Question about Garden
Treadmill got wet and blew
Stood outside in garden was wet by sprinkler and blew while in motion
    New Friend:
  • 10 Answers
Dry it - thoroughly! - a week in the warm! - replace fuse and try - watch out for shocks! - Wear gloves / use a stick
MOST LIKELY - the control board is terminal toast
Posted on Dec 31, 2013
I have a Everbilt #EFLS10-HD PLASTIC LAWN SPRINKLER PUMP. That losses prime when it shuts off. Also to operate garden hose must have sprinkles on. Please HELP... I do not have my own well so really don't...
Sounds like a broken or cracked hose underground. Check for wet or soggy spots in your yard. Isolated leaks can happen on piping like this.
Hope this helps.
Feb 04, 2018 | Garden
Garden sprinkler not popping up and not working
Replace that sprinkler head.
Feb 10, 2017 | Garden
How do I select a pattern for my triplespray sprinkler
www.irrigationtutorials.com/sprinkler-coverage-nozzle-selection-sprinkle...
Sep 22, 2014 | Garden
Got wet and blew
Replace your controller
Dec 25, 2013 | Exercise & Fitness
Installing sprinkler timer
GFCI is just a protected plug for use in wet areas - like Te one in your bathroom. Your sprinklers will work fine plugged into a regular outlet but it may void your warranty if something happens. If your timer is outside or not well protected from weather then consider installing one of these outlets. 7_11_2013_1_40_33_pm.png
Jun 22, 2013 | Garden
Sprinkler system pump pressure too high?
You just need to make better glue joints in the plastic pipe.
Use blue glue. It has primer built in and is one step. If you are using clear PVC cement and no primer it will not bond.
If you use purple primer and clear cement you need to put the cement on over the primer while it is still wet. If you allow the primer to dry it makes it worse.
Dec 30, 2017 | Water Source Plumbing
My treadmill got wet the motor runs but the platform belt wont turn
1) Try to get out the controller board motor, and put In bag dry Rice, by 48 hours.
2) clean the board with special contacts cleaner or board electronic( you can buy from any electronic store).
3) Put again the board in the treadmill, If work is ok, IF not the components like IGBT is fault, Replace the completely board.
Blessing
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Oct 30, 2017 | Icon Exercise & Fitness
My John Deere traveling sprinkler is in reverse and can not make it go forward. Help its hot outside. Thank You!
Improperassembly. Change the direction of the nozzles on the spray bar so it turns in the opposite direction..
Apr 22, 2011 | John Deere Gilmour Traveling Sprinkler -...
Garden Logo
111 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
