Question about DeLonghi ECAM 23.450 S Espresso Machine & Coffee Maker
The general alarm will not turn off on my delonghi ECAM23450. I have cleaned the inside as instructed and when turned back on heats, rinses then stays on heating up. Tried turning all off and leaving for hours no good. Can not look at menu etc as will not change the screen . Annoying just on Xmas when coffee needed. Please can you help? Is it fixable or not? Thanks Wendy
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Not fixable buy new , check waranty return to store
Posted on Dec 29, 2013
Noggin
  • 944 Answers
SOURCE: DeLonghi Alicia EMK6 - H20 error
Here is the link to the instruction manual if you need it; http://www.delonghi.co.uk/pdf_files/EMK6.pdf There is no information regarding this error message available online, but I think you are right and it relates to water - probably the sensor of the water level is stuck/blocked/scaled up. you can try descaling using white vinegar 50/50 solution with water, leave it overnight. Give the whole unit a good shake, in case the level sensor is a mechanical float device and it is stuck. See if any change. You can call Delonghi/Comet from this link; http://www.delonghi.co.uk/service_info.php hopefully they will tell you for certain what the error message means - if they do and it is different from what is discussed above, then please ask again if you want to try and solve the problem yourself. Hope this helps :)
Posted on Jul 31, 2007
SOURCE: Delonghi EC 155 general help
You don't have to wait 15 mins. just a few minutes, then run some hot water to warm up the portafilter and dry it up, fill it up with coffee and when you get the gree light again, make your espresso . You will have to have a good fine coffee and make sure to pack the coffee really good and don't leave any around the edges , so could make a good seal. If you have steam coming out of the machine , is maybe to hot and is ready to brew . Cool down the machine after use, run water through it and let the steam out of the nozzle.
Posted on Feb 06, 2009
  • 3 Answers
SOURCE: DeLonghi Magnifica always asks "Insert Infuser Assembly"
on my machine, the two screws that attach the infuser receptacle to the insides of the machine came loose. You can see those two stainless hex socket screws when you remove the infuser by grabbing its two red tabs and pulling it out. Just use a hex shaft
screwdriver (size 3mm or thereabout) to tighten them.
Posted on Apr 18, 2009
SOURCE: My Delinghi eam3500 has come up with general
The general alarm message after the machine taking too long to heat up -in deed shows a problem to reach the correct temperature.
So there are a number of possible causes:
the 2 heaters (water/steam) the NTCs(temperature control sensors)
the tempearature overheat-fuses. In my case it was the (water-)heater itself. Be sure to unplug the machine from power supply befor opening!!!
First test then-do the heaters warm up??.....carefull if they do-they are hot!!! If one of them doesn´t warm up- Unplug again!...and then measure the resistance of this heater-If the heater is ok,it should show around 50-58 ohms. If it shows indefinite resistance the heater is broken and you have to exchange it.
In case of both the heaters showing the~50ohms you will have to check the thermal resistors/fuse/NTC.
For me the two forums below wer of great help for me...of course they are in german...but didn´t you wish to learn a foreuage anyway???
Good luck and best regards
Wolfgang
Ref,:http://www.kaffeevollautomaten.org/forums
http://www.kaffee-welt.net
Posted on Dec 25, 2009
Dane1234
  • 25 Answers
SOURCE: eam3500 delonghi coffe machine
From page 21 of the owner's manual: Message: general alarm. Meaning: The inside of the appliance is very dirty. What to do: Clean the inside of the appliance thoroughly, as described in section 15. If the message is still displayed after cleaning, contact a service center.
Hope that all your machine needs is a thorough cleaning; it's not that difficult.
Posted on Jun 29, 2010
General warning coming up in heating cycle.Not working at all.
For DeLonghi Perfecta ESAM5500 Fully Automatic Bean to Cup Coffee Maker Team De-Brewerz.com says:
1. General Alarms should be taken care by authorised delonghi technician only. Please do not try to fix yourself as it is related to safety.
2. This error occures due to loose wirings, opened water circuit, failure of heating elements and last failure of PC board repalcement.
3. Please contact your nearest Delonghi authorised dealer for technical support.
4. You can claim the warranty if recently purchased through De-Brewerz.com . If you are in India then contact us at de.brewerz@gmail.com
Nov 03, 2014 | DeLonghi Perfecta ESAM5500 Fully Automatic...
My delonghi ECAM23.450 when turned on displays "heating up please wait" then nothing - sometimes it will show "general alarm" then nothing - the machine is clean and has not been used very often - any...
Check NTC sensor and heating element terminals. You should get resistance with multimeter or ohmmeter. NTC sensor should change resistance when you heat it up with lighter, finger or whatever heat source you have near by.
May 10, 2014 | Coffee Makers & Espresso Machines
Screen Alert: General Alarm What does this mean
General alarm means the machine has detected a serious fault. There is a section in the instruction manual that may help. If not, read on.
Persistent "General Alarm"
This means many things. If the transmission is not stuck, check the main boiler has not burnt out (open circuit). This happens when the thermoblock labyrinth runs dry and overheats, a common problem caused by leaks, limescale, milk blockages or water filter contamination. Replacing the boiler is the only fix, a difficult and expensive process, experienced fixers (or nothing to lose) only.
Transmission
If the transmission is getting stuck there may be obstructions, the lead screw may be worn or the limit switches could be faulty. If cleaning and grease on the screw/bearings don't help then replacement is a tricky job only for confident hands. Approach with caution.
Aug 25, 2011 | DeLonghi Magnifica 3300 Espresso Machine
Delonghi CT200 cleaning
hello,
Here are step of cleaning oven
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work; it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thanks.
    Oct 10, 2010 | Ovens
    Eam3500 delonghi coffe machine
    May 29, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
    Delonghi toaster oven wont turn off
    have you cleaned the inside of the oven lately?  With the unit unplugged!
    Mar 26, 2009 | DeLonghi DTT900 2-Slice Toaster
    How do i clean the pump for the delonghi ec702?
    you have t use a discaller for expresso machine not vinergar not strong enought follow the instruction on the discaller put product inthe machine with the water start the the machine after a few second turn it off for 10 minute time for the discaller to work repeat untill empty rinse very good that it do that every 3 month thanks pierre
    Dec 13, 2008 | DeLonghi EC701 Espresso Machine
    DeLonghi Rialto Expresso Machine EAM-4500
    You need to reset it. Unplug machine, remove waste container and tray. Put the waste container back in without the tray and slide a knife under the waste container, close door. Plug in. It should reset. Turn off, replace tray and waste container and turn unit back on.
    Easier, call their 800 number and they'll walk you thru it.
    Jun 03, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
    Delonghi EAM 6600
    You need to descale the machine with descaling solution.
    look at following link for instructions
    DELONGHI
    May 04, 2008 | Saeco Vienna SuperAutomatica Coffee...
    DeLonghi ECAM 23.450 S Espresso Machine & Coffee Maker Logo
    813 people viewed this question
    Top DeLonghi Coffee Makers & Espresso Machines Experts
    Henry  Thomas
    Henry Thomas
    Shehu Pro
    Shehu Pro
    Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
