Question about Kodak EasyShare Z812 IS Digital Camera
Camera turns on but no picture on screen - Kodak EasyShare Z812 IS Digital Camera
I can take pictures with my camera, but LCD screen is black, and I can not view my pictures either
Has the camera been dropped or gotten wet? If not screen is shot and needs a new one.
Jan 30, 2014 | Sony Cyber-Shot DSC-WX10 Digital Camera
Screen is black when i attempt to take pic
Move all the pictures to the camera memory card from your internal memory. Since you have to open the camera, the pictures will be lost otherwise. Save your pictures. If you do not have a memory card, transfer all the pictures to your computer.
Remove batteries from the camera.
Purchase a replacement LCD screen, specific to your camera. These replacement screens can usually be purchased directly from Canon or from a camera resale shop. Auction websites should also carry LCD screens specific for these cameras. Use the mini screwdriver to remove the four screws from the back of the camera. Be careful with this step since the screws are tiny. Take the back cover of the camera off carefully. Inside the camera, there is a piece of foam that supports the LCD screen. Do not remove the foam. Set the bottom portion of the camera to the side.
Turn the top portion of the camera so it is facing upward. Notice how there are clips holding the LCD screen in place. Carefully lift these clips up and remove the broken LCD screen. The screen clips are extremely fragile and break easily if they are lifted too quickly. A gentle touch is key.Place the new screen down gently and replace the clips. Gently dust the screen so fingerprints are removed.Turn the top portion of the camera down so the screen is pointing down. Place this on top of the foam padding. Turn the screws carefully. The best way to screw the back of the camera in place is to first screw in one corner, move to the corner that is diagonally across and turn that screw. Repeat for the other two screws.Replace the batteries. Turn the camera on and see if it is function.
Thank you !!
Jun 01, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Screen stays black
Purchase a replacement LCD screen, specific to a Samsung S860 camera. These replacement screens can usually be purchased directly from Samsung or from a camera resale shop. Auction websites should also carry LCD screens specific for these cameras.
Sep 02, 2009 | Samsung S860 Digital Camera
Cannon Powershot A-620 black screen can't review
Did you accidentally press the DISP or DISPLAY button on the back of your camera? This manually turns the screen on and off to save batteries. You would then use the optical viewfinder to take pictures. To turn the screen back on, just press this button one more time.
Jul 23, 2009 | Canon Cameras
My camera d580
First, make sure the batteries are fresh and installed correctly. Turn on the camera, if you get an opening screen, your camera should be OK. Press the menu button and navigate to screen options where you should be able to turn on the screen to take pictures.
If there is no opening screen when you turn on the camera (and you are sure the batteries are good and in properly), then try to take some pictures without the screen. If the camera takes good pictures, then the screen is dead. You can continu to take pictures with it in this condition. I do not think they are worth fixing, though.
If the camera does not take good pictures or no pictures then the camera has failed or dead. Your best solution is to replace the camera with a newer, better one, More pixels, greater optical zoom, quicker start time and so on.
May 31, 2009 | GE E1040 Digital Camera
KODAK eASYSHARE c530 BLACK SCREEN DOES NOT TAKE PICTURE
You may still be able to take pictures with your black screened Kodak camera. This problem occurs in the line of Kodak EasyShare digital camera models.
When you turn on your Kodak EasyShare digital camera, turn off the LiveView function. Take a picture using the small-windowed viewfinder (this is not the LCD screen). Also, try zooming in and out.
After taking a picture, review the picture to see if the picture has been taken. Then turn on LiveView and occasionally the LCD screen should no longer be showing a black screen.
Aug 31, 2008 | Kodak EasyShare C315 Digital Camera
CAMERA TURNS OFF WHEN IN PICTURE OR VIDEO MODE
Does the camera turn off or does the screen go black? if the screen goes black but the power lamp stays green then the screen is just turned off (power save mode), If it’s just the screen to turn on the LCD. There are 3 buttons just to the right of the screen, press the center button.
May 20, 2008 | Sony Cyber-Shot DSC-P52 Digital Camera
My digital camera screen has gone dark, but the camera still takes pictures. How do I fix the screen?
the same happened to me! and also it sometimes randomly turns off. but it takes pictures if it doesnt. mine is canon sd1000 powershot
Apr 16, 2008 | Cameras
Kodak CX7330. turns on but LCD screen is black and won't take a pic
It sounds like a bad connection on the ribbon cable of the LCD screen to the camera's motherboard. The fact that when you physically move the camera around and you can get the screen to then work, tells me something is loose inside.
- Jim
Jan 14, 2008 | Kodak EasyShare CX7330 Digital Camera
Kodak EasyShare Z812 IS Digital Camera Logo
29 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
