
    Apr 04, 2013 | 1989 Isuzu Pickup 2WD
    1997 avalon wont start fuel pump when key is turned to "on" position and hencar wont start. Also, the car wont start when the fuel pump is hard wired to stay on. Any ideas
    There are still many possibilities. The internal combustion engine is a complex mechanism. The timing could be off. All spark plugs must be firing. They must fire at exactly top dead center. The timing chain/belt must be in good working order, not worn or stretched. The cam shaft must not be worn out so the valves open and close correctly. the valve lifters must be working properly. the cylinder heads must have the same correct compression. A different compression indicates bad valves or head gasket. Piston rings must not be worn out or they will not provide adequate compression. the oil pump must circulate the oil to lubricate everything, and provide fluid for hydraulic lifters. Oil and filters must be clean and the correct type for engine and climate.
    Nov 21, 2017 | Toyota Avalon Cars & Trucks
    The firwt time this year I tried to start my Briggs Troybilt Pressure Washer, it will not pump gas. I spray gasoline in to the carb and it starts for a moment. I spray gas in the cylinder, and it fires for...
    If you left gas in it over the winter, particularly with the ethanol blends, the carb's probably all gunked up. You'll likely have to pull the carb, clean it and rebuild it.
    Jul 06, 2011 | Briggs & Stratton Briggs Stratton 2550...
    Escort 55 D, wrong fuel in tank ,is there a drain plug or can I syphon the fuel out
    Hello, If the D is for diesel, then you will have to siphon to fuel out of the tank until you make the fuel tank light enough to drop the tank. Then remove the tank, turn it upside down after removing the fuel pump. The gasoline that is in the tank by mistake at best could be used in a 2 cycle engine. For the most part it is junk fuel. Otherwise it can be used to start fires or clean tools.
    Add a small amount of diesel to the tank and swish it around and dump that fuel as waste. Then try to immerse the fuelpump(if in tank) in diesel fuel to get out the lighter more explosive gasoline. Try blowing out the fuel that has reached the motor and have the fuel filters changed. When everything is together add only several gallons to prime the system before trying to start it.
    If you suspect gasoline is in the injectors, they may have to be removed and cleaned too.
    Now if you added Diesel to a car using gasoline, then it can be a little easier to fix. You can use the fuel pump in the tank to drain the tank via the fuel line coupler at the fuel filter. Remove the filter and turn on the key with a rubber line connected to the tank side of the fuel line. The fuel pump will drain the tank. It would be good to remove and clean the tank, but not necessary. The residual Diesel fuel will dilute over time.
    If either fuel is mixed together there will be vapors. Ventilate and put down a rubber mat or blanket under the catch bucket to insulate it from sparks and static.
    I hope my solution is very helpful to you. I want to add that sometimes Comprehensive car insurance may pay for this service. You should call your Insurance company and see if your insurance covers this.
    May 15, 2011 | Ford E-Series Van Cars & Trucks
    1998 Jeep grand Cherokee is not getting fire to the fuel pump. What could the problem be?
    Open the hood and as you are facing the engine look to the right and you will see a fuse and relay center box. Open the relay center and look on the inside of the cover you removed and it will show you which relay is for the starter and fuel pump relay. Rather than purchase a new relay remove one of the relays from a known good location (all the relays are the same in these locations). Place the known good relay in the suspected bad relays position. If it works your problem is solved. If not and the relay is good then you need to move to the fuel pump in the fuel tank. This can be tricky and if you have not dealt with internal fuel pumps my suggestion is don't start. Remember you are playing with gasoline here and possible personal injury due to fire. Have someone who is competent to replace the fuel pump if necessary. I hope this helped. Also one other thing. If you turn the ignition switch on and you hear a whining noise that will be you fuel pump. This does not mean it is pumping it just means the electric motor to the fuel pump has power to it.
    Dec 16, 2010 | 1998 Jeep Cherokee
    Hi this is randie from philippines!! i would like to ask about trouble shooting diagram and codes!! my problem is it cannot strt the engine. theres spark and gasoline!! but it doesnt strt at all!!ps anwer...
    you need to find out how much fuel pressure your pump is putting out,with a fuel gauge you can check pressure at the reed valve on the fuel rail,you will need at least 55 psi to fire the engine.
    Dec 26, 2009 | Hyundai Motor 1996 Elantra
    Garden Logo
    185 people viewed this question
    Top Stihl Garden Experts
    Joseph Mueller
    Joseph Mueller
    brotherscott
    Level 1 Expert
    ray gallant
    Are you a Stihl Garden Expert? Answer questions, earn points and help others
