Question about 2000-2009 BMW K1200LT Brake Pads
Connect a 3.5mm ear bud jack
I want to listen to the stereo on my 2002 k 1200lt while riding, as the stereo dose not have Bluetooth compatibility I wont to fit a 3.5mm jack to use my ear buds. I understand that the ear buds and the stereo output is different to the ear buds so I want to connect it so there is no damage to either stereo or ear buds.
    New Friend:
  • 3 Answers
Fair warning, this response may be a dead end & be a waste of time. I can only refer you. In attempting to find a fix to your problem I did a little research. I am not sure that what I am telling you is even allowed on this site. On YouTube, type in ' Connect stereo to earbuds on BMW1200LT'. there is a vid showing stereo install. It may help. Sorry, I am a hardwire tech not a wireless guy.
Posted on Dec 25, 2013
How do I. get. music from my phone to play thru my home stereos receivers
I'm assuming u have bluetooth on stereo find bluetooth on ur phone, turn it on and find the device u need. I do it old fashion way with cord has headphone jack on one end to plug in phone and red and white to plug into stereo. If u really want low tech cassette tape with headphone jack works too.
Sep 05, 2014 | Audio Players & Recorders
My phones' audio jack won't play music from the right ear bud
Have you use another headphones insteading of your Sony headphones to have a try? Make sure it is not the problem of headphone, then you may need a headphone jack replacement to replace the old one.
I've also met this situation with my phone. Finally I found the right
Headphone Earphone Audio Jack Flex Cable for Samsung Galaxy S4 i9500 to solve this problem. You can also look for one repair part for your phone, then find a video following to fix. It is easy to make it. Hope it can help.
Mar 07, 2014 | Bose QuietComfort 2 Consumer Headphones
Connect a 3.5mm jack to stereo
Get the GPS version that has the blue tooth compatibility also change the brake pads to ceramic kind .
Dec 25, 2013 | 2000-2009 BMW K1200LT Brake Pads
I have enjoyed my Bose headphones for a couple of years now and tonight I plugged them into my iPad to watch a movie and the sound from the right headphone diminished quite a bit compared to the left. I...
Could be possibly dirt in Ipad headphone jack (common prob) - put a drop of isopropyl alcohol in Ipad jack - just a drop. You might also check headphones in a computer jack to verify if it is possibly the headphones.
Apr 03, 2011 | Bose in-ear headphones - Black with...
Want to know how I can listen to my music through my bluetooth
bluetooth is a type of wireless connectivity between supported devices. you can share music files with other mobile users through bluetooth , and you may use a bluetooth wireless headset to listen to the music files being played through your bluetooth enabled systems such as laptop and may also be supported by yuor phone.
Jan 17, 2011 | Cell Phones
Wiring diagram for skullcandy headphones
The cat chewed my skullcandy headphone wire in two, how do I splice them. Thank you, Robin
May 17, 2010 | Audio Players & Recorders
What jack is compatible to laptop using shure
You have to connect the unbalanced output (the 6.3mm jack) to the laptop's line in (or mic with setting the rec level at very low settings) 3.5mm jack. In details the wiring should be as follows:
6,3mm jack shield to 3,5mm jack shield
6,3mm jack ring to 3,5mm jack shield
6,3mm jack tip to 3,5mm jack tip and ring
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Apr 12, 2010 | Shure PGX14 Wireless Guitar/Bass System...
Want to use blue tooth to listen to music on my g1 instead of ear buds
U can connect your mobile to bluetooth headset. In bluetooth option there with be "Search for audio enhancement" option it will find out if your bluetooth headset is on and working. If u connect you can hear thru bluetooth. Pls vote for me if my suggestion is helpful.
Regards, Kesav
Mar 03, 2010 | HTC G1 Smartphone
I five klh speakers and bose amplifier, how can i connect it to my home hp pc
Perhaps you can specify which Bose amplifier you have. Presumably it drives the 5 speakers. Can you specify which computer you have? Do you have an add-on sound card? Does your computer have a 4 or more channel output? That is a different matter. Do you want the highest possible audio quality?
I'm going to assume the simplest configuration here.
1) There are two likely auxiliary input jacks for the Bose amp. One is a single 1/8" stereo jack. This jack would fit your ear bud headphones. Try this with it turned off. The other option are dual RCA jacks. These have a center opening around a cylinder about the size of a pencil. The center opening is about the size of that ear bud plug, but don't try and put it in there. The cylinder outside will have a metal ring.
2) Determine the output of your computer sound card. It is most likely a 1/8" stereo jack, so try your ear buds with it turned off. Many computers have a headphone jack and then a speaker jack. The speaker jack may be color coded green. You should be able to drive off of either of these but you will want to control the volume on your computer appropriately because the speaker output may drive too strongly for your Bose. Turn the volume up slowly.
So, then you need to go buy a cable. Here are two likely possibilities:
a) 1/8" stereo male to dual RCA male
for example: http://www.radioshack.com/product/index.jsp?productId=3449316
b) 1/8" stereo male to male
for example: http://www.radioshack.com/product/index.jsp?productId=2102949
Jul 21, 2009 | Audio Players & Recorders
I need a replacement rubber ear pad for one of my headphones.
most best buy stores have extra axcessories where the headphones and portable tape players are. try there, they might have them.
Mar 19, 2009 | JVC Gumy Ear Bud Headphone - Peppermint...
2000-2009 BMW K1200LT Brake Pads Logo
51 people viewed this question
Top Galfer Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Galfer Vehicle Part and Accessory Expert? Answer questions, earn points and help others
