Question about Husqvarna 28cc Gas Line Trimmer
Husqvarna 324LDx 4 cycle string trimmer. Have
Husqvarna 324LDx 4 cycle string trimmer. Have replaced the plug, air filter, clean oil, gas filter but still having problems with it starting and continuing to run. Has been superb up till now, best I have ever owned and normally started on 2nd or 3rd pull. Anything else I should do or look for?
jebpet@earthlink.net
  • 42 Answers
Probably needs a carb kit, check main jet and main fuel inlet jet, is the spark crisp, fat and powerful, try running it with a borrowed coil as this may have an intermittent fault. Is fuel cap breather working or blocked, these small carbs are very sensitive. Make sure all is well with gaskets and diagrahms. Good luck the Yeti
Posted on May 17, 2009
How much oil and what type of oil should I use in the trimmer?
You use no oil,use regular unleaded gas only,on 4-Cycle engine use gas,2-Cycle engines use the oil- gas mixture,your's is better cause you just need gas.I use Husq's too.
Apr 13, 2016 | Husqvarna 224L 25cc 4-Cycle Straight Shaft...
Where is the spark plug on this weedwacker?
Look at page 6 G and 9 P
on this parts manual
https://www.google.nl/?gws_rd=ssl#q=husqvarna+324ldx.pdf
Nov 01, 2015 | Husqvarna 324LDX Split Shaft Beam Trimmer...
Why does it stall at 100% throttle?
Not really, if the fuel is old or has water in it.
Sound like the new carb diaphragm. May be sucking air.
You covered all the bases, New Fuel lines, Filter and Cleaner
Try restricting the air flow coming in and see if it smouths out.
Apr 30, 2014 | Husqvarna 324LDX Split Shaft Beam Trimmer...
Husqvarna weed eater starts , but blows alot of smoke & then stalls out
Rod, Carb. may need adjusted, try loosening gas cap and start to see if cap vent plugged, there is a in tank fuel filter that you could fish out and remove to see if it is plugged. If still not running remove muffler and clean spark arrester screen, if screen plugged the trimmer will do this.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Craftsman Trimmer starts then dies
How to Clean Spark Arrestor Screen on Small 2 Cycle Engine Quick Fix
How to Clean Two Cycle Two Stroke Engine Carburetor
Sep 06, 2012 | Husqvarna 128 LD Weedeater
Tappet settings husqvarna 324ld
valve clearance should be 0.10 feeler guage
Flywheel 0.25 feeler guage
Jul 28, 2012 | Husqvarna 324LDX Split Shaft Beam Trimmer...
Engine suddenly quit and will not restart or fire.
Hello. Begin by changing your air filter. If the air filter is dirty or has too much oil in it the trimmer will not start. Next, change the spark plug. Then check the fuel filter inside of the tank to be sure it is not clogged.
Finally, I do have a customer now and then who accidentally puts in the wrong fuel [for instance straight gas instead of the gas and oil mix required]. If this is a possibility, drain the tank and start over with a fresh gallon of gas and a fresh 2 cycle oil mix. Joe
Oct 24, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
I put to much oil in my weed eater, lot of blue smoke came out, then it stopped. if i pour some of the oil out and let it cool off will it be ok
should be ok drain oil to correct level remove spark plug clean and dry plug,with plug out crank over to remove oil from cylender,make sure air filter did not get oil soaked if dry reinstall if wet replace. reinstall spark plug and start probably will smoke untill it burns off residual oil in muffler hope this helps
Aug 09, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Tb415cs,not getting spark? Cleaned the plug and filter, new gas & oil.
it may just be the switch playing up on you give it a good swilling with WD40 if that dont work look at the spark plug coile
Oct 30, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
My string trimmer will not start
Possible solutions:
-Kill switch is shorted out-check the wire and connections.
-Buy a new plug.
-Primer bulb needs to be replaced.
-Fuel filter needs to be replaced, and it's located inside the gas tank so it's a bit tricky to replace.
-Try starting it without the air filter attached.
Is it possible an incorrect mix of gas/oil was used (or straight gas) which in turn ruined the motor?
Jul 29, 2009 | Garden
Trot Bilt 4 cycle weed eater catches, but wont run.
rebuild carb to fix problem.let me know if this help you.ok
Jul 12, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Husqvarna 28cc Gas Line Trimmer Logo
1,122 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
