Charging point appears to have come off inside the tab. The warrenty holder have said this is damage? How do i remove the back to hopefully re-attach
I need to know how to remove the back of this unit to re-attach charging point
  • 3 Answers
What exactly model ?
Posted on Dec 25, 2013
Thermal fuse part number
TURN OFF THE POWER NOW!!
25851826-kucbmckx3u3x3wmaw0z02dzb-3-0.jpg Hello. The part numbers are as follows:
42 THERMISTOR 8577274
47 & 48 THERMAL CUT-OFF W/ THERMISTOR-HC STAT 280148(one part number for both thermals in a kit)
51 THERMAL FUSE 3390719
TIP--use a magnetic screwdriver that will take nut-driver bits
You will have to raise the top cover, then, on the right side corner, disconnect the door switch connector. Next, using a headlamp, look inside the unit, back towards the front near the upper left and right corners about 4 inches down on either side. Notice there is a screw on each side. Remove these 2 screws and that will release the front cover. Arc the top of it towards you and lift it off the metal positioning tabs at the bottom and set it aside. Remove the lint screen now. Remove the 3-4 screws that hold the lint duct assembly(metal blower cover) in place. CAREFULLY pull the cover away from the lint screen holder(be *darn* careful that you don't damage the wires connected to the moisture sensor bars on the upper right side of the lint screen holder). Now, carefully look for the thermal fuse attached to the blower housing. It will be the one towards the front, slightly to the left of the exhaust thermistor. It will have a pair of light blue wires attached to it. Note P9-1 BU(blue), thermal fuse, BU(blue). Replace the fuse and reassembly is the reverse--caution--don't forget to re-connect the door switch connector at the right corner--cause "It ain't gonna do a thing" (even if you pray for it to work! LOL)
25851826-kucbmckx3u3x3wmaw0z02dzb-3-1.jpg I hope this helps you!
Sep 05, 2015 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Zoostorm play tab
I bet they will repair it free of charge for you if you quote your consumer rights and "Fit for purpose".
Dec 25, 2013 | Computers & Internet
Rear deck stop light
the hyundai suggested method is by removing the back seat. the dealer will charge you around $100.
i have done it using an alternate method.
1. open the trunk
2. crawl in facing up
3. locate openings below the brake light
(the opening is offset from the bottom of the light and holder (very helpful of hyundai!!!)
4. remove the foam pieces if any.
5. remove the screws holding the cover in place. a magnetic philips screwdriver would be good.
6. unscrew the light using the tab at the bottom of the holder
7. push it up and into the passenger compartment.
8. the entire assembly should come out from inside the compartment.
9. replace the bulb.
10. saw off the extra plastic tab at the bottom of the holder ( will help in putting it back and for future installs)
11. replace everything in the reverse order: bulb , cover ( inside the passenger compartment), replace screws from inside the trunk.
Jul 19, 2012 | 2006 Hyundai Sonata
My galaxy tablet was fine yesterday but today it will not turn on. The battery ran dead and I pugged it in and nothing, The red light does not even come on to show it is charging. I have tried both the car...
You can damage the battery but it is very rare to actually do that. What you need to do is plug it in to the wall charger and leave it alone over night. At that point it should be just fine. it will actually start to show some signs of life after a few hours but don't be tempted to do anything wih it. it will first show a charge light or something after maybe 40 minutes if it is a faster charger.
If it shows no life the next day then you can try charging again but at this point you may hae a problem that requires either a battery replacement or warrenty. The battery has a microcontroller on it and when the battey gets real low they do not behave that well and typically you get the stone dead brick behaviour. And most people do not let it charge long enough to get it working. It is possible that there are other problems but those are usually moore serious and require replacement of the unit. The battery can be replaced but requires the etire case to be disassembled.
So charge it then check your warrenty and it may need serious repairs or to be replaced. If it is out of warrenty then you need to be careful on the cost verses replaceemn
Mar 13, 2011 | Samsung Galaxy Tab Tablet PC
How to replace copier drum Cleaning Blade UCLEZ0069FCZZ
Improper installation may damage the copier. Before disassembly, be sure to disconnect the power cord for safety. 1) Remove the drum cover. (4 Lock Tabs.)
2) Remove the drum fixing plate and the photo conductor drum.
•Dispose the drum fixing plate which was removed.
3) Check the cleaning blade and the red felt for damage.
•If there is damage, go to step 5
•If there is no damage, go to step 12
4) Remove the main charger. (Cleaning the screen grid and the sawteeth.)
5) Remove the cleaning blade.
•Dispose the cleaning blade which was removed.
6) Clean the cleaning section and the waste toner pipe to remove waste toner completely with a vacuum cleaner.
7) Remove the felt and duplex tape completely.
•Be careful not to scratch or bend the sub blade.
8) Attach the cleaning blade.
•Securely insert the plate section of the cleaning blade into the unit and fix it with a screw.
•Do not touch the cleaning blade rubber with your hand.
•When attaching the cleaning blade, press the cleaning blade in the arrow direction and attach.
9) Attach the felt.
•Attach the mocket with slightly pressing section A of the cleaning blade.
•Do not touch the tip of the cleaning blade.
•Do not put the mocket under the cleaning blade.
•Do not put the mocket on the sub blade.
•Do not press the sub blade with the mocket.
10) Attach the main charger.
•Securely set the MC holder on the projection of the process frame.
•Securely insert two projections of the MC holder into the groove in the process frame.
•When attaching the MC holder assembly, be careful not to make contact with the cleaning blade.
11) attach the drum fixing plate and the photoconductor drum. Apply grease to the inside of the photoconductor drum. (Diagram 2)
•Attach the drum from (b). (Prevention against the sub blade edge breakage)
•Attach the drum so that its position with the sub blade shown
12) Attach the detection gear.
•The detection gear is not installed to the drum cartridge package with the main body. Add a new one.
13) Attach the drum cover.
•After attaching the drum cover, do no make a copy
•When attaching the drum cover, engage the detection gear 20T rib with the 30T gear rib, and attach the drum to the process frame.)
14) Important.
•Insure proper drum rotation by rotating the drum counter-clockwise (as viewed from the front)
•If the drum does not rotate with reasonable effort the drum blade may need to be re-positioned or lubricated with a small amount of toner.
Dec 16, 2010 | Sharp Office Equipment & Supplies
Drum error. slide green tab in each color
1. power down the printer.
2. remove all color cartridges from their slots.
3. inside the color slot, you will see a green slide that will not move until you pick up the plastic cover.
4. rotate the plastic cover forward.
5. slide the green slide 3 or 4 times. (DO NOT TOUCH SMALL WIRES!)
6. return slide to original position.
7. snap the plastic cover back in place
8. return each color cartridge to it's slot.
9. replace color cartridge holder back to printer.
10. close all covers
11. turn printer back on.
If you still get the "move green slide" error, just repeat these steps
This took me about 10 minutes for the process, after understanding what the "green slide" meant.
Oct 04, 2010 | Brother HL4040CN Laser Printer
Don't know how to change the ink cartlige
Hi
thank you for your query
Make sure the printer is on but not printing. Raise the printer cover, then press down the Maintenance button for six seconds until the print heads move to the center. Pull up the empty ink cartridge clamp all the way. The cartridge rises up from its holder and should be disposed. Unwrap the ink cartridges and remove ONLY the yellow tape seal from the black and color ink cartridge. If you accidently remove anything but the yellow seal you cannot use the cartridge or it will damage the printer. To install the new cartridge, tilt the ink cartridge forward slightly as you lower it into its holder. Hang the tabs at the back of the cartridge on the hooks on the holder clamps. Don't place the cartridge tabs under the hooks on the holder clamp; you may damage the clamp when you close it. Install the ink cartridge and press the Maintenance button to begin charging the ink delivery system. Charging takes about a minute and is complete when the power light stops flashing and the error light goes out
Sep 24, 2010 | Epson Stylus C40UX InkJet Printer
How do I extract the ink cartridge from the printer?
Make sure the printer is on but not printing. Raise the printer cover, then press down the Maintenance button for six seconds until the print heads move to the center. Pull up the empty ink cartridge clamp all the way. The cartridge rises up from its holder and should be disposed. Unwrap the ink cartridges and remove ONLY the yellow tape seal from the black and color ink cartridge. If you accidently remove anything but the yellow seal you cannot use the cartridge or it will damage the printer. To install the new cartridge, tilt the ink cartridge forward slightly as you lower it into its holder. Hang the tabs at the back of the cartridge on the hooks on the holder clamps. Don't place the cartridge tabs under the hooks on the holder clamp; you may damage the clamp when you close it. Install the ink cartridge and press the Maintenance button to begin charging the ink delivery system. Charging takes about a minute and is complete when the power light stops flashing and the error light goes out. For more information on installing an ink cartridge please refer to your Start Here Poster or your Printer Basics Manual.
Nov 15, 2009 | Epson Stylus C40UX InkJet Printer
Audi A4 need to replace rear brake light on audi a4
Inside the boot is a plastic cap embeded in the boot liner. Remove the cap to reveal a screw. Undo the screw and the whole rear light cluster will come away in a sideways and not rearward direction to reveal all of the bulbs. Hope this helps.
Jun 04, 2009 | 2003 Audi A4 Cabriolet
My Hoover 1100 washer/dryer goes through its washing cycles fine but sometimes stops at the draining point. I suspected drain blockage, pulled out the rubber pipe at the bottom and found 7 coins there last...
I suspect this could be a 10p pivoting in the entrance to the filter housing. To remove it tilt the machine back and take off the pipe which is attached to the pump. Feel inside the plastic pipe and remove it.If there is no blockage the pump may have been damaged and will have to be replaced.
do post back if further assistance required.
regards
Dec 04, 2008 | Washing Machines
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
