Lap top to hdtv cable - i get picture no sound
Cable with plug into head phones jack for sound
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 22 Answers
Make sure laptop is turned up a bit.
Posted on Dec 25, 2013
alpug
  • 1961 Answers
SOURCE: we suddenly do not have any sound coming through
the problem is the speakers of your tv replace with the same type of speaker
Posted on May 20, 2010
markevans
  • 148 Answers
SOURCE: Blurry and shaking pictures on LCD
refresh rate, likely
try to adjust to a compatible rate. the monitor manual will give you its compatible rates. the video card should have that rate available. if not, you may damage the monitor with the wrong rate.
stop and try another monitor that has a refresh rate available on your video card.
good luck
mark
Posted on Dec 23, 2007
kklare
  • 85 Answers
SOURCE: When I plug my lap top into my tv via hdmi cable I
My MacBook laptop and probably others do not output sound on its mini-DVI connector and thus not into the HDMI adaptor. I would have to use the wired sound output or the optical output--same hole--into the sound system. If you have a DVI-HDMI adaptor, then that is the problem, there is no sound wiring on the DVI side. Same for VGA, which does not have digital video only analog.
-Ken
Posted on Apr 11, 2010
budmrtn
  • 11361 Answers
SOURCE: Bought a soniq hdmi cable
You need to go to TV on screen HDMI sound set up, you can choose AUTO or select the sound to be through HDMI or through the audio ports, check your laptop HDMI sound set up also. I would set them to 'AUTO'
Posted on Dec 01, 2010
  • 39 Answers
SOURCE: we have connected our asus K52J lap top to our
Hi there
I've just looked at that TV model, and it appears that your TV does not support a separate audio connection for HDMI sockets. It also appears that your laptop model has a issue with sending audio via HDMI. Are you running Linux, or windows?
Hope this helps
TV_Doctor
Posted on Jan 03, 2011
How do i hook lap top up
Most Laptops have a VGA output port. You would just hook this to the VGA input of the TV for video (picture).
You would then need to hook an audio cable from the laptops headphone jack to the TV's VGA's Audio Input jack.
Newer laptops have a HDMI output so that is easier and can hook directly to the TV's HDMI input for both video and audio.
Nov 13, 2013 | Zenith R57W46 57" Rear Projection...
My Laptop Headphone Jack on my acer 7551 - I have to wiggle the headphone wire end to get a sound, then hold it@an angle, very sensitively in place, or else the sound will go again - i think the inner...
Your inner jack could be jacked jack LOL . No really sometimes the inner connection gets loose or the connection to the headphone jack port not making good contact might need replaced if you know that your head phones themself work fine!
Jan 21, 2013 | Acer Aspire Computers & Internet
Hi i need to know what cable i need to conect my lap top to tv ? my lap top is a dell latitude d610
Depends what your TV supports. You could do vga to hdmi cable if your tv is newer, this will only do video since vga doesn't support sound. You would need a headphone jack to whatever your tv supports for sound adapter.
Dec 29, 2011 | Computers & Internet
I have an Acer aspire m3200. I tried to connect it to my hdtv, i got picture but no sound using the VGA cord, and got nothing using the HDMI cord. Please help
Using a vga cable to connect your laptop to a hdtv is very easy but the cable does not transfer the audio signal, you need another cable aswell. You need a 3.5mm jack to jack cable, one end plugs into your headphone socket on your laptop and the other end plugs into the pc audio socket at the back of your tv (usually next to where you plug in the vga plug).
May 28, 2011 | Acer Computers & Internet
Hooked up lap top to samsung tv #LN-T2632H using HDMI cable i get picture but no sound what can i do
may need to run a small cable that would plug in for the head phones port of your laptop to the back of the tv's audio port red & white much like one that is used to hook up an mp3 player's to the stereo... would have a small male plug size of head phones and the other end male audio jacks white & red .... not sure why the hdmi isnt providing the sound but think it will fix the issue... csn send a picture of what you need if your not sure what i'm referring to.
Mar 07, 2011 | Samsung LN-T2632H 26 in. LCD HDTV
How do I Connect a Dell Latitude E6500 to a Sanyo Television
Check your ports on the lap top see if you have s video or hdmi or dvi or VGA the best is hdmi if you have that get a cable for either one of you connections also match connections from the lap top to what you have for your TV more than likely if they are both fairly new you should have hdmi connections for both get a cable that is long enough. I get my cables at amazon.com their prices are the bomb.
Connect them together both ends to lap top and to tv then make sure that you have a line in jack stereo jack with RCA ends hook that to the back of your tv and your lap top in stereo jack even better to your surround sound system. Set your TV to AVI 1 or 2 or DVI or whichever is your connection start a movie on the lap top and turn your sound on and see if you have a picture on your screen you should have the same thing as what is showing on your monitor on your lap top. Adjust settings and have fun!
Jan 08, 2011 | Dell Latitude E6500 Laptop
How do I play music from my lap top on this sound system?
your laptop has an audio output jack that is 1/8 inch sterio .. your sound system likely has RCA input jacks .. you can get a cable from radio shack that has a 1/8 inch (3.5mm) sterio plug on one end and two RCA plugs on the other ..
plug the 1/8 inch jack into your computers audio output (headphone jack) .. the RCA plugs will connect to the AUX (analog) input on your sound system .. select AUX on your sterio system to select the computers input .. now you should have great sound from your computer . the computer likely provides only sterio information so the multi (7) channel feature of your sound system will have to fake it ..
Jul 24, 2009 | Pioneer SX-315
How to hook up BenQ PB6100 Digital Projector to a lap top?
Use a standard "video cable" that is used to connect a desktop to a monitor. Your lap-top will also have a similar video out - this is a blue colored outlet jack on your ap-top with three rows of 5-pin holes. The BenQ also has a similar blue receptor jack almost next to the place where you plug in the mains power cable on the rear of the unit.
Dec 20, 2008 | BenQ PB6100 Multimedia Projector
good luck
mark
Dec 10, 2007 | LG 42LC2D 42 in. LCD HDTV
Scrambled picture when cable box is hooked to hdtv plugs on philips 60 inch rear projection tv
I have a 53inch philips that is showing pictre but showing green, red as shadows..
Oct 03, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
