Question about Bugatti Diva Espresso Machine
To break all the coffee pot
It breaks my bag of coffee, why this happens? I could not prepare any express, the water emerges then breaks and coffee powder spreads.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Adjust prong to shallow depth
Posted on Dec 29, 2013
My coffee maker takes a long time to brew
Pour 2/3 water and 1/3 white vinegar into it and with the basket empty hit brew. Watch the lime and scale build up come out of it. Initially it will look like small rocks but they will further break down in the pot. Upon completion run 2 additional pots of fresh water through it. If it is still slow repeat the process.
Oct 09, 2017 | Coffee Makers & Espresso Machines
I am not able to get any coffee through the coffee dispenser. It just fills the overfill tray and leaks from under the machine onto the counter. Any idea what the cause is and how it can be resolved?
Try running a mixture of 1/4 cup Apple cider vinegar in a pot of water then flush with pots of cold water until no more vinegar odor. This immediately breaks through hard water scale buildup. You may also have a bad seal if it is leaking. You can get a repair kit from Mr. Coffee or if you have a Bunn, they have lifetime guarantee. You can return for repair, or request repair kit by contacting them
Jan 23, 2015 | Coffee Makers & Espresso Machines
Hi guys I have saeco idea and it says maintenance caf any got idea what that is , thanks.
It probably needs a cleaning. Run 1 pot of white vinegar through it just like where you fill it with water. But do not use any water. Then run 2 full pots of water through it to clean out the vinegar. Warning do put cold water into a hot glass pot or it could break. If it has a filter for the water, change it with a new one.
Jun 09, 2014 | Coffee Makers & Espresso Machines
How do i clean my stainless steel krups coffee maker before use model kt 611d50
Just run one full pot of cold water through it. Do not add coffee. Then it is ready for use. Caution - Do not make coffee right away because you can break the glass carafe by adding cold water to a hot carafe. Also the hot plate would be very hot too.
May 30, 2014 | Krups FME2 Coffee Maker
How do you use loose tea to make tea in a pot?
You can use steel pot to make a Tea, do you know Loose tea is very simple to make.
If you will use steel pot that is easy to hold and keep.
Feb 27, 2013 | Home
Cleaning the staining & coffee from a one-year old 4 cup coffee pot.
You can try salt and ice. Try pouring about a tablespoon of salt into the pot and a couple ice cubes. Hold the pot by the handle and swirl it around in a counter clockwise direction allowing the ice to move around the inside of the pot. Don't do it too fast, you could break the pot.
Sep 19, 2011 | Computers & Internet
The water isn't fully coming out when brewing a cup of coffee and won't fill the cup. I am maybe getting 1/4 cup of coffee
what you will have to do to solve this problem is that you will have to do self cleaning on the coffee maker
however, (not the bathroom one) is a handy item to use to clean coffee residue off the inside of a glass coffee carafe.
  • Does your pot have hard to reach areas? Use a wooden chopstick with a paper towel to get in there.
  • You can put ice cubes and a little water(enough so you can swirl it around) in pot and swirl them around, for harder stains put some table salt in pot and swirl it around for a few minutes and then rinse.
  • Put a glass marble in the water chamber to attract mineral deposits from hard water. Wash it once a week.
  • For tough stains, scrub the pot using a paper towel or clean (not soapy) dish towel. Rinse thoroughly.
  • To clean just the pot, do what many restaurants do. Put about two cups of ice, 1/4 cup of rock or table salt, and 1/4 cup of lemon juice (bottled or fresh is fine) and swirl around the pot. Measurements are not that important, just guesstimate. Be sure that the pot is cold before you try this, or you may break the glass pot.
  • Clean a brand new coffee pot prior to using it for the first time.
  • Never use the coffee pot to pour water into the reservoir. This will transfer oils and impurities from the pot, and eventually give the coffee a nasty taste. Instead, use a pitcher that is reserved for water only.
  • To keep the inside area around basket, filter, lid area clean (from coffee ground spatter) simply place a SECOND filter over the top of the grounds in the FIRST filter. Push second filter down so that spout will clear top of second filter (on many makes of coffee makers) as lid is closed. This keeps interior in pristine condition and doesn't take much time or expense.
Thanks for visiting our site good luck.
Oct 15, 2010 | Keurig B70 Coffee Maker
Pumping more water out than what i put in
This coffee maker uses a resevoir tank system - the water you pour in pushes out water that is already heated - the water you pour in won't actually be used for that pot of coffee! For that reason you should only use full pitchers when filling. You may need to cycle through 2 or 3 fillings before the input matches the output once more. The capacity of the resevoir is about 3 pitchers; you can brew 2 pots in a row before the machine needs a break to bring the resevoir back up to temperature.
Nov 12, 2008 | Bunn VPR Coffee Maker
Cuisinart dgb-500 automatic grind & brew
You have not missed anything. Unplugging for longer than 16 minutes (has 15-minute memory) is the only troubleshooting you can perform. Call Cuisinart to find out if you are still in warranty. All electronics have a failure rate. Cuisinart's is acceptably low, but their coffee makers are the least reliable of all their products. The basic problem with electronic coffee makers is that coffee makers produce high heat, and high heat kills electronics and melts plastic. At least Cuisinart has a 3-year warranty - higher than the industry standard.
Let me put it another way. All coffee makers have a high failure rate. As many Cuisinart coffee makers that break down, the non-Grind-and-Brews still have a 91 rating from Consumer Reports. Consumer Reports doesn't give ANYTHING a 91 rating. A lot break, but you probably won't fare much better by switching to a different brand. The problem with a Cuisinart breaking down is that an expensive unit broke down - you wouldn't be upset if your $15 Mr. Coffee broke every year. The law of averages is on your side - a 2nd Cuisinart will probably last longer.
-Tha Mp3 Doctor
Jun 11, 2008 | Cuisinart DGB-500 Coffee Maker
Bugatti Diva Espresso Machine Logo
65 people viewed this question
Top Bugatti Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Bugatti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
