Question about Archery
How do I remove the arrows on the tomcat Jr archery set
  • Confused
    Confused Dec 30, 2013
    Did you find a resolution, because we cannot figure out how to remove them from the packaging either. We are just shy of cutting the plastic. Thanks.
Arrows fly different directions when shot on brand new bow
Barnett says it all. terrible quality problems lately. Could be anything. I suggest return it and for youth bows the atomic bow is the best at best price. Made by bowtech diamond line.
Mar 08, 2014 | Barnett Outdoors Tomcat Jr Compound Bow
Arrow won't lay flat on the rail
Dangerous situation Contact Barnett lifetime warranty. DO NOT SHOOT THAT BOW. I Repair bows in Northwest Indiana. The Archery Clinic
Sep 15, 2013 | Barnett Crossbows Barnett Wildcat C5...
Drop away rest won't stay up when nocking arrow
is it automatic or is it controled by a string atached to the rest?
Nov 05, 2012 | Quality Archery Design Archery
Where can I purchase some archery supplies?
I buy all my supplies including bows, arrows, targets and protective gear from http://www.cabelas.com/archery.shtml They got a wide variety of accessories for archers and their products are top quality although a bit expensive.
Aug 26, 2012 | Betsey Johnson Archery
What equipment do I need?
In general it is best to have an ample supply of the same or similar bow types. You need to have bows, arrows, quivers, arm guards and a finger tab. Targets are also necessary for your archery stock.
What is good to use for a target in archery?
You can buy archery targets, but they can range anywhere from $40 -$200. If you are looking to make your own, this is a fantastic article to read: Making Archery Targets from Livestrong.com.
  • I've used targets made out of hay bales in the past.
  • You can also make them from feed/grain sacks, packing filling, sand bags or old carpet.
  • The article above will give you instructions on how to make all of the types, then some.
Jul 09, 2012 | Archery
What are the best arrows to use in archery?
I found this blog that has all the information you need regarding the types of arrows that are used with different types of bows http://bleacherreport.com/articles/280059-how-to-choose-the-best-archery-arrows-that-better-your-skills
Arrows seem to dip and rise to the target
the spine of the arrow seems to be off a bit. The spine is the stiffness, check a archery chart for your bow draw weight and suggested arrow spine.
Dec 18, 2009 | Saunders Archery Sport & Outdoor - Others
How do i start tomcat server?
I ll share config steps that I use:
1) After installing the Tomcat server set the environment variables in the following way :-
a)var name:path
var value:C:\Java\jdk1.5\bin;C:\Tomcat 5.5\bin
b)var name:classpath
C:\Tomcat 5.5\webapps;C:\Tomcat 5.5\common\lib\servlet-api.jar
c)var name:JAVA_HOME
d)var name:CATALINA_HOME
Var Values:C:\Tomcat 5.5
2)After setting these variables check to see if the server is running by typing "http://localhost:8080/" in the web browser.
3)If you can see the Apache Tomcat page with the message "If you're seeing this page via a web browser, it means you've setup Tomcat successfully. Congratulations!" then everything is fine & server is well configured.
I havent tried it on Win 2000 yet, these steps I use to configure Tomcat on Win XP & Vista, hope this proves to be of some help to you too.
Apr 29, 2009 | Computers & Internet
Archery Logo
209 people viewed this question
Top Archery Experts
Andre De Beer
Andre De Beer
Level 1 Expert
Tom Chichester
Are you an Archery Expert? Answer questions, earn points and help others
