Question about Activision Call of Duty: Ghosts
Ps3 problems game says press start but nothing happens
Whenever I put in a Playstation3 Discs (Specifically PS3 Discs) Usually a icon will appear where you may press the X button to start playing. But for all MY discs nothing happens. This started 3 days ago...
This is the 2nd most common problem with PS3's. This isn't a bad problem. Your laser/lens will need to be replaced. Do you see the time clock in the top right corner going around and around? If so, you are just having laser/lens problems. If you do not see the time icon spinning when you insert a disc, your PS3's Blu Ray drive controller board has gone bad and you will need to send it to Sony and not a 3rd party technician. Certain problems are only repairable by Sony. Good luck.
Jan 19, 2011 | Sony Playstation 3 (PS3) Console
My PS3 dos not allow my controllers to connect and also does not show anything but the background
did u try pressing the middle button on both of them if u did that then u need to charge the controllers
Jun 30, 2010 | Sony Playstation 3 (PS3) Console
When starting ps3 boots up as normal but get no display on tv and controller will not sync so lights just flash. Solida green light on front. Help please
Make sure you read this all before starting anything and if this helps please leave me a rating, if not let me know and I will try to help you farther.
Thank You
ETRONIC
Symptoms:
On start, PS3 Green light comes up but nothing happens. No sound or video
Insert game or any disc into the slot, blue blinks and again nothing happens
Try to assign wireless controller, nothing happens.
Try restart the console, unplug it for a while, or keep it on for long time again does not solve the problem.
Solution:
With the PS3 in Standby mode (Red light on), press and hold the Start button until you hear a single beep, followed by double beeps.
Connect the controller using USB cable and press the PS button on the controller.
Now, the system restore screen (or whatever they call it) will come up like the Picture at the bottom of this writing.
You have several options here for restoring the system, some will unfortunately wipe up all your data, others will make you lose the file naming. For me, I tried the option top-bottom and eventually had to do the Restore PS3 System. Luckily, all I had were demos, trailers, and game saves. only game I was really playing now was Prince of Persia. I felt terrible still though, but much better than if I was playing Ninja Gaiden or MGS right? Or let’s say a game Fallout!
"I have found a way to keep all your saved data with this problem.
Follow the steps above but first download the latest firmware update from the playstation website and save it onto a USB key. Follow the steps and choose the bottom option "SYSTEM UPDATE". Wait for it to update and it should restart with all your music, videos and gamesaves."ca67f16.jpg
Mar 14, 2010 | Sony Playstation 3 (PS3) Console
Games not working but work sometime they and dvds work
The problem beiing: You played mw2 (oranother game) with the latess update installed on your ps3 and at somepoint it froze. tried pressing the PS button but nothing happened. Youhad to hold the power button to reset it or resolve to switch the backswitch off/on. Only to get this same problem over and over again. youcan t play blu ray on your ps3 and/or get the error 80010514. from timeto time it will play those blu ray only to start the whole problemagain.
if it is what is describe up there, follow the link below:
http://boardsus.playstation.com/playstation/board/message?board.id=ps3&thread.id=4284886
Feb 15, 2010 | Sony Playstation 3 (PS3) Console
My ps3 keeps saying that there is a settings error to press X for it to be fixed when i press X the screan goes black and nothing happens
hold the power button at front when turned off, the ps3 will start up (still holding the power button?) then turn off again this will reset all system settings
Dec 24, 2009 | Sony Playstation 3 (PS3) Console
I inserted a new movie and I have no sound nor video with a green and blue lights on.
I had this weird problem yesterday knowing I have not done any video setting changes, nor recall a pending software installation. When I start the PS3, green light comes up and then nothing happens. Insert the Game into the slot, blue light blinks and again nothing happens. No video, no sound, and no, it’s not output setting problem as many others have guessed in forums. Try to assign your wireless controller and you’ll know. It doesn’t. If it was on, output and controller assigning I assume should be two separate things.
Solution:
  1. With the PS3 in Standby mode (Red light on), press and hold the Start button until you hear a single beep, followed by double beeps.
  2. Connect the controller using USB cable and press the PS button on the controller.
  3. Now, the system restore screen (or whatever they call it) will come up like this
  4. You have several options here for restoring the system, some will unfortunately wipe up all your data, others will make you lose the file naming. For me, I tried the option top-bottom and eventually had to do the Restore PS3 System. Luckily, all I had were demos, trailers, and game saves. only game I was really playing now was Prince of Persia. I felt terrible still though, but much better than if I was playing Ninja Gaiden or MGS right? Or let’s say a game Fallout!
Sharing it for others with same misfortune. Guess we’ll need the PS3 included in the backup plan then.
Nov 14, 2009 | Sony Playstation 3 (PS3) Console
My ps3 turns black and nothing happens
Try checking your HDMI or VGA lead and reset the Ps3 Settings
Oct 03, 2009 | Sony Playstation 3 (PS3) Console
When i turn my ps3 on nothing happens, its just a blank screen
when you press the power button to turn it on, hold it for 5 - 6 seconds until it bleeps.
May 17, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 Error Code 8001050
8001050B - Will not play demo hard drive games, when blue-ray disc is inserted - Cause unknown
8001050D - An error occured during the start operation; Ps3 game swapped using the eject function and then play pressed quickly - ps3 game inserted again
More error codes on
http://boardsus.playstation.com/playstation/board/message?board.id=ps3&thread.id=1857127
Aug 04, 2008 | Sony Playstation 3 (PS3) Console
Activision Call of Duty: Ghosts Logo
205 people viewed this question
Top Activision Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you an Activision Hardware and Accessory Expert? Answer questions, earn points and help others
