Question about Ovens
How to self clean a andi oven and remove all baked on grease and food
4 Suggested Answers
SOURCE: Kenmore Ultra bake self cleaning oven is showing code E0 - F2
My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
Posted on Aug 27, 2009
Obertelli
  • 3006 Answers
SOURCE: I have baked on aluminun foil on the bottom of my
If the bottom of the oven is enamelled or has a pyrolytic self cleaning surface then you can use caustic soda to remove aluminium foil.
Many oven and hob cleaners contain caustic soda and those which do always advise that it's kept away from aluminium parts precisely because of it's effectiveness in turning aluminium into grey foamy goo!
If you're in doubt as to whether your oven floor is caustic soda resistant then try a small test patch first.
Please note that caustic soda is extremely corrosive so you'll need to keep your hands and arms covered and preferably use eye protection as well.
Posted on Sep 20, 2009
SOURCE: after self cleaning ge oven, door won't unlock
I turned off circuit breaker to the oven and tried to open it. It did not. I did it again and waited for a few minutes, it worked and I was able to open the door.
Posted on Aug 10, 2010
Is the fan on my oven broken or just needs cleaned?
It is most likely coated in grease, remove it and clean it first.
Mar 08, 2018 | Ovens
Viking oven locks up while baking. Cannot open oven door to remove food. What could be causing this problem?
Ovens usually lock when it thinks you are running the self-clean process. Unplug for 15 minutes and plug back in, if that fails call in service
Dec 12, 2017 | Viking Ovens
How to set oven to clean
hi Sue.
this is all i could find on the internet.or go to the link at the bottom.
Before starting the Self-Clean cycle:
  1. Remove the racks, unless they are labeled as "self-clean". ...
  2. Any excessive amount of spillover (juices or liquid grease) not baked-on should be wiped out with a wet cloth before running through a self-clean cycle.
More items...
Range - Tips for Self Clean - Products - GE Appliances
How to set oven to clean Google Search
Oct 31, 2017 | Ovens
I left silicone guard on grates and put on self cleaning. My oven is now filled with a white powder.
Thank you for your inquiry, Cheryl!
I understand that you left the silicone guard on the grates and turned on self-cleaning, now you have white powder inside of your Frigidaire range. This can be removed by using hot water, baking soda, and a non-abrasive cloth. It may take elbow grease in order to remove the white powder. I would recommend not using the oven until you have removed the white powder. I hope this information is helpful for you. -Matt
Apr 29, 2015 | Frigidaire 30" Self-Cleaning Freestanding...
White residue left after using self cleaning feature - I can't remove it with soap and water and elbow grease. What would work? This looks awful!!!
The residue your seeing is the remains of whatever was left in the oven when you decided to creamate in. Grease, food, etc was basically turned to has and then powder coated into the metal. Bit of advice for the future though, avoid using self clean mode not only for the scenario you have, but for your bank account as well. The temperatures the oven reaches in self clean exceed that of which the oven cavity can handle letting heat pass upward, usually damaging the lock mechanism for sure, as well as the control board and touchpad.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 23, 2012 | GE Profile JT952 Electric Double Oven
I have a new Frigedaire self cleaning oven. Before I got to read the manual my daughter baked a cake which dripped onto the oven floor and began to smoke. To catch more drips I put a pice of tinfoil on...
Greetings,
remove as much tin foil that is possible...use something like hot water and mild detergent to loosen up the baked on cake residue...this should come up ok with alittle elbow grease...then run your self clean cycle...All will be ok....Bruce Denton
Jan 20, 2011 | Frigidaire Ovens
Delonghi CT200 cleaning
hello,
Here are step of cleaning oven
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work; it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thanks.
    Oct 10, 2010 | Ovens
    I cleaned my self-cleaning oven yesterday and today it won't heat up. Can you help me out?
    hello,
    Here are solution on how to clean up your oven below.
    Self Cleaning
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • Thank for visiting.
    Oct 09, 2010 | Whirlpool Ovens
    Door won't open after self-cleaning cycle is complete
    Turns out that the latch is attached to a plastic piece (made by the manufacturer) and the spring melted! To boot, the fuse in the back which aids in heating the oven went out also. Repair man said this was typical after several uses in cleaning cycle. He recommended using a gentle steel wool pad with soap built in to gently remove backed on food instead of using cleaning cycle. It is just too hot for too long, and there seems to be a domino effect with things that will go wrong. Nothing like the old fashioned way and a little elbow grease!
    Mar 19, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
    How does self cleaning work on my frigidaire gas burner stove?
    Self cleaning would be better named... Running the oven real hot to burn off residue.. so in essence, the oven is locked out and then heat is raised to a high level to bake out grease and food byproducts so they either burn off or turn to ash for easier cleaning.. Does that make sense to you? Most self cleaning ovens lock out the user until the oven has cooled down to a safe user-friendly level..
    Nov 28, 2008 | Ovens
    Ovens Logo
    19 people viewed this question
    Top Ovens Experts
    ashburton
    Craig Butler
    Craig Butler
    Are you an Oven Expert? Answer questions, earn points and help others
