Question about Snakebyte Ps3 Wired Controller Whit
Controller problem i just bought my snakebyte ps3 controller a couple weeks now and whenever i tried to play my ps3 controller it countinously says to reconnect knowing i got it plugged in far as ity;ll go. what's wrong? thanks.
My snakebyte controller for the ps3 just stopped working is there a way to fix it?
Hi Brandy,
On the back of the controller is a small hole just above the label to the right, this is the reset button, so use a pen or something thin to reset it and then re-sync it as usual.....hopefully that'll work
Thanks
Mar 15, 2014 | Snakebyte PlayStation3 Premium Wired...
Hello I am having an a minor issue playing my Modern warfare 2 game. when I am playing it appears that the man that I am using is moving on its own and/or if I try to move in one direction it goes in...
Most likely your controller is the issue. If you bought it used, it could be damaged or miswired. If you bought it new, then it's more likely miswired. Try playing with a different controller to see if the problem persists. If it doesn't, then take Game Stop one back and get a replacement. If it does, then it's more likely an issue with your system.
Oct 04, 2010 | Sony Playstation 3 (PS3) Console
I just got a ps3 for the last couple weeks and
Replace or check the cable form the PS3 to the TV...there maybe a short or loose connection in the cable that is causing the color to be missing, especially if you are using component(Y) or composite cables(RGB).
PLEASE VOTE IF THIS WAS HELPFUL. THANKS & GOOD LUCK.
Oct 23, 2009 | Sony Playstation 3 (PS3) Console
My PS3 will play PS3 games sometimes. It quit
sounds like a dead Laser they are a dual laser will read DVDs n CDs but wont read Blueray movies or PS3 games Laser might need replacing
Oct 19, 2009 | Sony Playstation 3 (PS3) Console
I just recently bought a PS3, the 80gb model and i've been playing Infamous for the past week and have gotten pretty far in the game. today, i switch on the system to play it and all of a sudden a red...
Its a problem from the system. Try re-updating the console... to the latest firmware... then try playing the game. If that does not work... call in the PSN
Aug 30, 2009 | Sony Playstation 3 (PS3) Console
Connection Problem, PS3
save your memmory on a memmory card than reboot the hole system it will work for sure
Mar 06, 2009 | Sony Playstation 3 (PS3) Console
PS3 controller does not work after 2 weeks.
try plug in the carger to the ps3 then the controler then press the ps button
Feb 12, 2008 | Sony Playstation 3 (PS3) Console
Snakebyte Ps3 Wired Controller Whit Logo
44 people viewed this question
Top Snakebyte Video Game Consoles & Games Experts
James Wishart
Are you a Snakebyte Video Game Console and Game Expert? Answer questions, earn points and help others
