Question about Autodesk AutoCAD 2010 Full Version for PC (001B141A1111001)
Where to find adlmint.dll - Autodesk AutoCAD 2010 Full Version for PC (001B141A1111001)
Windows 7 Media Player 12.0.7601.17514 configuration setting are corrupted and remain corrupted after resetting the Media Player to its default settings. How do I completely rebuild the default Media
You may be able to remove then put back WMP from Programs and Features in Control Panel. Click on add/remove features and you should see it there. Uncheck the box and apply. Restart afterwards then check the box and apply. May require another reboot.
Jan 14, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Unable to initialize adlm
Unable to initialize adlm error after uninstalling Service Pack for 2014...
Solution:
There are 2 solutions available, either of them can help you to resolve the license issue.
Option #1:
Uninstall and reinstall the Service Pack (any of the Service Pack if you have more than one) that you want to keep. This will restore the mismatched file versions to the correct one.
Option #2:
Copy and replace files manually
1. Download the LicenseCrash.zip attachment below, unzip to your local drive, and then unzip the 32-bit or 64-bit package according to your platform.
2. Unzip the package
3. Close all running Autodesk products
4. Stop the FlexNet Licensing Service from the Task Manager:
  • Click Start ? Run
  • Type taskmgr and the Windows Task Manager will open.
  • In the Windows Task Manager, on the Services Tab, right-click FlexNet Licensing Service ? Stop Service.
5. Replace the following 5 files from the unzipped folder into the following locations:
a. Replace adlmact_libFNP.dll and adlmact.dll with the ones (version 11.11.0.3 and 7.0.51.100) in the unzipped folder.
b. Replace adlmint_libFNP.dll and adlmint.dll with the ones (version 11.11.0.3 and 7.0.51.100) in the unzipped folder.
Note: Most products put this file under the root folder of "\Program Files\Autodesk\#Product name#\" i.e. AutoCAD2014, but some other products put this file under subfolder, i.e. Inventor /Alias in \Program Files\Autodesk\#Product name#\Bin folder.
c. Confirm and if necessary replace FNPLicensingService.exe with the one in the unzipped folder to avoid file version incompatible issue.
6. Launch your products.
Mar 20, 2011 | Autodesk AutoCAD 2010
When I right click on a website that is sent to me in my email, I choose, open in a new tab or window, I get this message on many of the links to websites sent to me by email. oops Internet Explorer could...
Dear klaireh,
Follow this steps to resolve the problem with opening links in outlook .
(In this resolution we are going to register the DLL files for the internet explorer and outlook )
1. Copy the whole command line below and paste it in a notepad .
2.Save the file as internet.bat
3.Right click on the file and click RUN AS ADMINISTRATOR
cd /d %SystemRoot%\system32
regsvr32 comcat.dll /s
regsvr32 shdoc401.dll /s
regsvr32 shdoc401.dll /i /s
regsvr32 asctrls.ocx /s
regsvr32 oleaut32.dll /s
regsvr32 shdocvw.dll /I /s
regsvr32 shdocvw.dll /s
regsvr32 browseui.dll /s
regsvr32 browseui.dll /I /s
regsvr32 msrating.dll /s
regsvr32 mlang.dll /s
regsvr32 hlink.dll /s
regsvr32 mshtml.dll /I /S
regsvr32 mshtmled.dll /s
regsvr32 Wininet.dll /I /S
regsvr32 msjava.dll /S
regsvr32 urlmon.dll /s
regsvr32 softpub.dll /S
regsvr32 wintrust.dll /s
regsvr32 initpki.dll /s
regsvr32 Dssenh.dll /s
regsvr32 rsaenh.dll /s
regsvr32 Gpkcsp.dll /s
regsvr32 sccbase.dll /s
regsvr32 Slbcsp.dll /s
regsvr32 plugin.ocx /s
regsvr32 sendmail.dll /s
regsvr32 scrobj.dll /s
regsvr32 mmefxe.ocx /s
regsvr32 corpol.dll /s
regsvr32 jscript.dll /s
regsvr32 msxml.dll /s
regsvr32 msxml3.dll /s
regsvr32 mssip32.dll /s
regsvr32 imgutil.dll /s
regsvr32 thumbvw.dll /s
regsvr32 cryptext.dll /s
regsvr32 rsabase.dll /s
regsvr32 inseng.dll /s
regsvr32 iesetup.dll /i /s
regsvr32 cryptdlg.dll /s
regsvr32 actxprxy.dll /s
regsvr32 dispex.dll /s
regsvr32 occache.dll /s
regsvr32 occache.dll /i /s
regsvr32 iepeers.dll /s
regsvr32 urlmon.dll /i /s
regsvr32 cdfview.dll /s
regsvr32 webcheck.dll /s
regsvr32 mobsync.dll /s
regsvr32 pngfilt.dll /s
regsvr32 licmgr10.dll /s
regsvr32 icmfilter.dll /s
regsvr32 hhctrl.ocx /s
regsvr32 inetcfg.dll /s
regsvr32 tdc.ocx /s
regsvr32 MSR2C.DLL /s
regsvr32 msident.dll /s
regsvr32 msieftp.dll /s
regsvr32 xmsconf.ocx /s
regsvr32 ils.dll /s
regsvr32 msoeacct.dll /s
regsvr32 inetcomm.dll /s
regsvr32 msdxm.ocx /s
regsvr32 dxmasf.dll /s
regsvr32 l3codecx.ax /s
regsvr32 acelpdec.ax /s
regsvr32 mpg4ds32.ax /s
regsvr32 voxmsdec.ax /s
regsvr32 danim.dll /s
regsvr32 Daxctle.ocx /s
regsvr32 lmrt.dll /s
regsvr32 datime.dll /s
regsvr32 dxtrans.dll /s
regsvr32 dxtmsft.dll /s
regsvr32 WEBPOST.DLL /s
regsvr32 WPWIZDLL.DLL /s
regsvr32 POSTWPP.DLL /s
regsvr32 CRSWPP.DLL /s
regsvr32 FTPWPP.DLL /s
regsvr32 FPWPP.DLL /s
regsvr32 WUAPI.DLL /s
regsvr32 WUAUENG.DLL /s
regsvr32 ATL.DLL /s
regsvr32 WUCLTUI.DLL /s
regsvr32 WUPS.DLL /s
regsvr32 WUWEB.DLL /s
regsvr32 wshom.ocx /s
regsvr32 wshext.dll /s
regsvr32 vbscript.dll /s
regsvr32 scrrun.dll mstinit.exe /setup /s
regsvr32 msnsspc.dll /SspcCreateSspiReg /s
regsvr32 msapsspc.dll /SspcCreateSspiReg /s
exit
Sep 20, 2010 | Microsoft Internet Explorer 8
I cant update my computer. i receive error 0x80070424. im running vista home premium
Some spyware, adware, viruses block the windwows update sites.
If this doesn't work
The above explanation was for a previous Version of BITS but, there has been
an update for BITS since Vista came out.
<http://support.microsoft.com/kb/939159>
Is BITS disabled ? It can be set to Manual and the system will update
successfully but, will not update if BITS is Disabled.
Suggest you run the BITS Repair Tool to see if that helps resolve the issue
after installing the update for it:
<http://support.microsoft.com/kb/940520>
Ensure you do not have "Vundo". Clean it up if you do.
It seems possible that your Windows installation has been deliberately
damaged by a trojan (Vundo, along any uninvited guests. (SDBot and ZLOB, all
protected by a rootkit.)) so as to prevent you updating your system or
removing the trojan.
Your first priority must be to cleanse your PC of all malware.
A very good antimalware app is SUPERAntiSpyware.
There is a free version (on demand scanning only), the paid for version
includes active monitoring, similar to Windows defender:
<http://www.superantispyware.com/>
The trial version of SUPERAntiSpyware Pro (SAS):
<http://www.superantispyware.com/superantispywarefreevspro.html>
Can't fix BITS - Windows Update
<http://www.microsoft.com/communities/newsgroups/en-us/default.aspx?&lang=en&cr=US&guid=&sloc=en-us&dg=microsoft.public.windowsupdate&p=1&tid=307d2 1a2-eb9a-4859-b139-78997305deff&mid=307d21a2-eb9a-4859-b139-78997305deff>
This will give you a starting point for your troubleshooting anyway.
Please let us know if the problem remains
I hope this helps (it should)!
Download this "Update for Background Intelligent Transfer Service (BITS) 2.0 and WinHTTP 5.1 (KB842773)"
from link below
http://www.microsoft.com/downloads/details.aspx?FamilyId=B93356B1-BA43-480F-983D-EB19368F9047&displaylang=en
It should fix your problem if you are using Genuine Windows.
Dec 27, 2009 | Acer Aspire 5720 Notebook
Problem with accessing and sending mail from yahoo account
Re-register the following .dll files:
Softpub.dll
Wintrust.dll
Initpki.dll
Dssenh.dll
Rsaenh.dll
Gpkcsp.dll
Sccbase.dll
Slbcsp.dll
Cryptdlg.dll
To re-register these files, follow these steps:
1.
Click Start, and then click Run.
2.
In the Open box, type cmd , and then click OK.
3.
At the command prompt, type the following lines and press ENTER after each line:
regsvr32 dssenh.dll
regsvr32 rsaenh.dll
regsvr32 gpkcsp.dll
regsvr32 slbcsp.dll
4.
Click OK when you receive the message that DllRegisterServer in FileName succeeded.
5.
Type exit .
Mar 23, 2009 | Microsoft Windows Vista Business Edition...
Trojan - antivirus-xp-pro-2009
Take my notes as a guide and hopefully this will work for you.
1. Start > Run > msconfig > “Start Up” tab > Disable All
2. “Services” tab > Check box “Hide Microsoft Services” > Disable All
2.5 Exit out, but don't reboot yet
3. Start > Right-click “My Computer” > “Properties” > “System Restore” > Check box “Turn off restore on Hard disks”
4. Start > Run > type %temp% > Edit Select All > Shift-Delete
Reboot machine
1. Combofix.exe. This program will run on its own. Also, it will likely wish to reboot the machine. Let it complete.
http://download.bleepingcomputer.com/sUBs/ComboFix.exe
2. WinSockFix.exe. This will fix any issues with the network connection.
3. SuperAntispyware.exe. This will remove all remaining spyware, tracking cookies, and browser hijackers.
Check to see that your favorite internet browser is working. Install or re-enable your favorite antivirus that failed to catch this in the first place.
Stop WinAntiVirus2008 Processes:
mav_startupmon.exe
uwa7pcw.exe
rtasks.exe
WinAv.exe
wa7pinst.exe
Remove WinAntiVirus2008 Registry Values:
2178F3FB-2560-458f-BDEE-631E2FE0DFE4
6F520BE0-9B54-4558-816F-224E67997DF3
459F4226-1AAB-43B6-9DC1-B6313EF83749
1AC5C88A-DEA7-462b-A232-04AF5CA42E7E
723D54C7-7483-4EB8-8EED-CE5B2AEA534D
Find and Delete these WinAntiVirus2008 Files:
WinAntiVirus Pro
WinAv.exe
uwa7pcw.exe
mav_startupmon
mav_startupmon.exe
rtasks
rtasks.exe
wa7pinst.exe
IH.exe
WinAntiVirus Pro.lnk
Reinstall or Uninstall WinAntiVirus Pro.lnk
WinAntiVirus Pro Manual.lnk
WapCHK.dll
rpt.dll
awvtr.dll
yayyvsp.dll
fcyxx.dll
gebxyax.dll
asmngr.dll
fopnl.dll
IEFWBHO.dll
Scnkrnl.dll
settings.dll
sqlite3.dll
WAV6COM.dll
winpgi.dll
BORLNDMM.dll
SCANADWR.dll
SCANBCDR.dll
SCANLDR.DLL
SCANDOS1.dll
SCANEMUL.dll
SCANFUNC.dll
SCANMCRL.dll
SCANOTHR.dll
SCANSCR.dll
SCANTOOL.dll
SCANTROJ.dll
SCANWIN1.dll
UNACPU.dll
UNADBX.dll
unamscan.dll
UNMIME.dll
UNPACK.dll
UNPACKS.dll
UNPACKS2.dll
UNPEPACK.dll
Vista
Stop WinAntivirus2008 Processes:
(Learn how to do this)
WinAntivirus2008.exe
mav_startupmon.exe
uwa7pcw.exe
rtasks.exe
WinAv.exe
wa7pinst.exe
Find and Delete these WinAntivirus2008 Files:
%UserProfile%\Desktop\Viruses.bdt
%UserProfile%\Desktop\WinAntivirus2008.lnk
c:\Program Files\WinAntivirus2008
c:\Program Files\WinAntivirus2008\Viruses.bdt
c:\Program Files\WinAntivirus2008\VRM2008.exe
c:\Documents and Settings\All Users\Start Menu\Programs\WinAntivirus2008
c:\Documents and Settings\All Users\Start Menu\Programs\WinAntivirus2008\WinAntivirus2008.lnk
%UserProfile%\Application Data\Microsoft\Internet Explorer\Quick Launch\WinAntivirus2008.lnk
%UserProfile%\Application Data\Mozilla\Firefox\Profiles\s1jqw0bz.default\cookies.sqlite
WinAv.exe
uwa7pcw.exe
mav_startupmon
mav_startupmon.exe
rtasks
rtasks.exe
wa7pinst.exe
IH.exe
WapCHK.dll
rpt.dll
awvtr.dll
yayyvsp.dll
fcyxx.dll
gebxyax.dll
asmngr.dll
fopnl.dll
IEFWBHO.dll
Scnkrnl.dll
settings.dll
sqlite3.dll
WAV6COM.dll
winpgi.dll
BORLNDMM.dll
SCANADWR.dll
SCANBCDR.dll
SCANLDR.DLL
SCANDOS1.dll
SCANEMUL.dll
SCANFUNC.dll
SCANMCRL.dll
SCANOTHR.dll
SCANSCR.dll
SCANTOOL.dll
SCANTROJ.dll
SCANWIN1.dll
UNACPU.dll
UNADBX.dll
unamscan.dll
UNMIME.dll
UNPACK.dll
UNPACKS.dll
UNPACKS2.dll
UNPEPACK.dll
Remove WinAntivirus2008 Registry Values:
5222008A-DD62-49c7-A735-7BD18ECC7350
HKEY_CURRENT_USER\Software\WinAntivirus2008
WinAntivirus 2009
# 1. Find and Remove the following Antivirus 2009 Processes:
* av2009.exe
# 2. Find and Remove the following Antivirus 2009 files and folders:
* C:\Program Files\Antivirus 2009
* C:\Program Files\Antivirus 2009\av2009.exe
* c:\WINDOWS\system32\scui.cpl
* c:\WINDOWS\system32\winsrc.dll
# 3. Find and Remove the following Antivirus 2009 files and folders:
* HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\ CurrentVersion\Run\15358943642955870504508370025739
Mar 06, 2009 | Microsoft Windows XP Home Edition Service...
Internet explorer raised unhandled exception in third party module IE will not start and the below call stack pops up every time. BASE:16940000,001B:1699D18C WINUTIL5.DLL,...
hi there,
it seems u got a big problem with ie7,
this is what is get right : Internet Explorer Unhandled Exception
> Internet Explorer raised unhandled exception in third party module and
> should be closed. We are sorry for inconvinience.
> Extended Exception Information
> Module: urlmon.dll
> Version Info: UNICODE; v.4, 0, 2, 3
> Call Stack:
> BASE:7E1E0000,001B:7E21B5CE urlmon.dll
> BASE:7E1E0000,001B:7E1F3FD9 urlmon.dll
> BASE:7E1E0000,001B:7E2150F2 urlmon.dll
> BASE:7E1E0000,001B:7E203342 urlmon.dll
> BASE:7E1E0000,001B:7E1FCD5C urlmon.dll
> BASE:7E1E0000,001B:7E1FCD32 urlmon.dll
> BASE:7E1E0000,001B:7E1FCB8C urlmon.dll
> BASE:7E1E0000,001B:7E1FCB69 urlmon.dll
> BASE:7DC30000,001B:7DE84E02 mshtml.dll
> BASE:7DC30000,001B:7DD69D68 mshtml.dll
> Restart Internet Explorer Close
there is a simple solution for that just follow these steps and than all will go good
I would recommend resetting it to it's default state. This usually takes care of any problematic plug-ins. below has details on how to do this.
1. Click the Tools menu, and then select 'Internet Options.
2. Next, click on the Advanced tab to the far right and click Reset.
3. Another dialog box will then open up, click Reset.
4. Once IE7 is done restoring to the default settings, click Close and then OK.
5. Close any browsers you may have had open and restart it. Everything should now be reset to the default.
or for just click this link and than click on download and run ie7 new
Dec 18, 2008 | HP Pavilion dv6000z Notebook
Videos
try this works for me
Fixing Internet Explorer Javascript Links
Sometimes in IE when you try to open links that open in new windows, they don't open. At the bottom left of the IE window you will see a yellow triangle which indicates its a Javascript problem.
  1. Start » Run » Type regsvr32 /s URLMON.dll
  2. Then do the same but change the DLL names to the following:
    scrrun.dll
    Msxml.dll
    Mshtml.dll
    Shdocvw.dll
    Browseui.dll
    Msjava.dll
    Actprxy.dll
    Jscript.dll
    Vbscript.dll
    oleaut32.dll
  3. Restart IE and your links should be fine.
  4. Alternatively you can copy this in to a text file and save it as a batch file (.bat file)
    regsvr32 /s scrrun.dll
    regsvr32 /s Msxml.dll
    regsvr32 /s Mshtml.dll
    regsvr32 /s Shdocvw.dll
    regsvr32 /s Browseui.dll
    regsvr32 /s Msjava.dll
    regsvr32 /s Actprxy.dll
    regsvr32 /s Jscript.dll
    regsvr32 /s Vbscript.dll
    regsvr32 /s oleaut32.dll
  5. This will re-register all the DLL files. All of the above are used by IE.
Oct 11, 2008 | YouTube Videos
Windows xp updates
Why don't you try using this website, Reimage.com - its mainly for power users and PC repair professionals.
Jan 26, 2008 | HP Officejet 4215 All-in-One Color Photo...
Autodesk AutoCAD 2010 Full Version for PC (001B141A1111001) Logo
49 people viewed this question
Top Autodesk Computers & Internet Experts
JM Computer Service
JM Computer Service
Jerry
Jerry
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
