The thermostat is set but the heat wont come on
    Scholar:
  • 45 Answers
This seems to be a pretty general issue. Have you recently changed the thermostat? There might be a chort from the thermostat to the furnace. There may be an issue with the furnace itself. Take the switch on the Thermostat labeled FAN and switch it to ON. There should be 2 setting for this switch-AUTO and ON. Switch to ON and see if furnace blower starts. If it does, we need to dig a little deeper to reveal your issue.
Posted on Jan 01, 2014
Model sf35f furnace wont quit heating after reaching thermostat setting
Sounds like the heat anticipator in your thermostat is either bad or out of adjustment. Turn of the furnace power. Remove the thermostat wires from the thermostat. Turn the power back on. Connect the white and red wires together. The furnace should start up. Let it run a couple of minutes. Then disconnect the wires. The burners should shut off immediately. The blower will continue to run for 60 to 360 seconds then shut off. If this happens replace your thermostat. If the burners continue to burn, then your problem is either the furnace or the thermostat wires.
Sep 12, 2014 | Heating & Cooling
Fer211as heats but wont dry! heating element comes on but kicks off after gets to temp then element will not come back on unless stopped and restarted?
Runs but will not heat
1.loose wiring--check terminals & wiring
2. Defective thermostat--replace thermostat
3.defective centrifugal switch in motor--replace switch (check linkage to motor)
4. Defective timer--replace timer
5. Open heater element---replace heater element
6. Heat switch set to off----set switch for desired heat
Sep 22, 2011 | Frigidaire FER211A Electric Dryer
My newly installed Broan-NuTone attic fan worked fine for two days. Now it wont turn off, even though the temperature has dropped well (40 degrees)below the setting(100 degrees).
Hi. The most likly cause of this type problem is the thermostat. Check the thermostat housing is it hot to the touch, is it close to a heat soarse, suchas, a motor or flu pipe for a water heater. If the thermostat has a adjustable heat range setting try setting it to the lowest setting if this shuts the unit off the calibration of the unit may not be set right. If the unit is new this should be covered under warranty.
Jun 12, 2011 | Broan-NuTone ATTIC FAN THERMOSTAT CONTROL
Wont allow me to set thermostat below 73 degrees?
You never said what type and model of thermostat you have....... If you have a digital stat You may have to lower the HEAT setting below 67 degrees if you want to set the AC to 70 degrees. If the thermostat has an Auto feature then it has to have a 3 degree differences between heating and cooling. On the newer models it does it automatically if you lower the Cooling setting it will lower the heating setting......It this doesn't help repost with more information so I can help you better....
Mar 28, 2011 | Heating & Cooling
Air conditioner works fine but heat won't kick on
Check RV is working. And also keep thermostat setting +29 and heat mode.
Dec 09, 2010 | Ruud Matching Split Air Conditioner
How do I set my thermostat for my furnace? My thermostat wont come on appropriately. I think I pushed wrong buttons and can't get the heat to stay on. Would like to cancel settings and be able to set...
Set the System switch to either Heat or Cool. Press the Hold Temp button. Use the Warmer/Cooler buttons to set temperature. Temps will stay until you either turn off the system switch or press Run Program.  Good luck.
Jan 02, 2010 | Honeywell CT3200 5-2 Day Electronic...
I have a honeywell th6110d1005 in my house i just had built. went to adjust the thermostat on heat and it will go down but wont go above 59
take the face off of your thermostat or open the front cover. there will be selector swithces the say HE, HG, and possibly one for heat pump. Heat electric and heat Gas. Make sure it is set to the type of furnace that you have. The wire should be red to the rh or rc terminal.(Should have a jumper wire), yellow wire to the y terminal, White to the w terminal which is for heat, and green to the g terminal. there is another adjustment to be made on the heat anticipator, but you would need an amp meter to set properly
Nov 26, 2009 | Honeywell Electronic Programmable...
I cant figure out how to set up timer
Go to
myhome.honeywell.com
and search for a manual for your model number thermostat on the right hand side of the page.
Hank
Oct 13, 2009 | Honeywell Electronic Programmable...
My heat wont turn off
Whan your room is up to temp or room is set at 70 and your stat is at 70 do you hear the stat click off .if not its a bad stat. you will have a little flam on your stat that should go off also
Dec 28, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
224 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
