Question about Denon Audio Players & Recorders
Denon 1909 flashing red ring after 20 minutes
I got a Denon AVR-1909 and it is turning off with a 0.5 seconds flashing red ring after playing 20 minutes of Music or watching a movie. So far i tried to disconnect all speakers, and the same thing happens. i did the same thing with opened cover, it runs for hours. I Positioned a fan to the hottest part of it (power supply) and closed the cover again, but it also turns off at about 20 minutes. How can i find the defective part?
    Genius:
  • Denon Master
  • 1,342 Answers
Well on most models red ring singals :
1 ) speaker wires touching something they should not
2 ) internal overheating, shutting down to protect
3 ) something is wrong, bring in for service.
I'm guessing it's out of warranty?
Posted on May 11, 2014
Testimonial: "This is happening also without any speaker connected to it, so the first thing is probably reasoning, but not my problem. Internal overheating is very probable, but how can i check which part is overheating? i tried to measure, the hottest things are the contant voltage IC's of the epower supply, could the power supply be the problem? What does it cost to fix such a problem?"
SOURCE: Sound keeps turning off
We had the same problem, we unplugged and re-plugged in the Bose unit and the sound problem stopped!
Posted on Oct 15, 2007
SOURCE: panasonic sa-ht700
Usually problems that start "out of the blue" after being powered-up for hours, caused by heat building up are due to things inside getting hotter and hotter until they fail. Unless something actually burns up, this is a reversible problem. Shut it down to allow it to cool off, and it works again. I own a SA-HT700. After 24 hours or so of being powered-on. it starts making a loud rumbling noise. Turning it off for 20 minutes fixes the problem. There's a fan on the back of the unit. It does not work. The heat sinks inside my unit are not covered with dust - suggesting the fan has never worked. I rigged an external DC supply to the 12V fan, so now the fan runs all the time. I am waiting to see if this fixes the problem.
Posted on Nov 20, 2008
  • 5 Answers
SOURCE: dvd problems
The issue might be that you have to send the LHT854 Back to the manufacturers and have the playback feature replaced. The playback feature is controlled by a device that is internal and very important to the overall function of the unit.
Posted on Mar 31, 2009
SOURCE: Need Help
i want my panasonic sa-pt770 speakers to work while i'm just watching t.v. and not a movie. can it be done?
Posted on Dec 02, 2009
SOURCE: The music center does not communicate with the
i have the same problem did you find out why
Posted on Apr 01, 2010
Denon AVR-1312 turns on displays for a second switches off and the red light starts to flash
you most likely have a shortedchannel in the amp that would need to be repaired
Jul 31, 2014 | Denon AVR1312 51 Channels Receiver
Denon avr-1909 has sound but no video, tried everything!!
Denon requires that you assign video to specific ports. HDMI, RCA or any other- you have to select which type and which port and you will get video.
Oct 22, 2013 | Denon AVR-1909 Receiver
Setup help for record player (Pro-Ject Carbon Debut) and pre-amp (ART DJPRE II) into Denon AVR-1909. I have everything setup properly, but I cannot get the subwoofer to turn on with my 2-channel settings...
In two channel mode, there will be no subwoofer signal unless you change the front speakers to 'small'. If you set the front speakers as 'large' then the full frequency spectrum will be sent to the front speakers, and none to the sub. Switching from bluray may keep the surround configuration until you restart as you mentioned.
Sep 26, 2013 | Denon AVR-1909 Receiver
I have a denon receiver avr 1909 and the remote control volume button do not work. A new remote control for this receiver is available?
If you mean a replacement, then I would contact Denon they should be able to tell you where and who can supply one. Generally replacement remotes are very expensive. So you might want to consider a universal one.
Aug 04, 2013 | Denon AVR-1909 Receiver
WHATS THE MOST COMMON AND SIMPLIEST SPEAKER CONNECTION FOR THE DENON AVR 1909
Hello,the simplest and most durable is the banana plug,while the most common is simply connecting bare wire.
Feb 21, 2011 | Denon AVR-1909 Receiver
Power cuts off suddenly, the power light flashes red quickly. i checked all wires are secure, none frayed or touching metal.. any ideas what 2 check or what could be source of problem?
You have a power supply problem as one of the +15v or -15v Regulators are bad. This is easy replaced at your local denon service shop.
Jan 10, 2010 | Denon AVR-1909 Receiver
I need reset DENON RC-1099 in begin state
Entering a new remote code will automatically erase the existing code for the device it is currently operating.
The remote for Denon devices is 111.
http://www.usa.denon.com/AVR-1909-OM_E_004.pdf
Dec 13, 2009 | Denon AVR-1909 Receiver
Denon AVR 1909 - tuner audio intermittent - off and on repeatedly
Make sure you have an anteena connected and adjusted
Jan 29, 2009 | Denon AVR-1802 Receiver
No sound playing through microphone
The microphone included with this receiver is for audio adjustments only. That's the "Audyssey Laboratories' MultEQ® six-point auto setup and room calibration system". You cannot hear yourself speaking through the microphone.
Nov 26, 2008 | Denon AVR-1905 Receiver
Denon avr-1909 crackling sound while watching Uverse HD.
It may may the the AT+T box is really not compatible with the AVR or the Pioneer.
Check the specs on those input/outputs for the Ubox and the receiver.
See if they agree. If so, try another hookup method like HDMI ( which carries the audio too)
Nov 05, 2008 | Denon AVR-1905 Receiver
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
