Question about Alesis Q88 88-Key USB MIDI Controller
Alesis q88 has no sound
There is no sound on the keyboard
The keyboard was working fine and all of a sudden stopped making sounds. I must have pressed a button.
I've never heard of a keyboard making sounds. I have heard of key presses making sounds. In the control panel under keyboard there may be a setting. The setting may also be under sound or audio (depends on the operating system).
Mar 21, 2015 | Computers & Internet
Disable keyboard sound on dell venue tablet
Go to settings.
Language and input.
Keyboard and input methods.
If google keyboard is your default, tap on the settings image.
Under General, there is an option called "Sound on keypress".
If checked, un check it and the sound will disappear.
Terry
Terryt
Mar 02, 2015 | Dell Tablets & eReaders
How to deactivate shift key sound on windows keyboard
Right click on the speaker icon in the bottom taskbar select playback devices then sounds tab scroll through all device sounds select it then from the drop down list select none
this will vary depending on your operating system
or
Click "Start."
Click "Control Panel."
Click the "Sound" icon.
Click the "Sounds" tab.
Click on the listing for the sound that currently plays when an action is performed on your keyboard.
This will select it. Click the drop down menu on screen and select "None." Click "Apply" to disable the keyboard sound in
hope this helps
Oct 10, 2012 | Computers & Internet
LAPTOP KEYBOARD DOES NOT ENTER TEXT. WHY?
Reinstall the drivers.
Check which keys are not working exactly
Go to BIOS, press the keys which are not working and check whether you are getting any beep sounds .
If you get the sounds, reinstall drivers perform system restore...... if still the problem persists perform system recovery(Reinstalling the operating system).
If you did not get any sounds in BIOS check with external keyboard and if the external keyboard does not work take the system to the service.
If the external keyboard works, change the current keyboard of your system.
Mar 17, 2010 | Acer NSK8458AN Keyboard
Keyboard sounds
To turn the keyboard sounds off, first go to menu, then settings, then profiles, then normal,press options, customize, and scroll down to Key Volume and adjust sound. I hope this helps. I had the same problem!
Jan 20, 2009 | Pantech Matrix Cell Phone
No audio sound after installing the keyboard software
when you loaded the software for the keyboard, the buttons on the keyboard for functions will be active, have you made sure that the mute key on the keyboard is not pressed 'on' to mute the sound?
Nov 18, 2008 | Logitech Cordless Desktop MX3200 Laser...
Alesis Q88 88-Key USB MIDI Controller Logo
253 people viewed this question
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Gil Shultz
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
