Question about Sharp AR-M237 Digital Copier
Sharf sharp sf-2530 erroe code H4 - Sharp AR-M237 Digital Copier
  • 4 Answers
SOURCE: Sharp copier sf 2530 developer reqired error code (ie indicator on)
It's hard to be sure because our model numbers are different but drum reset should be 24-7 and dev reset should be 24-6. Good luck
Posted on May 30, 2008
  • 62 Answers
SOURCE: Error code H4-01
This mean you have low temp. on heat lamp 2 program interput clear interrupt 14 print may clear this code. if not you can look at the fusing unit and reset thrmo breaker that may be pop off.
Posted on Jul 30, 2008
  • 30 Answers
SOURCE: sharp sf-7100 / status code
H4 means the fuser can't heat up. The fuser lamp probably burned out. Sorry, nothing can be done without tools and new lamp
Posted on Feb 25, 2009
  • 66 Answers
SOURCE: my copier is sharp sf-2530 and signal h5 is
restart the machine or replace the coy lamp
Posted on Aug 29, 2009
  • 257 Answers
SOURCE: H4 error on Sharp SF 7370
The heater lamp isn't coming on either because of blown heater lamp or thermostat reset itself . Clean the thermistor and replace any of the above defective part.Then press C, 0, 0, C and press 14 press READY.
Posted on Oct 31, 2009
How do I fix the error code H4 that blinks continually on the display pane of my copier SF-750
if fixing the fuse unit by checking the thermostat and thermos-fuse then you reset the software by entering simlations by pressing # interpret cancel interpret press 14 start button
Sep 08, 2015 | Sharp Sf 750 Copier Fuser Roller Kit...
Erroe Code H4-01
you must enter cod 14 then press copy key
May 18, 2010 | Sharp AR-M237 Digital Copier
How can I change the toner in my sharp 2530 sharp
open front cover ,release green holder on the right,pullout developer unit add toner .
Apr 26, 2010 | Sharp AR-M237 Copier
How do I Clear H-04 code?
C INTERRUPT 0 INTERRUPT
14
START
Apr 06, 2009 | Sharp SF 2040 Copier
Sharp sf-7100 / status code
Jan 15, 2009 | Sharp AL 1215 Black and White Copier
Code H4 is showing on the machine
h4 code in sharp .that s fuser temperature very high .just reset it.press clear key,auto photo key,clear,auto photo key.copier goes dead .when it goes dead just press 14 then start key.copier will bi ready after some time.it works.by mian jee
Dec 17, 2008 | Sharp SF 2020 Copier
SHARP AL-1216: HOW TO REMOVE H4 ERROR CODE
www.tinli.com.hk/PDF/AL1216.pdf
Hope this helps.
paul
Nov 01, 2008 | Office Equipment & Supplies
May 22, 2008 | Sharp AR-M237 Digital Copier
MY SHARP AR5316 DISPLAY H4 WHEN I PUT IT ON
Here is the process
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Dec 11, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M237 Digital Copier Logo
69 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
