Question about Vehicle Parts & Accessories
How to install a side window on 2010 cobalt? - Vehicle Parts & Accessories
  • 694 Answers
You just take out all of the old black caulk and put a new bead on the new glass and tape it in place overnight
Posted on Mar 06, 2014
Towing capacity of 2010 chevy cobalt
Should not tow any amount with a cobalt not recommended
Mar 05, 2015 | 2010 Chevrolet Cobalt LS
2010 chevy cobalt engine light on with code po641?
its the 5 volt reference user ecu need a expert to diagnostic this problem
Sep 23, 2014 | 2010 Chevrolet Cobalt
What is the location of the shift solenoid b on a 2010 chevy cobalt?
Inside the transmission. Most likely this won't fix your problem...
Sep 01, 2014 | 2010 Chevrolet Cobalt 2LT
Why is our 2010 cobalt still overheating after changing the thermostat?it has the 2.2 engine.the temp reaches 210 +degrees.sitting idled and the cooling fan is not turning on.The cooling fan only runs
was the thermostat installed the correct way round . Fans should start spinning at around 75degres c. Check coolant temperature sensor ( not temp. gauge sender unit) for operation. Have a flow test done on the radiator to check for blocked cores.. Have a compression test done to check gasket and for cracks.
Aug 06, 2014 | 2010 Chevrolet Cobalt LS
How difficult is Replacing driver side power window 2010 Chevy cobalt
not hard just be carefull with new glass and pay attention to how it came apart
Jun 09, 2014 | Cars & Trucks
Where is the pcv valve on the 2010 Chevy Cobalt
It is an integral part of the valve cover. Cannot be replaced
Apr 06, 2012 | 2010 Chevrolet Cobalt
I have a 2010 chevy cobalt. Both of the power windows on the driver side quit working at the same time. The windows on the passenger side will work from the switch on the driver side and/or the passenger...
Window fuse's and relay's may be up under passenger side dash or behind glove box.
Drivers door window gets used the most so it could be the motor, window switch, relay or fuse.
Could also be a broken wire in the rubber boot going from the door to the body. You will have to eliminate each till you find the culprit.
The motor and the relay are the most likely to cause this problem. Try swapping the relay with a working window relay. If it still doesn't work, remove the door panel and remove the window motor.
Turn the motor shaft in both directions by hand several turns. Then plug the motor in and see if the switch will now run the motor. Sometimes thats all it takes to get it working again. I have had to do this with brand new motors. If voltage is not present at the motor connector, either a bad switch or a broken wire exsists. Make sure to check for voltage coming to that windows switch. Actually, GM use's a circuit breaker type relay for each window and one fuse for all the circuit breakers.
Aug 02, 2011 | 2005 Chevrolet Cobalt
Vehicle Parts & Accessories Logo
37 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
