Charge time Doesn't seem to b charging ..... How long should this take ????
    Master:
  • 788 Answers
You can open the Windows and see the battery charging indicator on the right-bottom-corner. You can monitor the charging progress (every 10 minutes; the battery should get 1 more percent charging). Please make sure that there is a "charging" info when your mouse pointer is hovering on that icon. If the info is "not charging", then probably the battery is start failing or it is failed.
Posted on Dec 25, 2013
Doesn't seem to hold charge
right so it's one of two things, either the charger or the batteries,
can you try another charger ?
regards
Dec 18, 2012 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Tip
Battery keeps dying for no reason:
Is your Battery good or bad?
Sometimes a battery seems ok then later it seems dead. sometimes it charges and then it won't take a charge. This keeps going on and doesn't really seem like the battery is bad. This is a common problem happening to everyone at times.
Could be a dead cell in the battery, try measuring each cell in the battery. If one cell is low it will seem like a dead battery. But the battery really needs to be replaced. The debris in the bottom of the cell is intermittently shorting the cell.
Hope this helps.
on Apr 23, 2015 | Cars & Trucks
Battery doesn't hold charge for more than a week
All batteries will eventually fail to hold a charge. The battery chemistry and how you charge it can change how long the battery will last. The DMC-FS4 has a Lithium-ion battery so it shouldn't have as much of the memory issue of older rechargeable batteries. (This is the "you routinely recharge the battery when it's at 50% then it always stops working at 50% charge" problem.)
How old is your battery? Eventually you will need a new battery but the time to replacement will depend on the number of recharge cycles. With a Li-ion battery, I'd expect several thousand recharges before failure. Temperature and usage will effect this. The battery does lose charge even when not used.
Be careful, some versions of the firmware look for Panasonic's specific batteries or a "that match the Panasonic rigorous specs".
I've seen a few devices where the charger failed before the battery. If a new battery doesn't seem to be charging, replace the charger. I hope this helps.
Oct 18, 2012 | Panasonic Lumix DMC-FS4 Digital Camera
Charging is not working
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Oct 14, 2012 | Samsung T245G
Just bought one of these and it seems like it doesn't hold a charge it goes pretty good and thanafter 15 mins so slow??
Battery powered vehicles like scooters and golf carts have trouble going up hill because smaller electric engines aren't powerful enough or made for nothing more than flat land. You could have a bad battery or the battery isn't being charged enough. I know someone that has a golfcart and it takes approximately 48 hours to charge full. You may want to check the manual about charging times.
Sep 16, 2012 | Razor E200/300 Electric Scooter Battery
My Sloney E reader doesn't seem to be taking a
Because the battery is not removable? Best thing is to allow the E Reader to be completely cleared of any charge. OR While it is plugged in, press and hold the power and N buttons simultaneously for 20 seconds. I then turned the device on normally. Hope this help, have a great day..
Feb 24, 2012 | Sony Computers & Internet
When watching any DVD on my Sony DVP-NS999ES player, all the colors seem washed out. Is there anything I can do to correct this?
Projection televisions have a spinning light filter disk, assuming its DLP, and over time the get hot from the light and fade, It is fixable. Tell the repair man ahead of time you KNOW what the problem is, so he doesn't charge a rediculous amount of money. those color wheels are about $70 bucks and the tech will probably charge you the same in labor. sorry :(
Jul 30, 2011 | Televison & Video
Battery seems to not charge anymore
you can contact Acer via their website and they will direct you to a local provider or they will send you a replacement.
Jul 15, 2009 | Acer Aspire 5920 AS5920 Notebook
Won´t charge
My SLVR had the same problem, so I bought a new one from Amazon. When I plugged the new one in the first time it did fine, but when I ran the battery completely out, it wouldn't charge. I played around with it a little bit, and I think I've found a solution that works: try taking the SIM card out of the phone, THEN charge it. It works on both my new one and my old one that way. The drawback for you is that you can't use your phone while its charging, I just switch phones while the other is charging, a bit of a pain sometimes, but the SLVR is my favorite phone so its worth it. :-) Good Luck.
Dec 10, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
