Question about Vacuums
Fixing the belt on the hoover globe
I have removed the belt from my hoover globe and need to put it back together
SOURCE: hoover windtunnel u6634-900
I have the same problem. I believe, after some inspection, that the mechanism which allows for the circular spin of the brush has failed. Though I'm no mechanic, I believe my girlfriend's long (and beautiful) hair became entangled underneath the gray "end-cap" causing breakage of the rotating mechanism (which I believe is normally housed within the brush under the rectangular "end-cap"...the other "end-cap" piece is circular). Now the brush will spin about 6 rotations but with each spin the gray "end-cap" will extend on its screw rather than spinning freely. I believe my only option is to order another brush. We'll see if it solves the problem.
Posted on Jul 11, 2007
informatica
  • 1114 Answers
SOURCE: need instructions on how to replace the belt on a hoover dirt finder model u5321-930
You can download the manual from the link below: http://www.hoover.com/Media/ModelPDF/U5468900.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 28, 2007
reddevil6
  • 1673 Answers
Put the V belt on the pulley first, then the flat belt, put it over the motor shaft or pulley, then you have to stretch it to go over the pulley next to the V belt pulley.
Posted on Jan 19, 2008
  • 97 Answers
SOURCE: We have had three belts break on your hoover
sometimes when you buy belts from the walmart or target, they are not at the correct specification and they brake as soon as you turn on the machine. i would suggest that you buy these belts from the company.
Posted on Jul 19, 2009
SOURCE: Replace broken belt
I have the agitator belt style 190 for the Hoover elite rewind I put it on and the belt broke again what do I do help carpet needs cleaning.
Posted on Feb 04, 2012
How do i change the belt on a hoover model #U4509
Lay the unplugged vacuum upside down and remove the bottom plate covering the brushroll to remove the brushroll and belt. Make sure brushroll bristles aren't worn, replace it also if needed. Make sure brushroll will spin freely. Put new belt around motor shaft then around brushroll. Pull on brushroll with both hands to get enough leverage to stretch the belt far enough to drop the brushroll in place. Put bottom plate back on and insure brushroll will turn by hand before you turn it back on..
Nov 12, 2016 | Hoover Vacuums
How to replace belt on hoover SH40060
You have to remove the roller to get to the belt' look at the face and bottom to find the screws that hold the plate that covers the roller. Take the plate off and look @ the roller, to see where the belt runs. then take the roller out, you should be able to see the pin shaft that comes from the motor,the belt goes around it and over the roller.Be patient putting it all back together,and don't over tighten the screws, they strip easily, Good luck!
Feb 20, 2015 | Hoover Vacuums
Is it necessary to take the vacuum cleaner apart to change the belt on a Hoover Wind Tunnel Self Propelled vacuum cleaner, model UI6460-900? If so, how is that done? If not, how do you get the belt on...
To change the belts, make sure the vacuum is not plugged in. Lay it upside down and remove the screws holding the bottom plate on. Remove the bottom plate, pull the brush roll out noting how the belt goes so you will know how to put it back together. Especially how it goes around the idler pulley. Remove both belts, replace both belts, install the V belt onto the transmission first then around the brush roll and put the brush roll in place. Install the flat belt around the motor shaft and then onto the transmission pulley.
Feb 06, 2011 | Hoover Self-Propelled WindTunnel Bagless...
Hoover elite how do i put the belt on
Here is the belt you need: Hoover U5061900 Belt
Simply turn the machine over and you will see (4) screws, remove them and you will be able to access of the belt.
Dec 14, 2009 | Hoover Elite U5061-900 Bagged Upright...
I have a Hoover Slider, Model #S2105, Serial #050500084989, and I need instructions on putting it back together; with parts and assembly of parts. I took it apart because it was making a noise, and I...
Greetings from GoVacuum,
Please see the link below for a parts schematic to your Hoover Slider, hopefully this will help you put the machine back together. If you find a part that is missing, and would like to order one, just shoot me an email at chris.jones at govacuum.com, and I can give you a price on it.
Please feel free to send me an email should you have any further questions.
Chris Jones
GoVacuum.com
Sep 29, 2008 | Vacuums
Savvy vacuum belt
It is easier when you also take the top off. Then you can put the belt over the roller and re-install it, then put the bottom plate back on, then turn it over, undo the motor and put the belt on the motor pulley, re-install the motor and put the rest back together. To remove the top, thewre are a couple of scres from the bottom, then from the top, remove the Hoover emblem, there is a screw there to remove and the top will come off.
Jul 11, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Hoover belt replacement
Turn vac. over, remove the buttom plate over the brush roll, then at the bottom edge of the top cover, using a flat blade screwdriver, insert into the slots and pry up to unlock the tabs, then the top cover will come off. Put the belt on the brush roll and feed the belt thru the opening and put stretch it over the motor shaft. Put the top cover back on and push to lock the tabs.
Dec 19, 2007 | Vacuums
Bissell shampooer
First take off the cover on the left side oif the top cover, then turn it over, remove the screw holding the red lock and pull the cap and brush roll out, remove the cap, remove the cogged belt, then you can put the new pump belt thru that slot, put over the pulley on the pump and then stretch it to go over the motor shaft. Then put back together. This is for alot of models, but you didn't state your model number, hopefully this is the right fix for yours.
Nov 14, 2007 | Vacuums
Vacuums Logo
29 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
