Question about Ricoh Aficio 1027 All-In-One Laser Printer
Sc650 funtional problem with the copier
  • Ricoh Master
  • 1,294 Answers
SC 650 - communication timeout error between SBCU and duplex unit.Verify the duplex mechanical and electrical components(gears,actuators,sensors).
Posted on Jan 03, 2014
Funtional code SC101-00 appears on Lanier 5245 copier when turned on. Exposure lamp is burning.
Hello!
There you are. You asked the question but you already know the answer.
The exposure lamp are burned so... this error code appears in the display.
You need to change the exposure lamp
Sep 10, 2011 | Ricoh Aficio 450 Copier
@How do I rest the admin password for Canon if 3045
press additional funtions, 2 and 8 simultaneously, additional functions, copier, function, clear, password, ok. then turn off and on again with switch on the side of copier.
May 16, 2011 | Canon Office Equipment & Supplies
Error msg E000001-0000 What can we do
that is a thermistor error code. there are several causes for this. the thermistors are dirty, the upper fixing roller is damaged or it might have paper wrapped around it, or the connecter on the back of the fixing frame has a hair line crack in it. now you can clear this code if you you think there isn't anything wrong with the afore mentioned items.
you have to get into service mode. first you will have to shut the copier off at the main power switch and turn it back on once the error code pops up on the screen you will need to get into service mode.
you hit the
additional funtions button
then the 2+8 at the same time
then additional funtions button again
once in service mode you will need to follow the following steps
hit the copier tab
then the funtions tab middle of screen across the top
then hit the clear tab
then the err tab and hit the ok button to clear error
now you only have like 30 seconds give or take to get into service mode and to clear the error code before the machine shuts down if you don't get in fast enough dont worry shut the copier off and turn it back on and keep trying till you get in and clear it. trust me it took me several tries my first time i realized this myself.
Aug 16, 2010 | Canon imageRUNNER 5000 Copier
LANIER COLOR COPIER MODEL LD345c Funtional Problem SC541
sc541 means no warm up, press the clear modees the punch in107 then press and hold down the clear stop key untilk it goes into sevice mode then shut main power
Apr 07, 2010 | Lanier 1205 Copier
TURN OFF MAIN AND THEN ON ..BUT STILL FUNTIONAL PROBLEMS STILL OCCRING
Specify the your problem.Beging turn OFF/ON the copier enter in the service mode(press the total clear key-1-0-7 and hold down more 3 sec.the clear key).Turn OFF the copier,unplugged wait 10 sec,plugged and turn ON.
Aug 28, 2009 | Ricoh Aficio 1018D Copier
Canon Image Runner 2200, receiving error message 602-0003
It's related to copier HDD try with some technician to replace HDD or reinstall HDD software.
A data read fault of the HDD is detected when the HDD is started up. or
The wiring is faulty (short circuit, open circuit). The HDD is faulty.
also check -
Are the connection and the cable between connector J1025 of the main controller PCB and the connector J2005 of the HDD normal?
Jun 24, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Jaime arnuero
the scanner is locked  for the down is de scanner push bottom green.
Sep 01, 2008 | Xerox WorkCentre M15i Laser Printer
Ricoh Aficio 1027 All-In-One Laser Printer Logo
292 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
