Zoostorm play tab
I need to remove the back of the unit as charging point has become detached, and warranty holder have said it is damage and so not covered.
    Top Expert:
  • Computers & ... Master
  • 22,766 Answers
I bet they will repair it free of charge for you if you quote your consumer rights and "Fit for purpose".
Posted on Dec 25, 2013
Zoostorm playtab q6010 dc charger jack inside tab has bacome loose and have to hold the charger in place to enable it to charge Can i remove thr rear cover to try and fix this
Just look if ifixit.com opened your tab already. They show how to open and repair lost of electronics. They also can help with spare parts and they sell tools.
Jul 13, 2014 | Tablets & eReaders
How do I access the hard drive (to replace) on a Canon imageRUNNER 5000. Where is it located/how do I remove it?
Points to Note When Replacing the HDD
1. Take care to avoid damage by static charge.
2. Keep the HDD unit from impact.
1) Remove the rear upper cover and the
reader rear cover.
2) Remove the three screws , and detach
the cover.
3) Remove the two screws , and disconnect
the two connectors ; then, remove
the HDD unit.
4) Remove the six screws, and detach
the HDD.
When mounting the HDD unit, be sure that the flat cable is under the plastic sheet of the HDDupper case.
here is a link to the location of the HDD http://i51.tinypic.com/htvitg.jpg
Obs:
1) Replace the HDD unit.
2) After assembling the machine, connect the power plug to the power outlet.
3) Connect a PC to which the Service Support Tool has been installed.
4) Turn on the PC, and turn on the main power switch while holding down both '2' and '8'
on the keypad.
5) Using the Service Support Tool, format the HDD unit and install the system software.
Nov 16, 2010 | Canon imageRUNNER 5000 Copier
Don't know how to change the ink cartlige
Hi
thank you for your query
Make sure the printer is on but not printing. Raise the printer cover, then press down the Maintenance button for six seconds until the print heads move to the center. Pull up the empty ink cartridge clamp all the way. The cartridge rises up from its holder and should be disposed. Unwrap the ink cartridges and remove ONLY the yellow tape seal from the black and color ink cartridge. If you accidently remove anything but the yellow seal you cannot use the cartridge or it will damage the printer. To install the new cartridge, tilt the ink cartridge forward slightly as you lower it into its holder. Hang the tabs at the back of the cartridge on the hooks on the holder clamps. Don't place the cartridge tabs under the hooks on the holder clamp; you may damage the clamp when you close it. Install the ink cartridge and press the Maintenance button to begin charging the ink delivery system. Charging takes about a minute and is complete when the power light stops flashing and the error light goes out
Sep 24, 2010 | Epson Stylus C40UX InkJet Printer
How do I remove and replace the headlight dimmer switch in the steering column? It has become too sensative and goes to bright lights on it's own.
The headlamp switch is retained to the instrument panel by a tabs which are located on the switch. This procedure must be followed exactly or damage to the switch and/or instrument panel will occur. This procedure releases (lowers the tabs into the switch body) so that the switch can be puled out.
Rotate the knob counterclockwise until the knob points to the OFF position then rotate the knob clockwise one full turn.
Remove the headlamp switch from the instrument panel and...
detach the electrical connectors from the switch
Good luck.
Apr 25, 2010 | 2000 Ford Expedition
How do I extract the ink cartridge from the printer?
Make sure the printer is on but not printing. Raise the printer cover, then press down the Maintenance button for six seconds until the print heads move to the center. Pull up the empty ink cartridge clamp all the way. The cartridge rises up from its holder and should be disposed. Unwrap the ink cartridges and remove ONLY the yellow tape seal from the black and color ink cartridge. If you accidently remove anything but the yellow seal you cannot use the cartridge or it will damage the printer. To install the new cartridge, tilt the ink cartridge forward slightly as you lower it into its holder. Hang the tabs at the back of the cartridge on the hooks on the holder clamps. Don't place the cartridge tabs under the hooks on the holder clamp; you may damage the clamp when you close it. Install the ink cartridge and press the Maintenance button to begin charging the ink delivery system. Charging takes about a minute and is complete when the power light stops flashing and the error light goes out. For more information on installing an ink cartridge please refer to your Start Here Poster or your Printer Basics Manual.
Nov 15, 2009 | Epson Stylus C40UX InkJet Printer
The 6 disc magazine will not eject -
Ok..just happened to me. I'm a tinkerer so it's assumed that everything is out of warranty. The low down and skinny is this. The last disc holder is stuck on the metal changer tab, preventing the magazine to eject. 1. Remove the six screws on the left and right sides. 2. Use a small flathead screwdriver to GENTLY pry off the front Alpine CHM-S620 plastic facia.\ 3. On both left and right sides, collapse and push in the rubber suspension mounts. 4. Carefully remove the vertical/horizontal mount springs. 5. Gently pull off the data cable ribbon. 6. Flip over the changer unit. Use a coathanger to gently push the cartridge back into magazine. **You may damage the cd and last holder. Small price to pay to get things back to working order though. You may also have to wiggle the last cd holder to get it over the metal lip. 7. Reassemble in reverse order. 8. Change out that last cd cartridge so it doesn't jam again. Good luck.
Sep 27, 2009 | Alpine CHM-S620 6-Disc CD Changer
Need to replace right brake light. How do I remove and replace trunk lining to get access withou doing damage to the liner? What is the correct lamp?
Remove the luggage compartment rear trim panel. Detach luggage compartment side trim panel. Detach the rear lamp assembly bulb holder. Remove the rear lamp assembly. To install, reverse the removal procedure.
Aug 03, 2009 | 2003 Jaguar S-Type
How to detach face of lanzar stereo?
Here is a link to the owner's manual: http://www.lanzar.com/manuals/VBD1700MP.pdf (Note that the "DCP release button" is the upper-leftmost button on the unit.) On page E-5, it says: 2.DETACHABLE CONTROL PANEL (D.C.P.) Removing The Detachable Control Panel (D.C.P.). 1. Turn the power off 2. Press the D.C.P. release button 3. Remove the D.C.P. Attaching the DCP CAUTION 1. Attach the panel at the right side first, with point B on the main unit touching point A on the D.C.P. (As shown on the digram). 2. Then press the left side of D.C.P. onto the main unit until a ?click? sound is heard. DO NOT insert the D.C.P from the left side. Doing so may damage it. The D.C.P can easily be damaged by shocks. After removing it, place it in a protective case and be careful not to drop it or subject it to strong shocks. When the release button is pressed and the D.C.P is unlocked, the car's vibrations may cause it to fall. To prevent damage to the D.C.P, always store it in a protective case after detaching it. The rear connector that connects the main unit and the D.C.P is an extremely important part. Be careful not to damage it by pressing on it with fingernails, pens, screwdrivers, etc. Note: If the D.C.P is dirty, wipe off the dirt with soft, dry cloth only. And use a cotton swab soaked in isopropyl alcohol to clean the socket on the Socket back of the D.C.P.
Feb 16, 2007 | Lanzar VBD2200MP3 Motorized Slide Down...
Computers & Internet Logo
David Payne
David Payne
