Question about Maverick RediCheck Remote Cooking Thermometer w/Taste Settings
HHH code where temp should display - Maverick RediCheck Remote Cooking Thermometer w/Taste Settings
The Thermo temp flashes HHH ....and the thermometer keeps beeping...??? What do I do!?
That means the temp is higher than the unit is able to detect. If it has been exposed to very high heat then it is damaged. It may still have a bad sensor.
Jun 19, 2016 | Taylor Digital Cooking Thermometer
LCD display is showing HHH ,and wont change
Problem with loadcell sensor or may be in connection of load cell/ stain gauge. replace it.
Jan 02, 2014 | Health & Beauty
Displays just lines on outside display and has displyed HHH on both displyas , inside temp is fine
HHH means the temp is over the range that was designed. Where did you locate the sending unit?
Mar 11, 2013 | Radio Shack Wireless IndoorOutdoor...
Model# 501 ht mb HHH message in both wash and rinse temp display at different intervals,extreamly hot. cant find manual, washer installed 2 yrs ago not 1 problem untill yoday
Possibly the booster thermostat needs replacing. Expansion of the water in booster enters the wash tank when boiling showing HHH on both displays.
Mar 22, 2011 | Moyer Diebel 24 in. 501HT Built-in...
What does code HHH mean?
That's a troubleshooting code listed in the manual. It means something is broken and you should take it to a service center for repair.
Dec 06, 2009 | Cuisinart CBK-200 Bread Maker
HHH Error Code
Generally, an HHH error code means the machine is sitll too hot from making the previous loaf. Keep the door open for a bit and allow it to cool down.
Dec 25, 2008 | Sunbeam 5891 Bread Maker
Maverick et 72 remote thermometer when it is turned on it reads HHH
If the receiver and/or the transmitter display LLL or HHH instead of the probe temperature,
wait for probe to reach room temperature. If LLL or HHH is still displayed it is likely the
internal probe wire has shorted out either through moisture or heat damage.
-Tha Mp3 Doctor
Nov 27, 2008 | Maverick Wireless Remote Smoker...
Maverick RediCheck Remote Cooking Thermometer w/Taste Settings Logo
44 people viewed this question
Top Maverick Home Experts
john h
Tom Chichester
Are you a Maverick Home Expert? Answer questions, earn points and help others
