Question about Ovens
Samsung oven not turning on (model: BF30N3T11)
Top oven will not turn on
Make and Model of the oven in question?
Apr 14, 2017 | Ovens
Where do I get the user manual for this oven
Hi Shannette, All you need to do is google "manual for"+brand+model number ie: manual for Samsung TV LE32R53B........ Look for a FREE user manual you'll find it...CHEERS..
Apr 07, 2016 | Ovens
Top oven door is locked...cant open
It should go without saying that it is IMPOSSIBLE to answer your question without first knowing the MAKE and MODEL of your oven.
That being said, if you just ran a self-clean cycle, you cannot open the door until the oven has cooled. If you have not just run a self-clean cycle, the interlock may have failed.
May 14, 2015 | Ovens
Samsung dual oven
what is the model number?
May 25, 2013 | Ovens
Need a turn table for my microwave
model no req.we can proberly supply it.
Sep 18, 2011 | Samsung Ovens
I have a Whirlpool Electric Range GY399LXUS. The oven will not turn on. The top burners work, the only button that works on the keypad is the warm button.
I am an Appliance Technician...... and you need a new clock/ECM The part where the clock is & the oven controls... under there is a big circut board that is basicaly the motherboard for your oven. And I'm sorry to inform you that I just used your model number to look up the board and it is NO LONGER AVAILABLE.... that means they just don't make that part for your oven anymore. Whirlpool didn't use that design very long because they didn't sell well, they were expensive to produce, and they had a few too many problems out of em. So BAD NEWS is they don't make the part you need to fix your oven....GOOD NEWS is you get to go shopping for a Range!!! And BUY WHIRLPOOL!!!!!! DO NOT BUY LG,SAMSUNG, GE, FRIGIDAIRE, OR ELECTROLUX!!!!
Aug 05, 2011 | Ovens
SAMSUNG MBG45
Please explain the problem--
and tell us if the oven is Gas or Electric--
Floor model, or counter top, etc.
Mack B
Dec 28, 2010 | Ovens
How do I change the lightbulbs in the oven
Make sure the oven is off and cool (turn off the circuit breaker). Wear a leather glove to protect your hand. Depending on your model, there may be a glass shield held by a metal holder over the lamp. In the case of a unit with this holder, press on one side to release the shield and remove it. Remove the bulb by turning it counter-clockwise. Replace with a 40 W appliance bulb (turn clockwise). Replace the glass shield and the holder. (On some oven models, the shield will twist on and off like a bulb.)
There are several models of Kenmore 47783 Ovens; manuals are available here: http://www.managemylife.com/mmh/owner_manuals/search?query=Kenmore+47783 .
I hope this helps.
(please note: never operate the oven without the shield in place if your oven has one.)
Dec 12, 2010 | Kenmore 47783 Electric Single Oven
Samsung oven bf641fst displays -SE- How do you fix
According to the crappy manual:
-SE-
An error of the oven may cause low performance and problems in safety. Stop using oven immediately and call service man.
Means very little I know.
Jan 14, 2010 | Ovens
Samsung PKG001 Stainless steel Single Oven and Ceramic Hob : Hob working ok oven light comes on and fans work ok no display on oven and no heat any suggestions
Had exactly the same problem and just had the samsung engineer out (as it was only 3 months old ) who replaced the thermostat. all is now working ok
Jul 15, 2009 | Ovens
Ovens Logo
176 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
