Number lock key
I PRESSED NUM LK AND IT NOT WORKING
    Master:
  • 788 Answers
1. Please tap the NumLock key many times and see if it responds to the tap,
2. Probably your keyboard is in "Alt Fn" mode, so please try to hold the Fn key and tap the Fn key (I prefer to tap the left arrow and right arrow) and see if the keyboard is working properly.
3. Probably your keyboard is failed. It happens, even there is no spill accident. In this case, you need to replace the entire keyboard.
Posted on Dec 25, 2013
  • 61 Answers
SOURCE: my laptop keyboard is typing different letters and numbers
It sounds like your keyboard is starting to go. Try plugging a usb keyboard and using that. If your keyboard needs replacing, it may be around $50, but that will depend.
Posted on Mar 18, 2009
benwabnick
  • 2404 Answers
SOURCE: Num Lk button ASUS M51K won't turn on
Your best bet is to get that keyboard replaced. for some reason the overlay underneath that key isn't responding properly whether its because its worn out or maybe somebody spilled water on the keyboard by accident. Intermittent keyboard problems only get worse over time.
Posted on Jul 06, 2009
  • 44 Answers
SOURCE: num lock activated and can't turn it off
One of your Function keys (F11, F12, etc., usually F11) will also have the NumLock function on them. So when you hold Fn and press F11, it will toggle the Number Lock. Try holding Fn and press F11, this should turn it off (and back on should you ever want to use it again). Your keyboard should be labeled with the various functions keys have when Fn is pressed, you may have to look for the one that reads NumLk.
Posted on Sep 09, 2009
Davethesnake
  • 689 Answers
SOURCE: FIXED keyboard stuck in fn mode ASUS 1000h eee
thats a good one for people with long fingers!
Posted on Sep 05, 2010
  • 112 Answers
SOURCE: Where is the "num lk"
It is most likely a FN + button on my acer it is Fn + F11
Posted on Mar 05, 2011
How to work key pad
Key pad? Do you mean the keyboard or what?
Mar 21, 2016 | Dell Inspiron 1525 Notebook
ASUS Q501L Notebook PC, how do I keep or even start the numbers lock keypad? Keep pressing num lk key but nothing happens.
Admittedly, the placement of the "END" key is odd in the location where the "NUM LOCK" key would normally be. However, if you look at that key closely you will note that there is a second function to it. Hold down the "fn" key and press the "End/num lk" key and the numbers will be turned on.
Jul 31, 2013 | ASUS Eee PC 1000H Laptop
Alphabet keys displaying numeric
This happens when you have the Num Lk (Number Lock) key on and you have Pressed the FN Function key at the lower left hand portion of the keyboard. When this happens if you press the keys such as UIOJKLM you will key the numbers 4561230.
Turn your Num Lk off by pressing that key at the top of the keyboard.
Apr 26, 2012 | Acer Aspire 5600 Series 5610-2013 Notebook
Number pad does not work
  1. Find Alt code.
    Numeric Alt codes for symbols are listed in Alt codes list. Check for Alt code of symbol you want to input.
  2. Enable Num Lk.
    You may need to simultaneously press ["FN" and "Scr Lk"] keys. That's the combination for "Num Lock" on some laptops. Look at the picture - the "Num Lk"/"Scr Lk" button is highlighted there.
  3. Hold down "Alt" key.
    Some laptops require you to hold both "Alt" and "FN" keys.
  4. Input Alt code of symbol on Keypad.
    Do this while holding "Alt" button pressed. Type Alt code on your laptop's numeric keypad. It's highlighted on the picture.
  5. Release all the keys.
    After you release all the keys alt symbol should be entered. If all this stuff didn't work - check if you have really enabled the "Num Lock" first. Remember that green indicator should shine near the lock symbol on your laptop's keyboard. If that wasn't the case - try simultaneously holding "FN" and "Alt" keys instead of just "Alt". That just might work.
Feb 15, 2012 | Toshiba Satellite P105-S9722 Notebook
For some reason the number lock is on my keyboard - i can*t figure out howto unlock it. i have to keep the fn key down in order to type the letters on the right hand side. how do i unlock/ thanks in...
Please follow the below instruction to fix your problem.
Press 2 keys at the same time: "FN" (next to the CTRL key, lower-left of the keyboard) and "num lk", which is the upper-right of the keyboard (it is on the same key as "scroll", and is next to "F12"). This will either turn on or turn off the "Num Lock" function. Both the "FN" and "num lk" are enclosed in a small rectangle. They are easy to see.
Hope the above information will be helpful to you. Thank you. Have a good day.
Aug 11, 2011 | Fujitsu Computers & Internet
There is no key for numlock on my Dell studio 15 keyboard
The num lock key is labeled as 'Num Lk' on the Dell Studio 15 keyboard. It is located above the =/+ key next to backspace.
To activate num lock, you cannot just press the button. You have to make sure the num lock light is on and then hold down Fn while using the numpad.
Hope this helps,
Tiger720
Sep 02, 2009 | Dell Studio 15 Laptop
Number 9 inside a lock symbol on the keyboard and computer unresponsive
press num lock /num LK/scroll Lk.Find any of those key on your keyboard.it solve your problem.If .in Dell Latitude D600 the num lock/num Lk/scroll Lk is above F11 key.
  • after solve it,don't forget to visit me here
Jun 10, 2009 | Dell 0Y3740 Keyboard
Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
Mar 22, 2009 | HP 2133 Notebook PC
Fn key on keyboard seemed stuck
hit shift and "Num Lk" at the same time. Num Lk is abov the F11 button on some Dell keyboards.
Tony Nguyen From Pasadena, CA
www.connectionzpcrepair.com
Aug 06, 2008 | Dell Latitude CPX Notebook
Dell Laptop - Keyboard "Fn" is causing problems!
I think it is not the Fn key but the NumLock that is activated. Look for the key labeled NumLk , this is the number lock. Also check if the light on the notbook with a number (usually number 1) is on. If it is on, yo must deactivate the numlock by pressing it again. It works in toggle mode. Sometimes the numlock is activated together with the shift key, sometimes with the function key.
Jul 06, 2007 | Dell 0Y3740 Keyboard
Computers & Internet Logo
David Payne
David Payne
