Question about Rode Audio Players & Recorders
I just want to know that if i could use the rode m2 to record my bass voice, i use saffire 6 usb as mic pre, nuendo 4 as daw on win 7
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 71 Answers
The M2 wouldn't appear to be the best choice for a bass voice. I suggest a dynamic, like the Beyerdynamic M69 or M88.
Posted on Feb 06, 2014
  • 13433 Answers
SOURCE: how to hear my voice through my usb microphone?
by default the playback of your voice is muted. next to your clock theres the sound speaker icon click on it, you should see microphone somewhere there, if you dont press settings from the toolbar and then properties
then on the playback make sure there is a X on microphone.
then click ok, now check is the microphone muted? unmute it and speak to the microphone you should hear your own voice played back instantly from the speakers.
Posted on Apr 28, 2008
SOURCE: cannot record
Im having the same probz, got a Hp Pavilion Vista using mobile pre amp usb when i record using a condenser mic XLR nothing is picked up from the channels in Cubase or Nuendo. Im trying to record vocals but the Mic is not picked up and i cannot hear myself in the headphones and it wont transfere to cubase.
It has worked before when i had a desktop, but this only worked with a separate m-audio sound card inside the desktop and i plug in the output jax leads from the desktop (soundcard) to the m-audio usb pre amp
Is this why it is not working for the laptop do i need a Jax connection and where is this audacity
Posted on Sep 17, 2008
SOURCE: Cannot record both mic and electric guitar in daw
Disagree with previous post. The GTrack is designed to record vocals and a mono insrtument at the same time. That's its main selling point. It should also allow monitoring of both the vocals and guitar alongside the playback from the computer. In your computer's Control Panel, go to sound preferences, select the usb microphone and click on advanced tab. It is likely yours is set up to record 1 channel at CD quality - this is how many ship for some reason. Set it to 2 Channels CD quality.
In Sonar, set your track input as USB Left for the vocals, and USB Right for your guitar.
Posted on Apr 14, 2009
SOURCE: SE2200a rapid signal drop off
I had the same problem with my Saffire: the phantom power voltage quickly drops when switched on, causing the mic to cut out. This problem is common in older Saffires, and is well known to Focusrite support (a modification in newer-production units solves the problem).
The problem is that a tiny 100 ohm surface-mount "chip" resistor in the phantom power circuit fails due to insufficient power-handling capability. (This is "R196" in the phantom circuit.)
The fix is to replace the "chip" resistor with a "normal" 1/2 watt metal-film resistor (with wire leads), mounted upright on the circuit board.
I replaced the resistor myself, following directions (and photos) sent to me by Focusrite Tech Support.
The procedure is somewhat fiddly (a Swiss watchmaker could probably do OK). If you've never soldered before, DON'T EVEN TRY THIS, and if you've never worked with surface-mount components, I would ask your electronics-hobbyist buddy to do it for you.
Here is the procedure sent to me by Focusrite:
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} SAFFIRE PHANTOM POWER MODIFICATIONS
Dismantling the Unit
Remove the 7 screws on the rear panel.
Remove the 4 screws on the underside of the unit.
Lift away the metal cover.
Remove the 4 small black screws securing the MIDI In/Out sockets.
Remove the single screw securing the S/PDIF In/Out sockets.
Remove the two screws securing this PCB to the chassis.
Gently pull the PCB away from the rear panel and move it through 90 degrees towards the front panel.
Place the unit on its front and support the PCB with some suitable non-conductive item.
Modification Procedure
All the components mentioned are located in the same area on the same PCB (see photo).
It is best to remove the coil and capacitor (as shown in the second photo), as this gives easier access to the components.
Remove R196 and measure its resistance. If it does not measure 100 ohms, replace it.
Use a conventional type (100 ohms metal film, .5 or .6 watt) mounted upright as shown in the photo. Before fitting this resistor, check that the three zener diodes DZ11, DZ12 (22v) and DZ9 (3.3v) are OK and have not shorted out. (Diodes are 500mW, 5% tolerance)
Testing units for Phantom Power problems
Connect a condenser Mic or suitable dummy load* to Channel 1.
Engage +48 switch.
Measure the DC voltage between XLR pins 2 & 1 on Channel 2 Mic Input XLR.
Faulty units usually read around +28Vdc and the voltage gradually drops.
Good unts will measure +48Vdc +/- 0.7Vdc.
* Dummy Load for testing: Solder a 20,000 ohm resistor between pin 2 and pin 1 of a male XLR plug and another 20,000 ohm resistor between pin 3 and pin 1 of the same XLR plug.
Here are the photos:
My Saffire has worked perfectly since I replaced the bad resistor.
Good Luck!
Ken
Posted on Apr 17, 2009
  • 5603 Answers
SOURCE: whistling background noise with Samson C01U USB condenser mic
Welcome to the world of STUDIO microphones. Super quality BUT you must have a studio to use them. You can't have any local speaker playing into them. You often use headphones lest your monitor speakers will feedback. At the high frequency capability of these mics, you can fry your amps with oscillations above what you can hear!
Posted on Sep 30, 2009
Akg perception 220 professional microphone
Try building a little mike-preamp with an opamp to boost the signal.
Enough schematics on internet.
Or walk into an electronics shop for a ready to build package.
These are the things I can suggest; I don't know your audiobox.
Perhaps there is internally a pot-meter to adjust the gain of your mike; that would be the easiest solution.
Mar 06, 2014 | PreSonus AudioBox 22VSL 2x2 USB Interface
I got a rode classic II with avalon m5 mic pre. So when i crank up my mic pre to 60 n i can start listening some hissing from my monitor...or is it normal for a valve mic coz when after recorded with this...
The hiss is caused by your monitor system level and your preamp gain being so high. At high gain settings, a preamp is going to get noisy, and tube mics have a higher noise level to begin with.
If you can't hear it on your recordings, then it's not a problem.
Sep 17, 2011 | Rode Classic II Professional Microphone
I got a pre-amp (Focusrite Platinum Trakmaster Pro) with phantom +48v. i got an M-Audiophile 2496 installed to the comp. and a mic Rode nt1A. Eveything is plugged in and installed and iv'e...
the process of elimation will help you to solve your issue. first plug the rode nt1 (great mic by the way), into a good pa head or something you know works, of course you will need to have a pa that gives you phantom power. if the mic works then move on to the preamp. try it in the pa too, if it works move on to the m-audiophle and plug a line level signal into it (a cd player or mp3 player for instance) it this works then you have determined that everything works and you don't actully have a problem other than switching, Also try plugging your mic into the M-audiophle directly and see if thaat works ( don't know if that provides the 48 volts, if it doesn't than you will have to get a phantom supply to plug into first. good luck
Mar 17, 2011 | Rode NT1A Professional Microphone
I plug my rode ntg-2 into the computer and record using audacity and the recording is extremely low in volume.
This mic needs phantom power to operate. Best bet, go and buy a USB mic pre, such as a M-Audio product.
This mic, I believe also runs on a battery, when phantom power is not available...so check the battery.
Or, simply, your record levels are set too low.
May 20, 2010 | Rode NTG-2 Professional Microphone
I dont know why i can not record my mic into my nuendo4
plz first setup your driver. ten setup nuendo 4. device setup-vstaudio system-click switch
Apr 04, 2010 | Intel Steinberg Nuendo AudioLink PCI 96...
Has a muffled sound
How are you using the mic ie how far,through what type of equipment etc.. Shure make and have made great mics for years with the 58 and 57 dynamic models[very common used live and in the studio] being able to produce good clear vocal and guitar,sax etc recordings.. If you are using one of these or similar dynamic mics,then because they are not' too sensitive' ie pick up room sound/character you ought to get clear usable results from a few cm ..{a pop shield can help one move closer without pops[ppwwwooow type sound from breath].. But the pre amp level has to be set right so the sound is not to quiet but not overloading etc..{ i don't know what you have or why,so am suggesting basics} If there is a simple 2 or 3 knob eq on a mixer/amp or software,then add s little treble and less bass... If you have a good functioning set up and feel the sound lacks a certain amount of detail and you have tried all the above ,perhaps you need to consider trying out different types of mics..Large diaphram condensers perhaps..?? How about one with built in pre amp and USB input so that you can plug direct into the computer with minimum fuss ,if thats what you are using..[Rode and SE electronics make great USB mics at fair prices..] The pre amp that amplifies the signal is an important part of the chain if not using USB models ,but even a small mackie mixer with its pre amps built inwill turn out good results with some effort and experimentation.. ..Good luck..
Mar 01, 2010 | Shure Audio Players & Recorders
Noise from nouendo recording
What you need is a Plug-in, Either a NOISE FILTER or DNR (Dolby Noise Reduction) Also try when you record to set up the Mic away from Speakers, Equipment, and watch your lights. These are all Noise Makers on Tracks. Even Guitar and Bass to close to Monitors will give you added noise. If you can not find a Plug-in then pull up an EQ, Find the Frequency making the Noise, Adjust the "Q" (Range of Frequency) to be NARROW, Then slowly pull down your unwanted frequencies. This will get rid of Noise, But also anything else in that Frequency! Good Luck!
Apr 29, 2009 | Steinberg Nuendo 3 for PC
Cannot record
Sep 15, 2008 | M-Audio M AUDIO MOBILE PRE - USB MIC...
Engage +48 switch.
Good Luck!
Ken
May 04, 2008 | SE Electronics SE2200A Professional...
PLAYBACK PROBLEM
need to know if you use headphones while recording, if not it could be feedback from your monitors or even the phones.reasons phones too loud or mic gain too sensitive.
May 28, 2007 | Rode NT1A Professional Microphone
98 people viewed this question
Top Rode Audio Players & Recorders Experts
Michial Gueffroy
Don Hart
Tom Chichester
Are you a Rode Audio Player and Recorder Expert? Answer questions, earn points and help others
