Question about Vacuums
Gl1109 hoover globe twist and steer
Fix belt
How do I change the belt on my hoover twist and steer
Posted on Dec 27, 2013
  • mhardaker Jan 29, 2014
    Did you find the answer as I think I need a new belt for mine. I assume that is my problem as the brushes do not turn round.
HOW DO I CHANGE BELT ?
Hello! Below are step-by-step instructions for changing the belt on your Hoover S1147.
1. Rotate nozzle to the vertical position. Lift off front cover.
2. Remove the two bottom plate screws.
3. Pivot off bottom plate making sure to unhook center tab on inside edge of nozzle.
4. Remove agitator and used belt from nozzle.
5. Put new belt on agitator. Position agitator in nozzle orienting agitator end caps with slots on both sides of nozzle. The belt should line up with tab on inside of nozzle.
6. Attach belt to motor pulley.
7. Replace bottom place by first hooking it to center tab on inside of nozzle.
8. Reposition screws and front cover.
Hope this helps!
Jun 02, 2014 | Hoover S1147 Twist Vac Handheld Vacuum
How do i replace belt on zanussie 4720 hoover
http://hoover.com/support/video-instruction-guides/
proceed according with your model and see intructional videos for troubleshooting and fix it.
God bless you
Aug 02, 2012 | Vacuums
Beater bars won't turn
It is a really simple and cheap fix! All you need to do is replace the belt. You can get a replacement belt here:
Hoover Windtunnel Belts
Jan 10, 2010 | Vacuums
Brushes won't spin or turn by hand
It sounds like your belt is broken. You may also want to check and make sure that there is no debris (hair and whatnot) twisted around the brush roller.
Aug 20, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I have an older hoover vacuum and cannot figure out how to put the belt on?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=542813
Generic problem for all Vacuums
I have an older Hoover
Posted by rrunner on Apr 24, 2008
I have an older Hoover vacuum and cannot figure out how to put the belt on?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I am not sure how old your Hoover is but the old style the belt would change from the bottom and you would have to remove the bottom plate, lift out the brushroll and slide the belt onto the center of the brushroll, then look for the belt guide stamped right on the bottom of the vacuum and it will show you how to twist the belt in order for the belt to work, if the belt is on right you will have suction, if the belt is on wrong it will be blowing instead of having suction. If it is newer – you will have to remove the bottom plate or the top cover depending on the age of the vacuum and the belt will be on one side and the procedure is still the same – lift out the brushroll, slide the belt onto the brush, re-insert the brushroll into it’s position, then take a screwdriver or what I call a belt puller and stretch the belt onto the belt pulley then track / roll the belt and it will run straight and true. So, if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 24, 2008 | Vacuums
Hello I have a hoover vacuum cleaner, it's an older one model number 44535830.....I bought a new belt but have no idea how to put it on? can you help me
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=542810
Hello I have a Hoover
Hello I have a Hoover vacuum cleaner, it's an older one model number 44535830.....I bought a new belt but have no idea how to put it on? Can you help me?
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Replacement globes
You might try thehooverstore.com. There may some other on-line stores that you can buy parts from.
Apr 11, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Windtunnel
Your belt may be twisted inside-out. Be sure the printed marks on the belt face away from the pulleys and shaft. The printing should face you.
Oct 22, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
243 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
