Question about Roland GX-24 Vinyl Cutter
I have Roland GX 24 its cutting from the Right i want it to cut from the lift thank you
I am tearing my hair out trying to get any output from any of the software I have (sign cut, corel x5, easy cut, cut studio etc) from my Roland Camm1 cm 24. I can do the test cut from the cutter which...
The problem is more likely the operating system compatibility with old kit.if you are running something like 64bit windows 7 then the best solution is to have a dual operating system and install windows Xp.there may be updated drivers some where internet
wise.or you could try running in compatibility mode.
lpt and comm refer to older machines with serial port and parallel ports.if you do use USB you are better off using the rear ones as opposed to front end as they connect direct to motherboard.
if you have already tried go to the Roland site and see what support downloads can offer for system compatibility.otherwise you may find a forum via search engines with a driver.until then your machine will not communicate properly with you computer setup.also right click the executable for the software in its own folder and see if you can choose compatibility mode .best will be windows 2000 or Xp.
Mar 29, 2015 | Parallel Office Equipment & Supplies
Fuel cutoff switch
as always , check all fuses first... no DC power , NO JOY!
post a symptoms and list of tests.
no guessing, post engine size and country.?
lots of engines... which one,(open hood, look up, see sticker see engine name. like F22 or? 2.2L or what?
i cant guess i cant work from someones guess.. ever. (or fail)
sorry.
The EFI system only makes fuel pressure 30PSI
if cranking and spark is good.
the EFI cuts fuel for many reasons. you never stated it.
1: wont start.
2: low fuel pressure.
3: low only running.
the EFI also cuts fuel while cranking at WOT, right foot planted
that is, wide open throttle, super secret, unflood mode.
so if TPS is bad (ground were cut) no fuel, ever.
wow, in the FSM 12 fuel supply drawings, by sub model and engine.
in all case of the 12 drawings, the PCM controls the fuel pump directly
but not the GX, and CVT:GX
GOT A GX?
Nov 29, 2013 | 2004 Honda Civic
How to get out of dpics mode on a roland camm-1 pro gx400
Please help us the error code comes "dpics mode" in roland gx-500
Jul 29, 2012 | Roland GX-400 CAMM-1 Pro Vinyl Cutter
Manual for Roland Cut Studio Software
Here is a link for the Cut Studio manual direct from the Roland DGA website.
http://support.rolanddga.com/docs/Documents/departments/Technical%20Services/Manuals%20and%20Guides/RU_CutStudio_Basic.pdf
You Tube Videos:
part 1 of 2
http://www.youtube.com/watch?v=5IPzc2YjRS4
part 2 0f 2
http://www.youtube.com/watch?v=iHLHFz80_Gg&feature=related
Mar 20, 2009 | Computers & Internet
Please i have a roland pnc - 2300 to engrave gold peices
please i have a roland pnc - 2300 to engrave pices of gold the program software i use is called ( ats graphic suite version 1.02) when i want to start engrave i click file engrave and give the order but the printer didn't begin the engrave there was inside the folder printers a file called cut script i didn't find it and the roland didn't start engrave can you help me my email is flexoart1@gmail.com
Regards Saleem Tahir
Mar 11, 2009 | Microsoft Computers & Internet
I have a Roland Camm-1 CX-24 cutting machine that has a parallel connection. I have recently bought a Dell Inspiron 1720 with a Windows Vista OS. I have a USB to Parallel cable to connect the two. I have...
connect the printer and the comp. and boot up....windows should recognize the new device.
did you add the plotter to "add printers" and its driver and to the correct port?
make sure your plotter is on and loaded and function key pressed.
also some cable manufacturers supply a driver...so download one if need be.
what software are you using? is the software cutter driver set to the correct printer and port?
(by default it never is)!!
Aug 03, 2008 | Computers & Internet
Incomplete letters when typing
Ribbon not lifting high enough maybe because it is loose. check ribbon itself if you wind it up does it stay tight, if not bad ribbon.
Jun 17, 2008 | Brother GX-6750 Typewriter
Roland GX-24 Vinyl Cutter Logo
55 people viewed this question
Top Roland Crafts & Hobbies Experts
Debbie
ray gallant
Are you a Roland Craft and Hobby Expert? Answer questions, earn points and help others
