Question about 2000-2009 BMW K1200LT Brake Pads
Connect a 3.5mm jack to stereo
I want to fit a 3.5mm ear bud jack to the stereo on my 2002 K 1200 LT so I can listen through the ear buds while riding. The stereo dose not have Bluetooth compatibility.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Galfer Master
  • 1,632 Answers
Get the GPS version that has the blue tooth compatibility also change the brake pads to ceramic kind .
Posted on Dec 27, 2013
How do I fix my ear buds when theirs 4 wires from the jack but only 2 wires to the buds???
Hi.. Could the jack have left wires for the left bud and right wires for the right bud...... Just a thought..
Mar 26, 2016 | Audio Players & Recorders
Turn off the phone speaker when ear phones are connected?
that is a function of the ear phone jack some aftermarket buds do not plug far enough in to disconnect sound going to internal speaker tray another set
Jan 02, 2015 | Samsung Galaxy S 4G Cell Phone
My phones' audio jack won't play music from the right ear bud
Have you use another headphones insteading of your Sony headphones to have a try? Make sure it is not the problem of headphone, then you may need a headphone jack replacement to replace the old one.
I've also met this situation with my phone. Finally I found the right
Headphone Earphone Audio Jack Flex Cable for Samsung Galaxy S4 i9500 to solve this problem. You can also look for one repair part for your phone, then find a video following to fix. It is easy to make it. Hope it can help.
Mar 07, 2014 | Bose QuietComfort 2 Consumer Headphones
Connect a 3.5mm ear bud jack
Fair warning, this response may be a dead end & be a waste of time. I can only refer you. In attempting to find a fix to your problem I did a little research. I am not sure that what I am telling you is even allowed on this site. On YouTube, type in ' Connect stereo to earbuds on BMW1200LT'. there is a vid showing stereo install. It may help. Sorry, I am a hardwire tech not a wireless guy.
Dec 25, 2013 | 2000-2009 BMW K1200LT Brake Pads
It only lets me listen to music in one ear
  • If you have a warranty I would definitely send it back to the manufacturer. Most companies will pay for shipping for warranty repairs as well. What sounds like has happened happens a lot. The plug the jack plugs into (inside the Mp3 player) gets a cold soldier joint or the jack on the ear buds gets caught on something one to many times and breaks a soldier joint loose.
  • I usually open the media players and reheat the soldier joints myself. If you have already tried a different pair of ear buds it is almost certainly the jack inside the MP3.
  • Hope this helps.
Nov 08, 2011 | Nextar MA797 MP3 Player
None of the ear pieces work only if I move around the Jack plug thing
sounds like the jack is faulty tghe cable has been pulled and the wire probably stripped off connectors. if you can access a electronics or audio shop purchase a new jack these are cheap and you will need to cut the end off the cable there should be three wires an earth and a left and right cable these will need to be resoldered on the new jack plug.. make sure it is a stereo jack...!!.the best way to solder is to gently heat the cable end and dab a bit of solder on each before trying to attach to the jack. then when you come to connect the jack end lightly touch the connector and cable together with solder iron and solder..good luck A
Aug 13, 2010 | JVC Gumy Ear Bud Headphone - Peppermint...
I five klh speakers and bose amplifier, how can i connect it to my home hp pc
Perhaps you can specify which Bose amplifier you have. Presumably it drives the 5 speakers. Can you specify which computer you have? Do you have an add-on sound card? Does your computer have a 4 or more channel output? That is a different matter. Do you want the highest possible audio quality?
I'm going to assume the simplest configuration here.
1) There are two likely auxiliary input jacks for the Bose amp. One is a single 1/8" stereo jack. This jack would fit your ear bud headphones. Try this with it turned off. The other option are dual RCA jacks. These have a center opening around a cylinder about the size of a pencil. The center opening is about the size of that ear bud plug, but don't try and put it in there. The cylinder outside will have a metal ring.
2) Determine the output of your computer sound card. It is most likely a 1/8" stereo jack, so try your ear buds with it turned off. Many computers have a headphone jack and then a speaker jack. The speaker jack may be color coded green. You should be able to drive off of either of these but you will want to control the volume on your computer appropriately because the speaker output may drive too strongly for your Bose. Turn the volume up slowly.
So, then you need to go buy a cable. Here are two likely possibilities:
a) 1/8" stereo male to dual RCA male
for example: http://www.radioshack.com/product/index.jsp?productId=3449316
b) 1/8" stereo male to male
for example: http://www.radioshack.com/product/index.jsp?productId=2102949
Jul 21, 2009 | Audio Players & Recorders
2000-2009 BMW K1200LT Brake Pads Logo
47 people viewed this question
Top Galfer Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Galfer Vehicle Part and Accessory Expert? Answer questions, earn points and help others
