Question about Paradigm PDR 12 Speaker
Paradigm pdr80 no sound
After 2 years of use my subwoofer stopped making sounds. I have an onkyo system with a paradigm pdr 80 subwoofer. The light on he subwoofer still lights up, but I get absolutely no sound out of it. I have checked the system settings and tried re calibrating, but nothing has worked. I have changed the wired connection and double checked its continuity and still no sound. Any advice what to do?
    Top Expert:
  • Paradigm Master
  • 34,821 Answers
If it is a powered sub, the sub power supply may have failed. There might be an open fuse.
Posted on Dec 26, 2013
2 Suggested Answers
SOURCE: PDR-10 subwoofer has no output. 120vac to unit is
I have exactly the same situation with my PDR-10. Paradigm techs were of no help, don't me to take it to a service centre which i did. Of course when it was there they plugged it in and it stayed on for a day and a half so no problem right? Get it home, nothing, plugged and replugged, got it on once but not for long. Opened up back, everything including fuse looks solid and fine....to naked eye anyhow.
Posted on Jan 19, 2010
How do I stop my Paradigm sub from humming and "burping?"
The amplifier that powers the sub is the source of your problems. Sounds like some power supply filter capacitors are failing.
Dec 31, 2014 | Paradigm Audio Players & Recorders
Subwoffer will not power up
PDR-8 Specifications
Design
Single driver, bass reflex system with critically tuned resistive port and built-in amplifier Amplifier High-current, discrete output, 90 watts RMS
Amplifier Features Soft clipping, thermal protection Frequency Response On-Axis 29Hz - 150Hz Low Frequency Driver 210mm (8 in) extended travel with 38mm (1-1/2 in) voice-coil, aluminum former Low Frequency Extension 29 Hz (DIN) Finishes Black Ash, Light Cherry, Dark Cherry Inputs From A/V receiver/processor or Paradigm X-Series Subwoofer Control Unit mono-sub out or preamp left/right output;From receiver/amplifier speaker terminals or main/satellite speaker terminals Weight 25 lbs. (11 kg) Dimensions HxWxD 13.25" × 9.75" × 15"
(34cm × 25cm × 38cm)
Specifications are subject to change without notice.
© 2016 Paradigm Electronics Inc. Conditions of Use Privacy Policy Unauthorized Dealers WARNINGSouth Africa
Dec 26, 2013 | Paradigm PDR 8 Subwoofer
I have a 110v power input Paradigm PDR10 and would like to convert it to 220/240. I'm sure it's a case of change the series connection to parallel on the transfomrer but I'm not sure the exact functions...
I have the same problem. An external transformer would step down the voltage, but it wouldn't help with the frequency, which would still be 50Hz. Paradigm says there's a risk of burnout if an unmodified PDR-10 is run at 50Hz rather than 60Hz
Oct 16, 2010 | Paradigm PDR 10 Speaker
Paradigm 5.1 to 7.1 system
The Dolby curcuit in the Paradigm must be Dolby 7.1 or it will simply not be able to send the extra channel signals to the speakers. In otherwords you will not get the full 7.1 sound from two speakers added to a 5.1 amp.
Feb 15, 2010 | Audio Players & Recorders
Dec 20, 2009 | Paradigm PDR 10 Speaker
Hum coming out of Front left/right speakers but not center
There is a chance that your wiring is producing this problem. Manufacturers don't always make equipment that is compatible with each other. The biggest problem's are "ground loops". Radio Shack has a non-electrical device that separates the common ground from all equipment. You basically connect it between your amp out's and in's - cables included. It is possible that other manufactures also make and sell this device too. It's main "Google" name would most likely be - "Ground Loop Isolators". If you are using the actually speaker outputs into your subwoofer amp input(s), check your polarity wiring again. Good luck with your system - it sounds like it'll rock when it's all setup correctly.
Nov 06, 2008 | Paradigm PDR 12 Speaker
Power problem with Paradigm PDR 10 Subwoofer
Yes it can be.You can check it with ohmmeter the impedance should be 4 or 8 ohms.But if you can disassembly the sub its better then you can see and check everything.My guess is that one of the cables on the speakers connector is broken and its just touching the conntact.
Mar 08, 2008 | Paradigm PDR 10 Speaker
Power Indicator Light on Front Doesn't Light
The indicator light needs to be replaced, there is a loose or poorly soldered connection on one of the led's leads, or the circuit providing the signal (voltage) for the light isn't functioning.
Sep 17, 2007 | Paradigm PDR 10 Speaker
Paradigm PDR-10 Sub Box
Since this is a sub I assume the sound is not coming from the speaker but is mechanical and coming from the amp in back. The tranformer can be the problem if it has delaminated or may be loose. Try removing the amp and tightening the screws. If there are rubber grommets to isolate the tranformer don't overtighten. www.pardigm.com for contact info and parts. They are very nice. If the noise is coming from the speaker then you are still under warrantee and they will replace it free.
Sep 28, 2006 | Paradigm PDR 10 Speaker
Paradigm PDR 12 Speaker Logo
221 people viewed this question
Top Paradigm Audio Players & Recorders Experts
 Grubhead
Grubhead
woodzowl307
Are you a Paradigm Audio Player and Recorder Expert? Answer questions, earn points and help others
