Question about Creative WP-350 Headset
How do you connect to the ps3?
I don now how to connect the ps3 to the ps3.
    New Friend:
*NB: it will ONLY work for communications, NOT for game audio. (lame az, I know!)
  1. hold in the headset's power-on button until it flashes red/blue for pairing.
  2. Next make the ps3 scan: settings> accessories settings> manage bluetooth devices> register device (yes)> scan and add. (probably passkey 0000)
How to connect any Bluetooth headset to your PS3
Posted on Oct 20, 2015
Hookupplaystation3tointernet
Hello Cabage344,
Easiest way is to connect the pS3 to your wireless network.
If you don't have a wireless network, connect a ethernet cable from your PS3 LAN port (on the back of the PS3) to one of the numbered LAN ports on your router.
Thanks,
Pat
Apr 01, 2012 | Sony Playstation 3 (PS3) Console
Connect to wifi on blackberry and ps3
It is just be a matter of synching the blue tooth system of the blackberry to that of the PS3. Assuming the PS3 is not currently connected to the web or connected to a modem, you should be able to search for the PS3 by using the Bluetooth search tool in the Blackberry setup menus. Then for headsets,set those up through the PS3 by turning on the head sets, and then using the Blue tooth set up utility of the PS3 to search for the head sets.
Otherwise If you do not have Wifi active currently and don't have good cellular coverage in your area, you can use a Wifi Bridge Dongle (connector cable) like this one, there are others available too.
http://www.espow.com/wholesale-wifi-bridge-dongle-wireless-for-dreambox-xbox-ps3.html
to connect the PS3 to your home computer and use it as the hub assuming you ahve it connected to DSL or broadband. headsets would set up the same way.
Jan 04, 2012 | Sony Playstation 3 (PS3) Console
PS3 works great just won't connect to internet - have checked internet connections out, they all work, just PS3 won't connect. Is there a fix for that?
Try replacing the wi-fi antenna - only a few dollars. And also you could try replacing the bluetooth board - the antenna connects to that.They are your hardware fixes.
You could use an ethernet cable, if the problem persists, then it's probably a router problem.
Nov 30, 2011 | Sony Playstation 3 (PS3) Console
Why cant i get a system update
How to Update Your Ps3 Firmware With Your Computer
How to Update Your Ps3 Firmware With Your Computerthumbnail Update Your Ps3 Firmware With Your Computer
So you want to update your ps3, but you don't have your ps3 connected to the internet, well no fear in this article I will show you how to update your ps3's firmware by using your computer.
Instructions
Things You'll Need
Internet
J-Drive
1 First go to this website,http://www.us.playstation.com/Support/SystemUpdates/PS3
and click on the download now button just under the big ps3 and save it to your desktop or any other place that you can get to the file easly.
2 Now get into your j-drive and make a new folder named "PS3".
3 Now click on the PS3 folder and make a new one called "UPDATE".
4 Now put the downloaded update file ito the "UPDATE" folder that you just made.
5 Take the j-drive to your ps3 and plug it into the usb port.
6 Once done with that go to settings, system update, update via mass storage device.
7 Follow the directions on the screen to complete the update.
8 Once done you cna go back to playing on your ps3.
Tips & Warnings
You can do this for every update that you do
Its free to do
If it don't work you did it wrong
Aug 10, 2011 | Sony Playstation 3 (PS3) Console
I try to download stuff off the internet but it keeps saying connect storage media at the save destination what does this mean
File formats that the PS3 doesn't recognize as something that it can play can only be saved to a USB storage device, or a memory card. You can't download anything to the PS3 hard drive via the browser that you couldn't copy to it from a USB storage device. That is what the error message means. You have to connect an external storage device, because the PS3 won't store this file format on the internal drive. This protects the integrity of the system. If you connect a USB drive or memory card (you will need a USB adapter for the memory card if you don't have a launch PS3), then you can download anything that you want using the PS3 web browser.
Jul 09, 2011 | Sony Playstation 3 (PS3) Console
When i put ma ps3 on it goes green yellow red
I experienced the same issume before. This is called Yellow Light of Death or (YLOD)
Please see below on some information regarding this issue and some possible reslotion to prevent this from happening:
If we go by Sony's definition then having PS3 YLOD means "general hardware failure". So it means that a fault could have occurred anywhere in your Console. Don't be afraid though, since most of the times PS3 YLOD is due to motherboard getting detached.
Tips on how to fix it:
Alternatively you can try to repair ps3 YLOD yourself. There are a couple of things you can try to fix YLOD - check for any loose connections since some connections might be loose, you can also try switching it off for around 30 mins and switch it on again. This will help in cooling your PS3 down.
If these tricks don't work, then I will suggest you go through a dedicated PS3 repair guide instead of tinkering on your own. Such guide will cost you almost nothing in comparison to what Sony charges. And, god forbid, if it happens again you can solve the problem for free.
One of the greatest thing about doing it yourself is that you don't have to pay hefty charges to the big companies. Also, you don't have to wait for weeks, you'll completely fix ps3 ylod in no more than a few hours. Many people have already successfully fixed yellow light of death and I don't see a reason why you won't be able to do it. If my PS3 has yellow light of death then I won't pay Sony to repair my PS3. I'd rather fix PS3 lights myself.
If all this steps wont work i suggest to call SONY
1-800-345-7669
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
A VERY HELPFUL RATING IS APPRECIATED, Thanks Regards
Nerdierob
Jun 06, 2011 | Sony Playstation 3 (PS3) Console
Cant get internet connestion
Are you hard wiring it? if so you may need to reboot your modem then start the ps3 back up. Don't unplug from the computer and connect it directly to your PS3 because the modem still has the computer's ip address and it won't recognize the PS3 until you reboot it. If it's a wireless connection, check to see that when you scan for wireless connection that the green wireless LED is blinking, meaning it's searching for a signal. If it's blinking, then try resetting the modem and the wireless router as well and give it another try. If the green light does not blink, then there might be a harware issue with your PS3. Good luck
Jun 04, 2011 | Sony Playstation 3 (PS3) Console
Hi. My playstation won't work at all. When i try to turn it on, it goes on sometimes on the tv, or else, it says that i don't have connection from the PS3 to my tv.. I Checked my HDMI, and...
If the screen is just black and the PS3 doesn't turn itself off, then it could just be that the video settings don't go out through the correct output. This will reset the video output:
  • Hold the power button for 5-10 seconds until you hear two beeps; then let go
May 31, 2011 | Sony Playstation 3 (PS3) Console
I don t remember the steps to sync my Infinite Play Wireless to ps3 ;)
Hello Rickrip
Ok try this
Switch off PS3
Connect USD cable to controller and PS3
Turn on PS3
Turn on Controller.
Hopefully the controller will sync now
Hope this helps
Mar 07, 2011 | Intec PlayStation 3 Infinite Play Wireless...
Connecting ps3 to hd tv
ok here's what you do. Hook up your ps3 to your hd via hdmi cable then turn the tv on first. Then turn the power on to your ps3 and switch tv to hdmi. wait a while then a screen should come up and you should see and screen where it says an hdmi device is connected do u want to accept theses settings say yes. sometimes the "handshake" doesn't happen properly. If u already know this or have tried this it could be that your tv needs a firmware update, happened to me.
Jan 12, 2009 | Sony Playstation 3 (PS3) Console
Creative WP-350 Headset Logo
115 people viewed this question
Top Creative Radio Communications Experts
eradiostore
eradiostore
Are you a Creative Radio Communication Expert? Answer questions, earn points and help others
