Question about Seiko Lorus LO111 Watch
Second hand not working on my new lorus watch
I have a Lorus LQQ603S-A and I need to know the battery size
Take your Lorus watch to a jeweler who will demonstrate how to open it and identify the battery type. The jeweler may even be persuaded to replace the battery for a reasonable sum.
Feb 20, 2018 | Lorus Watches
Lorus mens watch does not work despite fitting a new battery
its possible that the coil on the movement has been damaged.
i would adbise to take to a local store to get a price to replace the movement.
Feb 04, 2018 | Lorus Watches
Manual for Lorus mickey dual musical. V422-0010.where can I get one?
Try Googling (lorus)(V422-0010)(manual) without parens OR contact Lorus directly.
Feb 02, 2018 | Lorus Watches
Installed battery in lorus musical watch and nothing.
mcdevito75 here, A quartz mechanism can go bad just like a light bulb, depending on the watches age, wear etc. If your watch was stored for a period of time with a dead battery in it, that dead battery could hve leaked, ruining the mechanism. If your watch worked fine and the battery just went dead, make sure the battery contacts inside the watch are clean, use a Q-tip dipped in Alcohol and gently clean the battery contacts, press the button for the music part of your Lorus and make sure those contacts are clean and are meeting once the button is pressed, this you can see with the back cover off the watch. Makes sure the battery is installed correctly, and that the new battery number is the same as the old battery number. 364 and 371 are popular batteries for Lorus musical watches, even though your new battery is new, it can still be dead, who knows how long it was on the store shelf?? also, double check as some Lorus Musical watches have 2 batteries, 1 battery would be rather large ans sitting just under it"s hold down bracket see, as soon as you remove the back cover, if so, that battery must also be replaced. I have an old Mickey Lorus musical useing a 397 battery just 1 but my Lorus is burnt out. If all this fails, I would look for a small watch repair shop in your area and have them look at the watch for you.
Feb 18, 2011 | Watches
I just bought an older Lorus Disney Mickey Mouse Musical watch V422-0010 with a box behind this number thia square was around the letters ZO. I cannot get the watch to work. It says, "After installing...
There is no CR920 3 volt battery and especially will not work for any Lorus watch. There is the SR920SW and SR920W series 1.55 volt silver alkaline cell.. 9 mm diameter x 2.0 mm height is an impossible size for this old Lorus watch.
Jan 02, 2011 | Disney Lorus Rare Musical R2306AX Watch
My gold Mickey mouse Lorus watch was opened a part damaged by the person replacing the battery. This is not a digital watch, but has nthe mouse with hands and a second wheel at bottom.
You are probably going to have to look for an identical watch for parts.You might try this site:
http://www.esslinger.com/watchparts.aspx?gclid=COCr3t2F9KUCFcIKKgodgiARnA which is parts for watches. I'd have a look on ebay as well for a watch that is not working. Of course it does depend on the part you are looking for. I am also wondering if the inner parts for another Lorus mickey moue watch might fit, but maybe you don;t wish to change it out from the original.
Dec 17, 2010 | Disney Lorus Out of Production Collectible...
How to set the alarm on the lorus rf33bx9
If you put "lorus watches" into your search engine you should come up with the Lorus web site.
One of the options given is "instructions", click on this and you will be asked to enter details off the back of your watch.
Feb 11, 2010 | Bulova Watch
Have lost the screw to wind the watch it's a lorus chronograph 100mm. Where can I buy one? mtracey@flairinternational.com
You should be able to have one fitted by a Seiko authorized dealer.
Go to your nearest dealer and ask him to fit a new winder.
Feb 08, 2010 | Seiko Lorus LO111 Watch
I have a Lorus NX11A multifunction watch and have no manual. I have been on the Lorus website but it might as well be written in Japanese
mcdevito75 here, I would imagine this is a Mickey Mouse Lorus watch by the picture supplied. If it Has DAY / DATE function, here"s what to do, --- To set the DAY, pull the stem out to set, keep turning the hads till you rech the day, then push in the stem. To Change the DATE 9 number) slip your fingernail just under the stem and lift it to it"s first position (notch) this should allow you to change the DATE (number) without haveing to turn the hands so many times.
Jun 24, 2009 | Disney Lorus Out of Production Collectible...
Seiko Lorus LO111 Watch Logo
15 people viewed this question
Top Seiko Watches Experts
Jerry Greenberg
Jerry Greenberg
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
