Question about MIPOW Power Tube 5500
My mipow 5500 has been charging for 6 plus hours and still not blue
How long does a wirless case charger have to charge?
You should always charge a battery in gps devices for at least 24 hours.
May 15, 2014 | Garmin nuvi 255W GPS Receiver
MY Zen WONT TURN ON. It also wont charge.
Connect the player to a USB port on the back of a desktop PC.. Check the display for the charging icon . As the display times out after a few seconds, press any button on the player to reactivate the display. If the battery is fully depleted, the charging icon may not be displayed. Cup the player in your hands to check that the blue power LED behind the Play/Pause and Options buttons is blinking on and off repeatedly. This indicates that the player is successfully charging. After 1 hour of charging, power on the unit to activate the display. The charging icon should be displayed. Allow the player to charge for at least 6 hours. During this time, if charging from a USB port, please ensure your PC does not enter a power conservation mode (Standby, Sleep, or Hibernate) as this will interrupt charging. If the player does not indicate a charge, or will not power on after at least 6 hours of charging, please contact Customer Support.
You might try updating your ZEN V or ZEN V Plus firmware to take advantage of new features and functionality.
http://support.creative.com
Jan 16, 2010 | Creative Labs Zen Micro MP3 Player
My zen wont turn on or charge up and I don't know how to reset it, is there a button??Its a creative zen v plus 1GB
Support site for the Zen V Plus, see:
http://support.creative.com/Products/ProductDetails.aspx?catID=213&CatName=MP3+Players&subCatID=214&subCatName=ZEN&prodID=15306&prodName=ZEN+V+Plus&bTopTwenty=1&VARSET=prodfaq:PRODFAQ_15306,VARSET=CategoryID:213
In the knowledge base solutions Creative gives next answer, when the player does not power on or charge:
To resolve this problem, establish that the player is charging correctly as follows:
  1. Connect the player to a USB port on the back of a desktop PC, to a powered hub, or to a power adapter ( You can purchase the power adapter here as a separate accessory).
  2. Press the reset button and observe the player.
  3. Check the display for the charging icon battery_ac_charge_1.jpg.
    • As the display times out after a few seconds, press any button on the player to reactivate the display.
    • If the battery is fully depleted, the charging icon may not be displayed. Cup the player in your hands to check that the blue power LED behind the Play/Pause and Options buttons is glowing on and off repeatedly. This indicates that the player is successfully charging. After 1 hour of charging, power on the unit to activate the display. The charging icon should be displayed.
  4. Allow the player to charge for at least 6 hours. During this time, if charging from a USB port, please ensure your PC does not enter a power conservation mode (Standby, Sleep, or Hibernate) as this will interrupt charging.
Creative recommends updating your ZEN V or ZEN V Plus firmware to take advantage of new features and functionality. To learn more, visit SID 29048 in our "Further Suggestions".
Note: If the player does not indicate a charge, or will not power on after at least 6 hours of charging, please contact Customer Support.
Reset pin on the left side with the player facing up.
Manual (Multilingual, 17,2 MB) for the Zen V Plus :
http://files2.europe.creative.com/manualdn/Manuals/TSD/9851/0xE85A7F46/Zen%20V%20Plus%20Quick%20Start%20Multilingual.pdf
Nov 24, 2009 | Creative Labs ZEN V Plus MP3 Player
Wont Turn ON
(1) Hit the reset button for 5 seconds.
(2) Hit the reset button, slide down the on/off slide, and have it plugged into the computer at the same time. Hold for 5 seconds.
(3) Hit the reset button again.
(4) Charge it for at least 10 hours in the port in the BACK of your computer.
(5) After 10 hours, unplug the player and press the + volume button. While still holding it, plug the player back in. Keep holding it for 5-50 seconds. (most likely nothing will pop up).
(6) Let the player sit UNPLUGGED for a good 3 hours.
(7) Plug the player back in (it should light up now). Let it charge the usual time it takes to charge for an empty battery, about 6 hours.
Sep 14, 2009 | Creative Labs ZEN V Plus MP3 Player
My creative zen won't charge or turn on
  1. Connect the player to a USB port on the back of a desktop PC, to a powered hub, or to a power adapter (separately available).
  2. Check the display for the charging icon battery_ac_charge_1.jpg.
    • If the battery is fully depleted, the charging icon may not be displayed.Cupthe player in your hands to check that the blue power LED behindthePlay/Pause and Options buttons is glowing on and off repeatedly. This indicates that the player is successfully charging. After 1 hour of charging, power on the unit to activate the display. The charging icon should be displayed.
  3. Allow the player to charge for at least 6 hours. During this time, if charging from a USB port, please ensure your PC does not enter a power conservation mode (Standby, Sleep, or Hibernate) as this will interrupt charging.
Ifthe player does not indicate a charge, or will not power on afteratleast 6 hours of charging, please contact Customer Support.
Creativerecommends updating your ZEN V or ZEN V Plus firmware to takeadvantageof new features and functionality. To learn more, click here.
Hope this helps
Chris (ziraffa)
Jan 14, 2009 | Creative Labs ZEN V Plus MP3 Player
My player wont turn on. The computer reconizes it for a couple seconds but then the player shuts down. The play/pause button blinks but the olayer doesn't seem to be charging. The reset button is broken....
Creative recommends updating your ZEN V or ZEN V Plus firmware to take advantage of new features and functionality. To learn more, click here.
Hope this helps
Chris (ziraffa)
Jan 09, 2009 | Creative Labs ZEN V Plus MP3 Player
My Zen v plus won't turn on. The reset button is broken and it will have the play/ pause button blinking but it doesnt seem to be charging. The computer reconizes it for a couple seconds but then the...
    • If the battery is fully depleted, the charging icon may not be displayed.Cup the player in your hands to check that the blue power LED behindthe Play/Pause and Options buttons is glowing on and off repeatedly. This indicates that the player is successfully charging. After 1 hour of charging, power on the unit to activate the display. The charging icon should be displayed.
Ifthe player does not indicate a charge, or will not power on after atleast 6 hours of charging, please contact Customer Support.
Creativerecommends updating your ZEN V or ZEN V Plus firmware to take advantageof new features and functionality. To learn more, click here.
Hope this helps
Chris (ziraffa)
Trouble
Hope this helps
Chris (ziraffa)
Jan 06, 2009 | Creative Labs ZEN V Plus MP3 Player
MIPOW Power Tube 5500 Logo
22 people viewed this question
Top MIPOW Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a MIPOW Electrical Supply Expert? Answer questions, earn points and help others
