Question about Supersonic Televison & Video
Bluetooth static when on bluetooth mode - Supersonic Televison & Video
  • Dayton Computer
    Dayton Computer Dec 25, 2013
    Hi rachel papineau, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Bluetooth static when playing music on bluetooth mode
Static is interference between the source device and the WHAT? Headphones, Speakers, Amplifier, or TV?
I assume you are trying to send a signal wirelessly from your player or computer to an independent receiver of sorts?
Dec 25, 2013 | Supersonic Televison & Video
I have just got a used nokia CE0681 bluetooth headset, how do i connect it with my nokia 6120c?
All these given solutions are not catering your problem unfortunately; because your problem seems to be the following "You are not at all able to find your bluetooth headset from your phone, pairing is a far off thing" right?
So, here is the simple solution that no one has given here and on other sites (I myself was confused, but finally found it out):
1. Turn bluetooth of your Mobile on.2. Put it into "shown to all" mode.
3. Now pick your bluetooth device, and simultaneously click on the multifunction key (The middle one that blinks) and the "+" volume key for around 6 seconds or more; you'll see that blue blinking light will become static (and it means that your bluetooth device is now "Searchable" by your phone).
4. Start "Pair new device search" from your Mobile, and your Phone will find the bluetooth device.
5. It will ask you for a passcode, just enter 0000.
6. Pair both devices now.
7. The static blue light (Which became static when you pressed the middle multifunction key and "+" volume key together for some seconds) will now start blinking again (in a 3 sec interval approximately).
Your handsfree is now connected, do a test call and confirm.
In case you find any volume problem, then know that the default volume after connecting a bluetooth handsfree is at low level, so just increase it using your Phone's volume keys/ controls and it shall be all fine.
Vote up if it helps, it is the genuine solution of this problem though; I tested it several times. :)
PS: I'm writing this while logging off in haste, pardon any spell/ typo mistakes. :P
Jun 26, 2011 | Cell Phones
How can i connect bluetooth ce0681 to nokia n95
2. Put it into "shown to all" mode.3. Now pick your bluetooth device, and simultaneously click on the multifunction key (The middle one that blinks) and the "+" volume key for around 6 seconds or more; you'll see that blue blinking light will become static (and it means that your bluetooth device is now "Searchable" by your phone).
4. Start "Pair new device search" from your Mobile, and your Phone will find the bluetooth device.5. It will ask you for a passcode, just enter 0000.6. Pair both devices now.7. The static blue light (Which became static when you pressed the middle multifunction key and "+" volume key together for some seconds) will now start blinking again (in a 3 sec interval approximately).
Jan 21, 2011 | Nokia N95 Cellular Phone
How to connect a bluetooth headset with nokia5230?
You need to switch on the bluetooth in both device then search the device in your phone ,same time while you searching in your phone press the button repeatedly in your bluetooth headset.Then device will found in the phone and connect it.
Thanks Fixya team
Sep 29, 2010 | Nokia 5230 Cell Phone
How do i fix the static on my bluetooth headset
Well yea but what if it doesnt have a volume control...my model is a quikcell BOLT mini auricular headset
Jul 22, 2010 | Motorola Mobility Q Bluetooth Headset...
When I am talking to someone on the phone i get a lot of static.
see what TTY mode your phone is in. TTY mode is under call settings or go to voice command and say TTY mode. I keep mine off. This mode is for people who are deaf, and people who are hard of hearing and use hearing aids.
Dec 12, 2009 | Plantronics Discovery 925 Bluetooth...
Need to find process to put Anycom HCC-250 device into discovery mode for pairing.
the device must be off. push the power button for at least 6 seconds until the lights turn on blinking red and blue. then you may start in searchmode with your desired device.
Connection code is 0000
Nov 20, 2009 | Anycom HCC-250 Bluetooth Headset
My LG cookie is not able to detect the Nokia Bluetooth headset
Sorry if you have done this but let's see if we can get you connected!
On your Nokia headset press and hold the multi-function key for roughly 8 seconds. Your green light will begin to flash quickly. Your Bluetooth headset is now in pairing mode.
Now using your LG Cookie, press Menu > Settings > Bluetooth > Search
Once found, you will need to type the pass code which is normally set as four zeros (0000).
You should now be connected.
We hope this helps!
Jul 03, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
How to set up bluetooth
go into bluetooth menu and get phone to search for the headset, have the headset turned on, and make sure it is in pairing mode. The instructions should tell you how to do this.
Jan 11, 2008 | Motorola Mobility H350 Wireless Headset
Televison & Video Logo
Top Supersonic Televison & Video Experts
Computer Repairing
Computer Repairing
Demonic-2011
Demonic-2011
Are you a Supersonic Televison and Video Expert? Answer questions, earn points and help others
