Ixhave amemorex dvd player recived from friend keeps reading wrong disc or loading for long periods
  • 1,511 Answers
If a DVD has been cloned the speed and angle of the laser may not be compatible with the players read head. If you are using Commercial DVD's then the alignment is standard and should work OK. If the player is CD\DVD only you cannot play Blu-ray discs.
Posted on Dec 25, 2013
SOURCE: WRONG DISC
it is the internal lazer light. if you communicate with coby they will fix it . it seems to happen quit often ed
Posted on Feb 02, 2007
SOURCE: tf-dvd7005
hit the piece of shit with a sledgehammer
Posted on Jan 05, 2008
SOURCE: My portable dvd player won't load any dvds anymore
lachallep,
The solution for your problem will be needing a little knowledge with electronic repair and hands on.Most common problem for portable DVD player is their 1) Spindle motor the 2) flex cable ( tin ribbon wire connecting the optic lens and the main board)
note: to check if your spindle motor is working good, you must measure it's resistance and it should be around 200ohms.
For the flexcable all you have to do is check the continuity.
cheers.
mark
Posted on Jan 16, 2009
stonephoenix
  • 563 Answers
SOURCE: wrong disc error
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Unfortunately, if the player will no longer read any commercial dvd that you attempt to play, the unit is defective and needs to be replaced. The unit has a 90 day warranty from the date of purchase. You will need the receipt in order to receive a warranty exchange.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Posted on Feb 05, 2009
stonephoenix
  • 563 Answers
SOURCE: "Wrong Disc" error message
I work for COBY tech support. Our customer service phone number is 1-800-727-3592.
Unfortunately, if you're getting that error message on every disk you try to play, it means the player has developed a problem in the dvd mechanism. This can't be repaired.
The warranty is 90 days from the day of purchase. A receipt would be required for warranty exchange.
While this solution doesn't "fix" your problem, I hope that by giving you the facts, I've enabled you to make an informed decision as to what to do next.
Please let me know if I can assist you further.
Posted on Apr 17, 2009
I don't know if my first REQUEST for Assistance was received, at any case, I REQUESTED to find WHY my GO.VIDEO COMBO Player is NOT READING any of my blank DVD DISC( SONY, IMATION, MEMOREX, DVD+R ), IT KEEP...
If there is nothing on the disc, it will read, "no disc". It will only read and/or identify discs with media loaded or burned onto it. Your unit is a player, not a DVD+R (recorder). Can record VHS, but not discs.
Jun 30, 2010 | GoVideo Go Video DVD/VCR Combo
I keep getting wrong disc error on my Daenyk DVD player and do not understand why I have played these DVDs on it prior and no Problem
The reason the player keeps giving you wrong disc error is because the player is not reading the disc.
the reason is either the lens is dirty or weak.
To test if the lens is dirty, try to clean the lens with a lens cleaner and test the player DVD disc.
To fix it if the lens is weak, open the player with the appropriate screwdriver, open the disc tray, and replace the lens with a new lens, test it with a DVD disc.
Take care
Jun 14, 2010 | Televison & Video
Keeps saying wrong disc
first i downloaded the manual and read it through... it mentioned wrong disc but did not give any solution so i rang Teac and they told me it was a malfunction and by the time i paid for them to look at it i could buy a new dvd..... so i am going to buy a new dvd..... not really a solution but the only one available
Jul 06, 2009 | Teac DV-3500 DVD Player
Wrong disc problem
This is a known problem - there is no fix - if you call coby customer service they will tell you to try a dvd lens cleaner -this will not fix the problem. Best advise - throw it away.
Feb 26, 2008 | Coby DVD-224 DVD Player
No Disc keeps popping up
yes , the eye is not reading correctly, if it is still under warranty i'd have the factory replace it, if not , any tv repair place can help u out, hope this helps jason
Dec 28, 2007 | Sampo DVE-620 DVD Player
Dvd not reading
The spindle motor magnets have started to flake, causing the DVD's to slip. like on a slip mat. You need to take the cover off and remove the flaky magnetic particles on the magnets that clamp onto the DVD's. You can put a very light coat of rubber cement on the lower magnet and let it dry completely, this should give the lower magnet/spindle motor some traction on the disc and get it spooling up in the correct amount of time.
Dec 02, 2007 | Mintek DVD-2580 DVD Player
After loading every disc displayes "wrong disc'
are they bootleg dvd's? if not try getting a lense cleaner because wrong disc means it's reading your dvd's as .mov files which only play on quicktime in a computer. if it reads your cleaner as wrong disk too then get yourself a refund cuz it has a motherboard malfunction.
Dec 02, 2007 | Cyberhome CH-DVD 300 DVD Player
Nid help
Dear friend,
It's software problem.software corrupt in ur dvd player flash ic.
Aug 03, 2007 | JVC XV-N422S DVD Player
WRONG DISC
Aug 02, 2006 | Coby DVD-224 DVD Player
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
