Question about Exercise & Fitness
Got wet and blew
Treadmill standing outside running pad near motor got wet machine was switched on huge puff from machine and it stopped working
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 163 Answers
Replace your controller
Posted on Jan 04, 2014
  • 16 Answers
SOURCE: belt stops running while standing on the treadmill
Either front roller may need to be replaced or the motor drive belt may need to be adjusted. This problems are caused when a walking belt is worn out and in need of replacement. Too much tension can cause bearing failure in the motor and the front roller and front roller pulley failure.
Motor drive belt adjustment: The motor drive belt is adjusted independently from the walking belt. Some newer models have an auto tensioner which is a lever that has a wheel that puts pressure on the drive belt and a spring on the other end that automatically loads the belt to the proper tension. You should not adjust these since they are preset. Tension can be affected slightly by adjusting the tension of the walking belt but if you have a slipping problem, the drive belt will require replacement. If your drive belt is too loose, it will slip on the front roller pulley or the motor pulley. If it is too tight, it will increase your amp draw to the point that you may have an electronics or motor problem. Due to this, it is better to be on the safe side and replace a drive belt rather than risk over tightening it.
Posted on Feb 20, 2010
maxtreadmill
  • 832 Answers
SOURCE: how do i start the 5 star treadmill
Most on/off reset switch are located right by the power cord in front of unit.
Posted on Jun 26, 2010
outfield502
  • 79 Answers
SOURCE: my treadmill motor starts exactly
that a qualified technician check the motor controller board the mosfet (IRF250N.) or diodes
Posted on Sep 08, 2010
  • 84 Answers
SOURCE: my treadmill starts up and
check tension on w/belt and motor belt signs of worn out belt. black dust cracking treads or flaking.
Posted on Mar 14, 2011
  • 456 Answers
SOURCE: Hi. I have a
hi.
the circuit breaker probably only covers the motor anyway, and if this is the case then the problem has been isolated already.
it sounds like the motor has burnt out, and there is a short in it somewhere. the best (and safest) thing to do is to remove the motor and either just replace it, or have it tested by an electrician.
most repair shops will happily test a motor for free if you take it to them. it should only take a few minutes.
take the circuit breaker to them as well, as it is possible to have a faulty circuit breaker.
please feel free to ask if you need more advice.
hope this helps
Posted on Jun 22, 2011
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
I have a NordicTrack C2420 treadmill and it looks like I am having issues with its motor board (MC2100WA).
sounds like a MCB problem, I have MCB's in stock ready for shipment, Elitefitnessrepair@gmail.com
Apr 03, 2015 | Nordic Track Nordictrack C2420 Treadmill...
My Kettler running machine keeps cutting out. Have lubricated the running belt but problem persists
Could be several things going on. I'm not familiar with your brand of treadmill, so I don't know how powerful the motor or how durable it is. Could be that it can't handle the load anymore. I had a cheap treadmill that would trip the breaker switch on me often after about 5-10 minutes of use. I needed to up the switch amp to get it to work, but that means your house wiring for your switch needs to conform to that load as well. Messing with electricity was not going to happen for me. I ended up getting a new treadmill. Try plugging in your treadmill in a different outlet that may have a fuse or breaker with a higher amp, like a 20 amp or so, and see if the problem persists. If your machine is more than 5 years old, it's motor is probably worn out. Of course, you could always dress warmer and just run outside. ;)
Jan 24, 2015 | Kettler Race Indoor Training Bike
Treadmill got wet and blew
Dry it - thoroughly! - a week in the warm! - replace fuse and try - watch out for shocks! - Wear gloves / use a stick
MOST LIKELY - the control board is terminal toast
Dec 25, 2013 | Garden
I have a Proform 585 and the incline won't go up or down. When I push the button you can here the motor trying but nothing happens. Please help
As you are hearing the motor sound, It could be a problem as simple as the gearbox on the motor being jammed. We can remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn't run outside the machine and you can hear it try to work, you need to replace the incline motor.
Mar 14, 2011 | Proform Exercise & Fitness
Treadmill will not level out and motor sounds all the time
If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
Jun 27, 2010 | Proform 575 Crosstrainer Treadmill
My 17.0 R image incline stuck in the highest mode, how do I bring it down.
Jun 14, 2010 | Icon Image 17.5 S Treadmill
My treadmill is stuck in the max incline position
Jun 11, 2010 | Nordic Track Exercise & Fitness
Heard a pop when I started it, now no blower or blinkers
sounds like the ignition switch shorted out like a wire was rubbing and im sure it blew the fuses your going to replace the egnition switch and repair any wire thet is bad and replace the fuse
Nov 14, 2008 | 1992 Dodge Caravan
Exercise & Fitness Logo
61 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
